Results 1 to 40 of 60
Thread: Misfiring...
    Default Misfiring...
    well i recently had my motor rebuilt and its been running great but the Check engine light is now blinking, i immediately took it to AZ and it threw codes for misfire on all 4 cylinders...
    i changed out the plugs yet ithe light is still blinking...any information? im not driving the car until i can get this figured out...im going to do the basics (cap/rotor/wires) and see where it goes from there...
    the o2 sensor is unplugged but i dont think this would cause misfiring?
    could timing be off? could the belt jumped a tooth? idk any help is greatly appreciated...
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Quote Originally Posted by Benefit
    is that because its misfiring or because your license is revoked?
    Either way, good call , lawl
    did it have any other codes to go along with it.
    Senior Member G.C's Avatar
    Forgot
    02 wont cause misfiring. to me it seems like timing has gone off. but like you said try doing the basic/cheap stuff first. and see what happens.
    :idb:
    XLR8SHEN FOE LizzziFeE iNsTuN nOoDoH's Avatar
    Cambodia
    Quote Originally Posted by G.C
    I would think the timing would be the cheapest, since you really don't have to spend any money, unless you check ignition timing too where a gun is involved...
    by timing you mean taking off valve cover , setting the motor to TDC (what mark is it on the crank?) and checking the cams?
    Cambodia
    yup, crank pulley white mark on the lower timing cover mark and the cam sprockets both point up with the exhaust 3 o clock mark pointing to the intake 9 o clock mark.
    GetItFixItFlipIt Timinater's Avatar
    my accord was missfiring, it just turned out to be the sparkplug wires, did you get a chance to change yours out yet?
    Quote Originally Posted by no mo hondas
    must be talkin to myself.
    한 국
    ^ LOL
    i'm pretty sure he would have said if there were anymore codes when he mentioned this, not being an ass about it
    just have to make sure. i see people post up asking about 1 code but will have a few others they leave out.
    yes , there was a code for the o2 sensor and 7 codes for misfire...
    i just changed the oil since it has been 500 miles on the new motor , took it high rpm past vtec around ~7k and the light is not blinking anymore....still going to change wires cap, rotor and check timing
    what was the all the codes
    well i just replaced the spark plugs , wires , cap , rotor , and alternator...still misfiring...any ideas??
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    I hope it was built right. What is your setup?
    Oct 2003
    No Mo Hondas has asked you more than once what were the exact codes. Yet you post up what you have. Appearently, you have no desire to get it fixed the correct way, yet you want an immediate, yet simple fix. All you have to do is post up ALL 7 CODES and win a prize!!! Seriously, every code has something to do with each other, especially if there's a camshaft correlation code. Plese post the codes.
    02 WRX patrick4588's Avatar
    warner robins
    have you used a timing light to see where the ignition timing is?
    GCO Member
    NRA Member
    Quote Originally Posted by blackshine007
    there is only 4 codes for misfire...when i go to AZ again ill be sure to write them down...its a random/rapid misfire...
    it started misfiring about ~400 miles into the break in period...the wires were the ****tiest wires i had ever seen , they wouldnt even clip on the plugs...the rotor screw was not even on...it was chilling at the top of the distributor and i saw corrosion on the cap so i thought surely that would fix it...
    i took it for a drive this morning and the CEL was not blinking but the motor was not fully warmed up...so maybe a valve adjustment?
    oh the light does not blink ALL the time , it will blink like 4-5 times every 10 min
    Quote Originally Posted by patrick4588
    no i havent but wouldnt timing be good if it was not throwing codes for 400 miles?
    i figure its worth a shot..u never know what can happen
    i hope its just some fuel problem now...other than that what could it be?? maybe valve adjustment?
    Da "A" Niccuh
    It sound like internals or somethign is seriously wrong.
    i dont think u need a valve adjustment..u'd hear the engine ticking, not misfiring..
    ur problem sounds like ignition or timing
    Quote Originally Posted by twinj
    what makes you think that??
    JDM TYTE AnthonyF's Avatar
    Cumming
    crossed wires? (sorry if this has been said)
    -Ant.
    The Carbon Fibered R6
    ^^ not that kind of misfire...
    i dont even notice it in driving , only way i can tell is from the CEL
    Da "A" Niccuh
    That what it means when the check engine light is flashing. You already did the most obvious troubleshooting. It honestly sound like a piston ring or something. Don't quote me but that just my 2 cents could be wrong.
    What is your setup?????
    motor has new crank , rods , bearings , piston rings , headgasket , oil pump and all the gaskets/seals...
    only thing internally i can think of is the valves not adjusted properly causing a messed up AF/R, which the o2 sensor isnt already fukking up...its a brand new bosch 200$ o2 sensor...just dont know the wiring...and being colorblind doesnt help
    i guess ill compression/leak test?
    gunna seafoam it today , see if it helps any...
    Cumming
    CEL can mean MULTIPLE things not just one particular problem. A Piston ring isnt going to set a CEL. A piston ring collapse will produce smoke out the tail pipe.
    -Ant.
    -Ant.
    This is true. and lets not overlook the fact it ran perfect for 400 miles , and the misfire is not like the engine stumbling or anything.
    got air? Bud's Avatar
    northside
    I was about to say check you seals and vc gasket. Had that problem y-day. But very quick fix. But good luck finding your problem bro
    Da "A" Niccuh
    -Ant.
    You are right muiltiple of things. To determine whether a rings is collapse or not isnt smoke out the tail pipe either.
    -Ant.
    Yes it could. I am not the most technical person. I wouldnt make up nothing either.Everything I said is from experience.
    Just comp test then work from there.
    copied from a member who posted in my thread on H-T
    are there any other codes? when does the code come on? during vtec? idle? normal driving?
    per Helms, possible causes:
    Fuel pump insufficient fuel pressure, amount of flow
    fuel line clogging, blockage, leakage
    fuel filter clogging
    fuel pressure regulator stuck open
    distributor malfunction
    ignition coil wire open/leakage
    ignition control module malfunction
    valves carbon deposit
    compression low
    IAC vavle malfunction
    Fast idle thermo valve malfunction
    fuel does not meet owners manual spec, lack of fuel
    VTEC system malfunction
    test procedures and more info on page 11-78 of the integra manual
    also a misfire on all 4 cylinders would be fuel related i guess...i also have a walbro 255 on the stock fpr/rail/injectors...
    Cumming
    If you say so Mr. ASE.
    -Ant.
    Da "A" Niccuh
    -Ant.
    LMAO, ok ok
    Im French! Frög's Avatar
    AMERICA FUCK YEAH
    my car was misfiring, it was just a coil...
    and it sounded BAD facking As$ while it did!!!
    yea it doesnt make any sounds...
    update-- i just put in a bottle of STP octane booster , and filled up...drove it and the light is not blinking (for now , i hope that did it..)
    about to seafoam in a little bit...
