Results 1 to 40 of 71
Thread: Quick Q on my turbo setup.
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    Default Quick Q on my turbo setup.
    I'm building a turbo setup for my Z6 swaped crx and was wondering if upgrading the injectors needs to be done. Curent injectors are the A6 injectors still using the resistor box. I do have the Z6 injectors if there better.
    I'll be running
    Z6 stock internals with Port and Polished head and intake mani. 65mm JG thotal body
    Turbo is a TD05 internaly wastegated at 7 psi (I will only be running this, I have no plans on running more boost)
    I have a P28 chiped with crome pro.
    I've heard that 450cc dsm injectors are what most people run but what is involed in running these. I know you have to bord out the injector seals to fit then in the intake mani.
    any help would be great thank
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    trim the little rubber seals and the resistor box + a basemap is all u need
    we did this on isa2o3's z6 on here.
    Gainesville
    I know about the seals but what about the resistor box? I've read that people with the A6 setup(injector and resisor box) just poped in the DSM injectors and they work is that true?
    Yes keep the resistor box with the dsm 450s.
    ATL ROAD HOG fabulous's Avatar
    WITH UR GIRL
    nice little setup!!
    I LUV VTEC DO U!
    Gainesville
    Quote Originally Posted by fabulous
    nice little setup!!
    thanks
    I'm not looking to make killer power just more that I am now. I'm really just looking to build something fun and the extra HP is a bonus.
    Gainesville
    would the 450cc or 550cc injectors be better on this setup?
    450cc will easily supply enough fuel for your goals and are much cheaper unless you can find rx7 injectors.
    Gainesville
    and the 450 are drop in other than the seals which can be bored out. 450cc it is.
    Now for the oil drain mount tot the oil pan other than welding a fitting on has anyone used these. If so where did you get them because the ones in the pic are $65.
    thanks for all the help
    Gainesville
    sorry for all the dumb Qs but out of all the 6,8,10,12 an fittings witch one is or is clostest to 3/4"? Trying to figgure out the the oil drain to oil pan. The turbo has a 3/4" hose comming off it for a drain so I need to find the fitting thats the same.
    I think I'll use this
    with this
    just need to know what size barbed fitting to match up with the 3/4" hose fitting on the turbo.
    sorry about all the Q pics and descripitions on wed pages
    Flowery Branch
    6an is close to 3/4 your going to want to run smaller to the turbo feed, too big the pressure will be too high, on return you can run whatever, i can weld the bungs in the oil pan if you would rather have that done? i'm local so let me know. oh and use only earls fittings, i have never had much luck with anything else...
    Gainesville
    yea the 6AN is only for the oil drain. I ordered the oil feed lines that are 3/8"
    I'm going to order the weld in fitting like this
    and run the 6 AN 45* Earl's fitting to the turbo drain.
    i used a oil line kit from stealthmode
    Gainesville
    I ordered the oil feed off Ebay I hope its good.
    Gainesville
    I guess I'll order these 450cc dsm injectors. Whats the diff betwent blue and black top injectors?
    http://cgi.ebay.com/ebaymotors/450CC...m270237346046&
    Flowery Branch
    lemme know if and or when you need anything welded
    Flowery Branch
    blue tops going for 100+ bux. what happend to 25-50.
    the black tops are 2g injectors
    all u got to do to make it work is to take the seals off your stock injectors. get a dremel carefully bore it till it fits the dsm injectors. thats it everything else is plug and play.
    this might help a lil
    http://www.homemadeturbo.com/tech_pr...ors/index.html
    edit: might need to change your clips also
    those he purchased are cleaned and spray pattern tested. i picked up a set for $50 the other day.
    Gainesville
    is that the same for the blue and black top ones, Just plug and play?
    i never used the black top ive always used the blue. obd2 ive had to change clips to make them work. on your u might have to change clips or cut the tab off the injectors to make them fit.
    Gainesville
    ok thanks
    they will fit fine with stock injector clips.
    for the record ive actually done several sohc turbo setups in EFs including my own with the d16z6.
    Gainesville
    new Q time!!!1
    Its about a t3/t4 turbo setup
    on the exhaust side of a t3/t4 there is the exhaust hole and then a small hole. On a internally wastgates t3/t4 does the wastgated exhasut come out the smaller hole?
    The problem Im seeing is all the down pipes have a solid flange. I'll post pics
    Gainesville
    bump for some help
    There is a housing that can be bolted on there to convert to an internally wastegated setup. solid flange is used when you are using an external gate.
    btw stay away from ebay turbos!!
    It sounds cliche but most people that try them end up failing, some people do have good luck but a lot don't. its worth a few extra bucks for a piece of mind that your turbo wont grenade itself and trash your engine.
    Gainesville
    thanks for the advice and yea I was just wondering about the down pipe I'm not going to buy any off brand ebay turbos.
    good luck with that
    Warner robins ,Ga
    man ebay turbo ftw! ha
    your moms house
    yes it comes out of the small hole. you will have to find a factory exhaust housing with a internal gate and make a adapter plate for it to stay internal
    Gainesville
    well I think I will be able to use the TD05 that I got for free. I finally got to mock it up on my old motor and figure out what all I need to get the oil to it and out of it. And I think I will be able to fit it with my full size radator.
    covington,ga
    Is it still a good idea to use the missing links?
    Gainesville
    Quote Originally Posted by almightyone
    Good Q I was wondering if I needed this only running 7 PSI.
    Gainesville
    Another question on turboing a d16z6. Can the map senser handle 7 psi of boost or do I need a missinglink or a gm map senser?
    Thanks for all the help you all have given me.
    Yes the stock map can be used for 7psi if you are using a chipped ecu or AFC hack along with 450cc injectors. The missing link is only used alongside a fmu.
    Gainesville
    ok thanks
    Install start this afternoon after I get off work. I'm kind of nervous.
    LOL well hit me up if you have any questions.
