Results 1 to 17 of 17
Thread: injectors for 500hp
    Certified Gearhead lsi-crvtec's Avatar
    Default injectors for 500hp
    What size injectors are good for 500hp to the wheels its a ls-vtec....my friend was telling me that 720cc are good for that
    thank but i didnt really understand that chart
    about this far.
    get some 550cc
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    I put the sexy in dyslexia.
    R.I.P steven bond....
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    there are variables here.
    I'm guessing you're going boosted, so what size turbo? How's it being tuned? Are you trying to use stock fuel pump[hope not] or are you planning on upgrading? If so, what pump do you plan on using? What compression do you plan on running? We basically need to know every detail of your engine to help you determine correct injector sizing, because contrary to what most people will tell you, there's not a 'one size fits all' for a given HP level.
    Quote Originally Posted by callmetree19
    get some 550cc
    Bad idea. 550s will NOT fuel enough, I'm at ~80%DC on mine right now in the mid 300's on a 2.0L engine.
    about this far.
    ok ok 750
    Imy ruckus
    ~Lagg Squad~
    <turbo negros>
    superduper LLLLLLLLL
    why not just get 1000cc injectors and not worry about anything now or later?
    02 WRX patrick4588's Avatar
    warner robins
    i vote for 1000cc.
    GCO Member
    NRA Member
    Quote Originally Posted by AnclyT
    I agree unless you are worried about an injector driver given they may not be saturated. Peak and hold style.
    thanx guyz...i think ill go with the 1000cc
    Ellenwood
    Quote Originally Posted by RX4BRDM
    Most aftermarket injectors are. Resistor box is easy to wire up.
    Privateer Racing!!
    Duluth,Ga
    I vote for 1600s. When i first started turboing my car i had 450 then i wanted more power, i went too 880, then i wanted more i went too 1000, then i wanted a hell of alot more then i got 1600s.So you se the pattern once u start your always going to want more, so start big!!! hahaha
    Duluth, G-nett
    ^^^^ but we are not as rich as you! lol
    Senior Member anothaRRR's Avatar
    Gainesville, Ga
    Quote Originally Posted by B18c1Turboed
    LOL, thats exactly what happened to me started with 450, to 550, to 880, to 950, to 1000, to 1600....
    I would at least get some 880's....You dont wanna get a small injector and have to run higher fuel pressure just to make up for the difference...
    i dont know, fonzy can get gangsta, he drives a impala. hes a wife beater and a shotgun away from being Scarface
    JDM TYTE AnthonyF's Avatar
    bigger is better
    The Carbon Fibered R6
    Northwest Georgia
    1000 sounds good for what you are doing. Either way a set of injectors will cost the same. Hell do 1200, they finally dropped the price of those.
    I think 750ss's should do just fine.
    "Cool car" less.
    Anti-Nutswingers Crew - Member # 001
