Results 1 to 32 of 32
Thread: poor man's type r???
    Dtran
    Default poor man's type r???
    I'm thinking about going with poor man's type r setup. I have the b16 head port and polished with a 3 angle valve job and stock gsr block. I was just wondering if anyone has any experience with this setup and any problems they ran into? Any advice would be great.
    middle ga
    kyle has one..it was ok i guess. i just never understood the dynamics of it...a b16 head on a gsr block lowers compression right? why would you want a lower compression n/a motor when you are trying to get more performance? maybe i am jst missing something here because its a really popular thing to do and many ppl have had great success with it
    middle ga
    lowers it by .2 by my calculations on that site. stock b16 head on stock b18c1. now if you go changing pistons at the time of the swap i can def see where you could get crazy. b16 block with gsr head and p30's get you 10.65:1...rad
    Quote Originally Posted by japan4racing
    How did you get 10.65:1?
    Block = B18C1/C5
    Head = B16a/b-B18c5
    Piston = p72-A0 (USDM B18C1)
    Head Gasket Thickness = OEM B-series 3-layer
    Piston-to-Deck Height = OEM B18A/B/C1/C5 - B20B/Z
    Compression Ratio = 9.80
    Block = B18C1/C5
    Head = B16a/b-B18c5
    Piston = p73-A0 (USDM B18C5)
    Compression Ratio = 10.60
    middle ga
    instead of gsr bock with b16 head i swapped them around and tossed some p30's in the mix
    Block = b16
    Head = b18c1
    Piston = p30
    Piston-to-Deck Height = OEM b16
    Compression Ratio = 10.657
    Block = b16
    Head = b18c1
    Piston = p30
    b16 block with a p72 head?! That would be retarded, GS-R heads can't breath like a b16/b18c5. Higher compression isn't always better if the head doesn't flow well.
    Athens/ATL
    ^^Word. Pretty much the only thing GSR heads have going for them is the IAB's in the intake mani, and those are only so cool for so long.
    middle ga
    you got me all wrong bro..reading comprehension owns j00! it was just something i noticed. i was not reccomending it all...jeebus you guys need to calm it down a bit! let me make it more clear.....i made an observation that that combo made a slightly higher c/r. i found it interesting so i shared. you guys dont need to try and prove your uber elite internal combustion engine knowlege to me.
    Then use a b16/b18c5 head slightly milled or a thinner head gasket or a taller piston and have way more than 10.6:1...the GS-R head sucks, sure it's a higher compression but its smaller valves and does not breath as well.
    middle ga
    hey guy..it was an observation. im not trying to sway the honda world into building a motor like this. i am very aware of how to raise and lower compression. give it up already. cant a man make an observation without all the vtak boys jumping through hoops to make a point? i never said a gsr head was good..where do you kids come up with this ****? its like you read what someone says and in your mind you change it to somehting that you can argue about....i dont get it.
    Mas Puto! dELfONiK's Avatar
    Then use a B16 head... haha, jk!
    Southside of The Jungle
    Quote Originally Posted by b16civic4do
    what pistons you using?
    ALL CAPS JITB's Avatar
    mmm honda talk
    Certified Gearhead jaystar's Avatar
    www.JdmSouth.com
    im running this set up now on type r pistons and valves and retainers cosmetic head gasket arp headstuds and competition clutch. the head is a b16 with a gsr bottom has nice top end
    Spending money i don't have, to buy parts i really don't need, to impress people i don't know
    Quote Originally Posted by jaystar
    im running this set up now on type r pistons and valves and retainers cometic head gasket arp headstuds and competition clutch. the head is a b16 with a gsr bottom has nice top end
    fixed...
    JDM TYTE AnthonyF's Avatar
    ^i caught that too
    give Mr. Kidd a PM. he will help you out
    The Carbon Fibered R6
    ^i caught that too
    You know, those cosmetic head gaskets...the ones you get a Macy's and you paint them on with the little brush. They even come in differant shades to match the color of your block!
    lolol. When i first read it, i was like "he placed a headgasket on his valve cover?"
    2 of the most intelligent people on this site battling. lol.
    www.JdmSouth.com
    fixed...
    damn i did not even catch that oops thanks
    Banned LS2ner's Avatar
    The Face
    But doesnt the p72 head have the flat edges on on the combustion chamber which reduced risk of detonation?
    Certified Gearhead EK Hotch's Avatar
    Canton
    detonation ftw!!....jk lol
    Swamp
    Quote Originally Posted by LS2ner
    If the P72 combustion chamber is flatter and a few cc's smaller don't you think that would increase detonation?
    As long as premium fuel is being used the chances of detonation on a stock GS-R/ITR is slim to none anyways.
    Dtran
    Thanks for all the comments guys. I have dual valvespring and retainers and ctr cams that I'll be using and probably go with type r pistons
    turbos
    i am kind of new to the honda building but would you not get better results with a B20z with a b16 head on it?
    Quote Originally Posted by seanrg1116
    Sure, if the sleeves don't crack.
    clayton county
    i was in one long long ago. the guy had type r internals though. whipped an 07 SI. =P
    I give out reps....
    <--- RIP :,( psycho_freke's Avatar
    Locust Grove
    I dunno if this will help, but I was scoping out this page on honda tech about building a type-R bottom end the other day:
    http://www.hondatuningmagazine.com/t...ild/index.html
    The Face
    I think what i was thinking of is called "quench pads" maybe?
    I know Mike (Vteckidd) said GSR heads were better for that reason, but im not sure. From what reading ive done, the GSR will make a lil better mid-range compared to the pr3's top end. Im not saying your wrong Speedminded, was just asking about the specific detail on the p72's.
    lol who doesnt whip those
    more torque less reliability due to b20 thin walls,High rpm+b20=boom unless great amount is spent to make it reliable
    clayton county
    You and your knock off Mongoose. =P
    I give out reps....
