Results 1 to 28 of 28
Thread: Time to upgrade the R1
    Johns Creek
    Default Time to upgrade the R1
    Put the bike on the dyno today, found my rings are pretty worn. Looks like its time to plan out an engine upgrade for the R1. Thinking about possibly putting an 02-03 injected swap on it.
    McDonough
    Your R1 is carb'd? Didn't know that.
    Bitches love bacon.
    Johns Creek
    2002 was the first year of fuel injection for the R1s. With fuel injection, they made slightly more power topend, but a lot more in the mid and lower rpms. My old 02 is a lot stronger compared to my current setup.
    McDonough
    Ah gotcha. I've been told in the past to stay away from carb'd bikes. Never knew why though. Guess it was from a maintenance point of view.
    Bitches love bacon.
    As far as I know, they're pretty difficult to tune (4 carbs) and synchronize them. Then having to tune for different times of year and altitudes.
    McDonough
    Damn all that. I will stick with my injected 636.
    Bitches love bacon.
    Hiawassee, GA
    Yessir. Tuning can be a real PITA on a carb'd bike. Not to mention the tendency of jets to clog, float valves to stick or not seat properly, etc.
    -Zach-
    1987 Toyota Pickup - Toy
    McDonough
    Zach, you or your shop tunes bikes right?
    Bitches love bacon.
    Hiawassee, GA
    Yessir we do.
    -Zach-
    McDonough
    Good. PM me the cost to dyno tune it. PC3 comes next month.
    Bitches love bacon.
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    Quote Originally Posted by David88vert View Post
    Re-ring and stroke it? (over bore, new cams take ur pick)? Should be cheaper than an engine swap I think..
    But yea what you got done to it so far?
    And the only thing I DO like about carbs is that I can "tune" it with only a screw driver!
    Dec 2003
    Atlanta,GA
    how much is it putting down? my 03 has 50k miles on it and im sure i could use a rebuild but it makes great power
    McDonough
    Zach shall be tinkering with mine in due time.
    Bitches love bacon.
    Johns Creek
    Quote Originally Posted by 1moreaccord View Post
    I may rebuild this one, since I know the motor has no major issues, but I will put another motor in while I do it, so that the bike isn't down too long.
    This bike has a lot done to it, so I will keep it for a long, long time.
    Johns Creek
    Quote Originally Posted by gottraction? View Post
    This one is down to 139 at the wheel right now, as it lost a few hp since it started with the rings.
    My 02 was putting 147 down, but had a lot more in the low and mid range compared to the 2000.
    Dec 2003
    Atlanta,GA
    very nice. i need to get mine up to pair and put it on the dyno. im guessing around 140. which means to me its underated motor. i have done pulls with 06-07 cbr 1ks and have pulled low to mid range so i cant complain
    Hiawassee, GA
    Those are pretty impressive numbers a pre-04.
    -Zach-
    Johns Creek
    Both of them have a LOT of money in them. My 02 had every intake and exhaust mod you could through at it.
    The 2000 is the same, but the carbs don't have as much low end as FI.
    With the CF rims, and CF bodywork, the 2000 is pretty light. I can still pull a lot of newer liter bikes. I don't like to ride this one too hard anymore though, as it is getting harder to repair old bikes. Probably need to grab up another newer bike soon, and let the 929RR go.
    Hiawassee, GA
    We just parted ways with our shop R1 for that very reason. It was a 99 with 44k on the chassis, 01 motor with around 5,500 on it. Fun bike, but little things starting to wear over time on the chassis, and just general stress of being a 40+k bike that was rode like it was. The guy that bought it is extremely pleased with it though. I liked the feel of that bike for sure, I'd love to ride one with more mods. That one was just a full Yoshi, K&N, carbs synced and tuned, -1/+2, 120/190 Conti Sport Attacks, ProTek clip ons, Hotbodies undertail and hugger, Sprint steering dampner setup with custom mount, and everything safety wired.
    -Zach-
    Johns Creek
    Mine has more in the suspension department - all Ohlins, AP brakes, and BST wheels. Makes it handle very quick.
    Hiawassee, GA
    That's where I'd like to spend more money on mine, heck a stock 1k has more power than I'll ever use. Right now I have Superbike Italia worked forks, and a Penske worked rear shock, both serviced this winter by Superbike Italia and setup for my weight/riding style which work good enough for me, but I'd like an aftermarket stabilizer, better brakes, and wheels. I'm rocking the 10w fork oil in the stock dampner for now and it works pretty good, so brakes and wheels are my next investments, then I'll go GPR dampner.
    -Zach-
    McDonough
    A GPR stabilizer is also on my list unless ohlins (sp?) makes one for my bike.
    Bitches love bacon.
    Hiawassee, GA
    We are also a dealer for GPR Stabilizers.
    -Zach-
    McDonough
    Well damn. I guess I will go through you for all parts then.
    Bitches love bacon.
    --- --- --- LordMDP's Avatar
    Oct 2003
    hwy. 129
    you dont have to rejet for temperature/altitude ona stock street bike with SV (constant velocity carbs)
    that would only go for flat slides style carbs or the likes
    McDonough
    Can I run my bike with the thermostat removed?
    Bitches love bacon.
    Johns Creek
    You could, but there is no reason to. You want the bike to be in its optimal operating temperature range.
    McDonough
    Damn. Gotta fix this coolant issue before Zach can tune it. Don't have a clue where to start.
    Bitches love bacon.
