Results 1 to 23 of 23
Thread: ITBs -vs- AFTERMARKET IM
    Default ITBs -vs- AFTERMARKET IM
    so what do yall think! debating either ITB's or aftermarket! IM for bseries!
    stock GSR block, built GSR head, JDM ITR cams!
    ITB's vs skunk2 pro series IM & sk2 TB ...
    which would have a better gain.. and the ITB's will consist of from a 600cc CBR ITBs fabbed with oem GSR IM flange .. and some fab .. which will gain more?
    /Oo ___A___ oO\
    |=_/_______\_=|
    more info on the setup
    More then likely the ITB's if done right...
    yea im going to have to agree with this
    itbs
    does anyone in IA have a homemade setup? that is running .. ?
    /Oo ___A___ oO\
    |=_/_______\_=|
    are you planning on this being a daily driver especially in lot's of traffic or just a weekend/night car? itb's will have better throttle response and some more gains, but also less driveability...you would probably get used to it, but itb's probably won't be good on a commuter car.
    yeah was planning using it as a DD .. so why's that.. whats the bad about a ITB setup Daily driven ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    Southside Ridin HATCH
    [QUOTE whats the bad about a ITB setup Daily driven ..[/QUOTE]
    ^^ yea, more info on this, I just want to know also..
    ---and just to add I had Skunk2 mani and throttle body on my old setup and i loved it!!!
    I was building ITB's for my Miata using a cut stock manifold with GSXR600 tb's connected with heavy duty couplings. There are quite a few Miata guys dd'ing with ITB's, you might want to check out some of their pros and cons as it's just general tech not Miata specific. ITB's require more tuning then just a aftermarket IM, and a lot more tinkering with.
    Don like 2 prof reed
    Apr 2004
    ATL and Baton Rouge
    +1. Most any car with ITB's will have more power if done right. Look at race cars...
    yeah I might definately want to make it work on mines.. i'll see how it goes.. i just want to get an idea of how other users of ITBs are making there homemade ITB's work, like which throttle cables will work.. and so on.. to get an idea.. we'll better do some research before jumping on it ..
    /Oo ___A___ oO\
    |=_/_______\_=|
    tuning is more critical and if not done right part throttle can be a little difficult...if tuned correctly it's not as much of an issue. the tune is a combination of map and tps based and has to be tinkered with so the transition is smoother. due to the nature of itb's you progress to 0"vac with much less throttle position and have more of an on/off driving unless someone takes the time to play with the tune. the response is still different and takes getting used to...it'll be a fun car to drive.
    YEAH! bRiAnMcIvIcS's Avatar
    Dude, just get the Professional Products (AEBS) intake manifold ($160 on honda-tech) and get the professional products 65mm throttle body($150 on Honda-tech).
    Link:
    http://www.professional-products.com/
    WAY cheaper than skunk2.
    Quote Originally Posted by bRiAnMcIvIcS
    Link:
    /Oo ___A___ oO\
    |=_/_______\_=|
    Quote Originally Posted by YouKnowIt
    HaHa. I Know,Jk.
    EM1 Crew Member
    Link:
    same setup i'm getting on my EM1
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    I think you would probably make more power with the IM and TB. ITBs work on a race car b/c there is a race motor to go with them. Talk to blackR on here, he lost power switching to ITBs and his setup is pretty well modded, hytech header, toda cams, cam gears, itr engine, reving it to 10k, dont really remember what else. I know for K series the cars that make the most power run intake manifolds.
    Depends if your girl likes you smelling like pump gas or not. You have to tune it for the climate, altitude, etc. Seasons change then you'll probably need to re-tune it, etc.
    Quote Originally Posted by OnURleft
    Throttle response before power.
    As Josh mentioned, you can get just as much or more power from a proper intake manifold and throttle body setup anyways.
    Personally if it's a hot performance car then I want to see ITB's on it :boobies:
    everything sounds good except for the part where you said .. seasons change and i'll have to get it re-tune.. Fawk dAT
    anyone agree/disagree on change of seasons.. and by how much of a difference will happen motor explodes and turns into a mushroom?
    /Oo ___A___ oO\
    |=_/_______\_=|
    In any tuned vehicle changes in climate will effect it: temperature, humidity, barometric pressure, etc. The question is can the ECU or Standalone compensate for it.
    in a honda the ecu can compensate a little and changes in temperature, altitude, barometric pressure will affect the power it makes, but it will still be in tune-just making different power. however, w/ intake/tb you can at least run a cai to get cooler air to the motor on hot summer days. unless you run w/o a hood you're injesting under hood air. you could build a plenum around the itb and then run a cai to get the best of both worlds, but the effort and $ you put in may not be worth the gains you see over a good intake/tb/cai setup.
    THANK YOU, i think i'm going to drop my super duper ITB project then.. thanks yall
    /Oo ___A___ oO\
    |=_/_______\_=|
