Results 1 to 33 of 33
Thread: overheating
    Murdy korilee13's Avatar
    El Paso,TX/ ATL @ Heart
    Default overheating
    its overheating not only while sitting in traffic but even when im driving.
    its blowing out cold air even if its set to heat.
    i pull up to church this morn and smoke poured out of my vents and my engine bay..... sadness. i replaced the thermostat and still doing the same ish. i noticed that the radiator fan is not running if that helps ya'll help me. this is my only way of transportation and i have work tomorrow at 8 in the morning. so i really need ya'lls help. thanks in advance
    sounds like a blown headgasket.
    it would help if you told us what car an motor it is.
    95 civic ex with d15b.
    yea tom from acura and honda specialist told me that a while back...
    but it just started doing this particular thing today. he told me to call you but this will do. you know where i can get a d16 z or zc motor for a good price around atlanta?
    Nadauto.com
    Pacific Imports
    Nadauto.com
    Pacific Imports
    i appreciate all the help man, if i was going to go boost, would you suggest a d16z or what?
    also what would ya'll charge for install?
    Shifting_At Redline Mdeezy's Avatar
    Quote Originally Posted by korilee13
    you may want to check into to why your radiator fans aren't running. Luckily its very cold out so that can help you some with short distance traveling. Maybe a fuse blew, connector came loose/broken. Get those fans working and then see if you have overheating issues still.
    replace your headgasket
    Smart Went Crazy skillzilla's Avatar
    Roswell
    Also check the coolant/oil. If either one looks like chocolate milk, your HG is done for.
    DOTCOM SpeedDreamz's Avatar
    alabama
    look under you oil cap if it is milky then it is a blown head gasket.
    Mobile Electronics and Performance
    Tuscaloosa, Alabama
    In-ground Dynojet
    aka Honda_Chick
    Winderrr Ga
    Quote Originally Posted by SpeedDreamz
    oh. dang. looks like im in the same boat =[
    my car was going from all the way hot to mid like crazy. but i was thinking- theres no way it can go from hot to mid in like 5 seconds. well the other day me and my boyfriend were sitting in traffic and one of the hoses busted. it was an easy fix, luckily it was on the end, and i cut the hose, moved it up and reclamped it jus to get me home. i refilled the coolant and it was fine for about 3 days. now its starting to overheat again. but when im in high rpms, it goes back to normal. .. still sound like a head gasket?
    aka Honda_Chick
    Winderrr Ga
    my car was going from all the way hot to mid like crazy. but i was thinking- theres no way it can go from hot to mid in like 5 seconds. well the other day me and my boyfriend were sitting in traffic and one of the hoses busted. it was an easy fix, luckily it was on the end, and i cut the hose, moved it up and reclamped it jus to get me home. i refilled the coolant and it was fine for about 3 days. now its starting to overheat again. but when im in high rpms, it goes back to normal. .. still sound like a head gasket? and i guess it doesnt help to have 220k miles on the car either.
    buford ga
    Quote Originally Posted by honda_chick
    Have u tryed poring vtec fluid in it?cause u no if u run out of vtec fluid it will run a little hotter than normal
    got air? Bud's Avatar
    northside
    ^^^^lmao
    well thats not my problem because my vtec fluid's all gravy...it was blessed by jesus himself, i never have to change it and it always stays full! hellz yea
    DC5-R
    Gwinett
    check your fan switch, maybe thats why your cooling fan is not kicking on. That could cause you to overheat too. But as stated above, check your coolant and see if that **** is milky, if it is then its a definite blown hg.
    Cambodia
    You blowing coolant back into the reservoir? It could also be a leaky heater core or you're just leaking coolant somewhere else. I'd get the fans working then look for any leaks first before doing a headgasket.
    WEST_SIDE
    LoL @ most Of these replies.
    He gave a good Hint . " when he turns oN heater It still Blows COlds AIR"
    exact same thing happen to me. it was my my head gasket
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    ok all of you... my oil looks normal, the reason i know its my head gasket is that its blowing pressure into the radiator. like a 5 minute ride will create a **** load of pressure, so i was having to ride with a radiator cap missing the "toggle top" or w/e the hell it is, which allowed it to release pressure at all times... tom from acura and honda specialist helped me out with figuring that out, now anybody have any suggestions now? lol
    if you know for sure its the headgasket then either time to rebuild that motor or drop in a new one.
    i'be already pulled the motor out, i'm putting in a sohc ZC. but i'm stilll worried bout the cooling issue. what ya'll think it is or has anyone had this problem? relay, wire problem, fan etc etc
    IP Banned
    Won't the bottom of the oil cap be white if he has a blown headgasket?
    I would drain all the coolant out and add some few afterwards. Have the heater on, so it can circulate better. I had that same problem with my wrx and doing that help'd out.
    Quote Originally Posted by Maniac©
    its a lil late for that, as of about 3 this morning that engine is out of the car. but preciate the help anyways.
    i'm convinced its spmething to do with the fan, considering even when the car was at the redline on the "heat-o-meter" the cooling fan was still not on. im just not sure what it could be.
    F.T.W.K.T.A.
    Dalton
    it also could have been a cracked cam creating alot of heat in the head causing the coolant to turn into steam inturn causing the pressure... i know it sucks trying to figure that much crap out... i had a thread about a year ago and i did everything then i took the cam out and checked it and instead or hearing a ring it was a thud noise.
    94 civic Dx 4dr - N/A Ls/Vtec
    94 Del Sol Si - Project O'SH is GO!!!
    91 Accord Lx - Totaled
    if your fans arent working your car will overheat. I think it would have been best to fix the fan issue then drive your car and see if it still overheats. You might drop in the new motor and still run into the same problems.
    Quote Originally Posted by kain86
    i dont see that having a connection but i guess weirder things have happened
    Quote Originally Posted by Mdeezy
    i drove the car to see if it would still overheat after installing the thermostat, so i could see if that fixed the problem. it wasnt until i got back froim this ride that i noticed the cooling fans weren't working. i replaced the motor because it was a d15b and to me it wasnt worth tearing the head off to replace a head gasket when its like a 300 dollar engine. so i replaced it either way its gettin taken care of
    F.T.W.K.T.A.
    Dalton
    ^^that was why mine was overheating.....
    What up man were in the hell have you been.
    F.T.W.K.T.A.
    Dalton
    roommate didn't pay the bill so my dsl got shut off.
    aka Honda_Chick
    Winderrr Ga
    yea well mines got a lot of pressure in the lines. and ive busted two hoses so far. my uncle is a mechanic and he bled the air out. he said it would fix it. and it did. for about 20 minutes. now back to stiff hoses again. how much does a headgasket run? for labor?
