Results 1 to 10 of 10
Thread: OBD2a - OBD1 conversion Harness question.
    Default OBD2a - OBD1 conversion Harness question.
    Original Motor: F22A1 (OBD2A)
    New Motor: DOHC F20A (OBD1)
    New ECU: Stock ECU for the F20A (P6 or something like that)
    Can I just use a conversion harness and be done? or do I need to go through the trouble of buying all new sensors?
    McDonough
    Should be the same as a Civic swap of the same sort. Use a jumper harness and the ECU for the new motor. Think the jumper harness you'd need is an OBD2A-1 harness.
    Check this link: http://www.boomslang.us/obd2to1.htm
    Bitches love bacon.
    whats the year of the car?
    McDonough
    Read his sig.
    Bitches love bacon.
    Feb 2010
    Zebulon
    obs2a to obd1 harness.
    buying new sensors will do nothing as the motor has no place for certain sensors.
    barrow county
    he dosnt need to change sensors or anything. all he has to do is buy a jumper harness so he can plug up obd1 ecu, other than that its plug and play.
    Feb 2010
    Zebulon
    there needs to be a minus rep button for people like above.
    your best option is to reuse the obd2 hardware and wiring, injectors.
    del sol? 94_teg_ls's Avatar
    Quote Originally Posted by xero_xero View Post
    there is one just hit add to rep and disapprove
    /sig
    barrow county
    have you ever done a obd conversion? if not please leave the thread
    who me? if so then its none of your business if not me then ignore that
    /sig
