Results 1 to 23 of 23
Thread: Adding oil to a Manual Transmission.
    Default Adding oil to a Manual Transmission.
    On an integra.
    Can I pour it in through the speed sensor?
    or does it have to be done from the bottom?
    REPS for replys.
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by BIG WORM
    On an integra.
    REPS for replys.
    you can add it through where the speed sensor is located(dont forget to take the speed sensor out )
    yeah that's what I meant.
    Quote Originally Posted by NEMOTEN
    IS300 NEMO's Avatar
    We Fuckin...
    yeah thats how i added mine.
    It's all about JDM.
    CA to GA
    do it the proper way...use a funnel and tube, and theres a bolt to fill, and a separate bolt to drain.
    Quote Originally Posted by gsrteg
    why do it that way. its more of a head ache. the speed sensor is just so much easier while still being just as accurate.
    the old man NAIZBST's Avatar
    remember to fill up with 2.3 quarts
    Hamilton, GA
    use the funnel and hose technique
    Near the cv axle there is a fill hole just put a 17mm on the bolt and pull it out stick in the hose and run it to the top. Then stick your funnel in it and fill until it starts to overflow
    Norcross
    ^^ i just changed my tranny fluid today as well. i wish i woulda seen this thread earlier lol
    IS300 NEMO's Avatar
    We Fuckin...
    Quote Originally Posted by T2KU
    why do it the hard way?
    at least pull the fill bolt out to see when you've got too much. you risk overfilling it through the speed sensor hole. if you overfill the oil will seep out the output shaft and soak your clutch/pp.
    yeah, if it was meant to fill throught the top, they would not have drilled the extra fill hole, just do it the right way.
    drain, fill with 2 quarts. YOu cant overfill if it you only use 2 quarts
    /thread
    Quote Originally Posted by T34me
    not even honda is perfect.
    X2
    Hamilton, GA
    the right way is not always the easiest
    Southside of The Jungle
    Its a headache doing it from the bottom but it is the right way...Make sure you put down a piece of cardboard I spilt alot of oil due to improper tools..
    ccw replicas
    kennesaw
    just fill it in the fill plug its not that hard to do, and your already right there to drain it out. so.....
    HF
    What I do is drain with the 3/8 ratchet bolt and take the 17mm bolt out up top , screw the 3/8 bolt back in tighten it, and then take the 1 10mm bolt out of the speed sensor wingle it back an forth an remove it, fill the fluid until it runs out of the 17mm hole then install the 17mm bolt and gentle install the speed sensor and line up the hole and install the 10mm bolt and your done, whip off fluid and clean up your done!
    Fluid I use either, Honda/Acura fluid which cost 5.49 qt
    or GM syncro mesh!!!
    IS300 NEMO's Avatar
    We Fuckin...
    Lawrenceville, GA
    2 quarts? good god my tranny takes almost 4-5...
    well buy a honda or stop biatching!
    Quote Originally Posted by Stormhammer
