Results 1 to 33 of 33
Thread: New pistions
    Certified Gearhead 02lx's Avatar
    Conyers
    Default New pistions
    Well I am planning on getting some 10.8 or 11.1 compression pistons made and I was wondering if I should change the bore on it? My stock bore is 75 and my stroke is 94.4, what do you guys think?
    http://www.myspace.com/tritoncarclub
    Senior Member 99SI's Avatar
    Jackson
    I am not sure what the level of tolerance for boring the D17 has. I know that my B16 can only take an overbore of about 1mm at the very max on a stock sleeve. I would not really want to take it to that even. I'm sure someone can give you a tip on the 7th gen's capabilities to take an overbore. I would say doing a .030 over bore would be good b/c you can have the bore trued back up and honed which will take out any imperfections and make complete ring seal much more likely.
    Conyers
    yea I was thinking of a .025 overbore and going with the 10.8:1 compression, because I do not have to keep in mind that I am working with stock sleeves
    D17s have a hell of a stroke, thats huge.
    tiny little bore though, i would keep stock bore, most likely if the cross hatches are still present, just drop the pistons in.
    Im curious, why build the D17, there isnt anything available for it in terms of camshaft, valvesprings, etc.
    i think it would be cheaper to just do a K20A3 motor
    Conyers
    I did the math, if I put in a 10.8: 1 with a .5 overbore and build up the engine I will get some real decent gains, someone has done the build without the higher compression pistons and he is putting out 180whp (give or take 10-20whp), and a proper k20 swap will run about 2-3 grand more. it is all about budget. O and there is camshafts, and the full valve spring and retainer upgrades available, you can get up to stage 3 cams, but I am getting stage 2. Pretty much everything is offered for the D17A2 (civic EX) now. Also everyone is doing the K20 swap, I am not that big of a fan of it. paying 4 grand for 160hp, and still I would have to build on that, or for the RSX-s motor that is even more. it is not like I am looking for 300HP, just to max out my current motor, and put alot of people to shame when I show the dyno chart.
    Quote Originally Posted by 02lx
    180 whp on a D17?
    Conyers
    give or take he was approaching it, but he was not finished yet, many people put it down, but it's only real draw back is the intake manifold
    how about ITB's?
    Conyers
    sorry I am not good with all of the abbreviations...ITBs?
    Jackson
    Individual Throttle Bodies.
    180 whp on a D17?
    no shit, thats alot of power out of that little motor
    exactly, i'm thinking more like a b17 if you're lucky.
    Conyers
    naw, well the main thing is the Vtec, the D17 stock cams is what makes it a Vtec-E which is all about economy and not on speed. With more aggressive cams you change the whole outlook, many of the guys now after changing the cam settings, to make it a true vtec and work from there. They are also taking the intake manifolds from the D16Y8, which helps as well. There is alot that you can do with these engines, once you do your research, and realize that vtec mainly affects your cams, you make that more aggressive you start really changing the mind set of your engine.
    I don't get it...you didn't know what ITB's were but you pulled all that out of a hat?
    oh we know how camshafts work. still, the TRICKEST y8 motor i have ever seen NA made like 187whp, and it was not streetable, and it was a 10K$ motor.
    i have a HARD time beleiving with just pistons, and cams and a intake manifold your oging to gain roughly 50whp
    Conyers
    well we will see, i am not trying to prove anything to any one of you guys, because non of you guys are helping me build this thing. I just want to do some stuff to my motor, and whatever I get will be fine with me. I appreciate the input about the pistons though.
    we arent talking shit, take it from people that have built motors and who have alot more knowledge it seems.
    We are just trying to let you know dont expect 180whp when in reality youll be lucky to make 150whp. get the most for your money.
    link me to the thread where the guy is close to 18-whp, id be interested to see it.
    good luck
    Conyers
    I am not saying that you guys are talking shit, I know you guys know about the motors that you guys work on. The guy said it on 7th gen, and I cannot get on that site here at work. See will see what I do in the long run, I am just asking people's opinion on different things to see what is the response.
    good luck
    just look at his ^^^ sig, that should tell you alot. Not to mention we are probably one of the few, if not the only two, on here that has clay tested engines before. I fully respect anyone wanting to build up their own engines or at least do their own research, etc...but like vteckidd said, don't expect that big of a return on your investment, i don't see it happening.
    Conyers
    ok, I appreciate it the honest input, and I will put some thought into it
    speedminded, im learning to degree cams now, ever done that? finding centerlines, etc?
    now that's what i'm talkin about...never on my own though, but assisted with it a few times.
    Jackson
    lol, ^^^^Vteckidd you're such a goofy noob. sheesh, I swear I'm not going to teach you anything else, you're on your own.
    haha whatever. DonF showed me and i think i got a good understanding of it.
    im about to invest in a degree wheel and bore gauge
    i want the digital one that omniman has
    you don't have all that all ready, sheesh, and you call yourself a tuner...you aint nothin but rice man..
    nah i have been doing it the old fashioned way haha
    Conyers
    hey, I took into mind all that you guys were saying and I talk to some people, and took all that I have learned about my engine, and I think ia m going to boost.
    Jackson
    I think that is a wise decision if your goals are 180+! Good luck and keep everyone posted. If you are planning to use a shop talk to mainstream they have some very nice turbo kits that are very competitively priced.
    DC5-R
    Gwinett
    boost is good for your health
    somewhere near ur mom...
    i owned a 02 civic...i tried everything!!
    your best bet is boost or swap! there isn't enough backing for the d17 IMO.....
    M Power
    DC5-R
    Gwinett
    I would like to see this D17 rip out 180whp
    ^so would every member on 7thgencivic.com!!
    M Power
    Conyers
    I will try, I know all of the parts that I am going to get it is just to put my plan into motion, SAVE SAVE SAVE!!!! I will let you guys know how it is going each time, and when it is all finished I am going to head to you guys down at mainstream to dyno it, so you guys can see for yourself, and if I pass the mark you guys say, you better give me some hell of some rep points
