Results 1 to 15 of 15
Thread: 240sx questions
    Acworth
    Default 240sx questions
    I'm thinking of doing a ka-t and was wondering what i was going to need to replace with the install.
    Does anyone know if the factory fuel pump and injectors on a 92 twin cam will hold any boost?
    And also Does anyone know how to install the s-afc on the ecu.. Ive seen the apexi instruction but they list two different ecu types and i dont know which i have.
    Thanks
    Drifter/Kneedragger
    Buford, GA, USA
    Quote Originally Posted by Ruststang
    Thanks
    stock fuel system might hold up to maybe 5psi on a small turbo, but even then you'd be cutting it close. a walbro pump is pretty cheap, and a top feed rail and some junkyard injectors isn't bad either.
    you can tell what ecu you have by the sticker on it (assuming it's there). it's generally on the front of the casing. the two different ecu's should be for manual/automatic cars.
    Acworth
    ok so running a t25 for a bit with stock injectors and a walbro pump shouldnt be that bad until i get some money for junk yard parts.. I just didnt wont to screw anything up.
    run 1psi
    Acworth
    Quote Originally Posted by BenefitX
    run 1psi
    Only 1 psi.... damnit where are all the money trees!... Hello credit card
    Acworth
    ok how about walbro fuel pump and some 300z tt injectors or some sr20det injectors which one would work better oh and a safc
    Certified Gearhead bluuuurr's Avatar
    Oct 2003
    Monterey, CA
    370cc injectors are pretty much the minimum you can slide by with on a ka-t.. walbro 255lph fuel pumps are only like 100 dollars and a must
    i'd reccomend a new head gasket and arp head bolts
    for the long run.. look into pistons
    research, try www.ka-t.org
    Drifter/Kneedragger
    Buford, GA, USA
    to run the bigger injectors you must run some sort of tuning electronics, so an SAFC is a must. unless you're keeping the boost really low you'll also be needing a Z32/Maxima or Q45 maf to keep things happy, the stock one's capacities are pretty easily exceeded.
    for a budget setup using a T25 minimally you'd want:
    -SR20DET injectors
    -SAFC
    -Walbro fuel pump
    -Adjustable fuel pressure regulator (1:1 rising rate)
    if you want to make a little more power:
    -Q45/Z32/Maxima MAF
    -J&S safeguard or other timing controller
    Acworth
    on a sr20 or ca18 u would need an adapter for that one to fit. the nismo one does not need an adapter. im not sure about the KA though.
    Acworth
    Quote Originally Posted by plv
    That one is a universal one after the fuel filter i was just wondering if that whats im looking for since its a vacuum rising level one..You going to come over and help me do all this work pete? Im trying to find someone to tap my oil pan i dont know how easy it will come out or if i should take the car in and leave the pan on to be tapped..
    yeah man ill help u out, when are u planning on doing this? give me a call sometime. are u daily driving the car right now? oh and u should probably check the compression before u turbo it.
    i dont think u want to leave the oil pan on the car when it gets tapped, u dont want the chance of having metal shavings in ur oil. here is how to take it off
    http://www.ka-t.org/forums/viewtopic...hlight=oil+pan
    im not sure about the fpr, i guess the rising rate is the one u need since the engine is NA originally. i dunno if i would trust that ebay brand though.
    Drifter/Kneedragger
    Buford, GA, USA
    you can tap the pan in the car, but it's really a lot more work than it needs to be because you have to pressurize the crankcase to blow out the metal shavings as you drill and it's harder to get to anyway.
    i'd suggest pulling the pan for that, it'll make life easier in the long run since you wont be nursing a big oil leak.
    Acworth
    okay update i know have on the way to my house
    t25 kit with fmic and 3 inch dp
    370cc injectors with fuel rail
    255lph walbro fuel pump and 240sx kit
    3inch cat-back with test pipe
    rising level fpr
    All i need now is an oil return line (Friend at machine shop should be able to make it)
    And an safc... if anyone know where i can get one of these for around 150 or less that would be awesome.
    Thanks for all the help from everyone.
    Evan
    Acworth
    I think im going to start on sunday the 28th and try to have it done and take it to tune it on monday at dyno lab or maybe mainstream i dont know who is cheaper?
