Results 1 to 25 of 25
Thread: 1992 accord
    FREE BUJU StarBwoy's Avatar
    IDK
    Default 1992 accord
    my accord wont start it turn over but wont run can i have sum advice on it plzit would help thanks.
    my dads said it the distributor but hes not sure
    General Tech Hater
    Quote Originally Posted by jdmcivcc View Post
    Hey guys, my Honda Accord won't start. The starter turns the engine over, but it does not actually run. Could someone please help me with some ideas on what could be wrong? Please help.
    Also my father said it could be the distributor, but he is not quite sure.
    This is pretty broad man. You're going to need to check a host of things. Have you checked it for spark at the spark plugs? Have you checked to make sure the main relay is sending a signal to the fuel pump? Have you checked to make sure the fuel pump is operational?
    B-Town Crunk Force
    Statesboro, GA
    Check for spark.
    Check for fuel.
    Post back.
    IDK
    i check the spark and the fuel is great .but i found a video on how it sounds http://www.youtube.com/watch?v=qK3PByIs7nw
    timing belt!
    MCD
    have you pulled the valve cover off yet?
    IDK
    Quote Originally Posted by whatever210 View Post
    yep but im going to check again
    B-Town Crunk Force
    Statesboro, GA
    What? lol
    take the oil cap off and spin the motor over if the valve train is not moving timing belt!!!!! then head work!!!!
    IDK
    Quote Originally Posted by ASE*Tech View Post
    ok i will be doing this
    Senior Member DustnU's Avatar
    I'm on a boat!!
    I had one that did the same thing, Igniter inn the Dizz was bad thats it. $40 and it ran like a champ. Try that.
    Work in progressneed slicks!
    Do a compression test.
    fuel air spark compression what are u missing.
    IDK
    Quote Originally Posted by DustnU View Post
    tell me more
    IA Member d00d's Avatar
    Jul 2009
    macon,ga
    I would check compression, and timing belt. Most of the time its air, fuel, or spark. Always check the big 3 first.
    griffin
    i had one do that on me and it was my main fuel relay
    IDK
    o ok
    it may be the distributor the o ring went bad on my 93 accord so oil went in the distributor, just get another dist
    IDK
    i will be checking that ^
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    if its an interference engine this is a bad idea
    need to check to see if its sparking, if it is then you need to check to see if the fue pump is turning on. if its not then try replacing the main relay.
    About to approach beast mode
    I'm on a boat!!
    Quote Originally Posted by ballistic08 View Post
    No it's not!!!! Your not gonna spin it backwards.
    Grayson, Georgia
    if its an interference engine and you turn it over with a broken timing belt then you're gonna bend valves.
    MCD
    it is and he can get lucky like i did when my h22 snapped timing belt while driving and bent no valves. did a compression test and it was all good.
    Grayson, Georgia
    yeah he could get lucky. but its a good chance hes got valves open and they will bend if he turns that over, but I guess its up to him if he wants to buy new valves and a valve job.
    MCD
    thats exactly what i did and i got lucky as well. i was like holy shit i got lucky as fuck lol
