Results 1 to 40 of 64
Thread: Power Commander dilemma
    McDonough
    Default Power Commander dilemma
    Would putting a PCIII on my bike require the use of an ignition module or would that be something extra that may come in handy?
    Bitches love bacon.
    Johns Creek
    You do not need an ignition module to use a PC3. A PC3 controls the fuel injectors, so that you can optimize your A/F ratio. It is usually used when you change something like your intake or exhaust, to flow more air. The additional air can require more fuel to be added to maintain an optimal A/F ratio. SOME bikes can see a small improvement when stock, but my experience has been that it is not necessary for most modern stock street bikes - especially new ones that have better mapping from the factory.
    Hiawassee, GA
    Quote Originally Posted by David88vert View Post
    He nailed it.
    If you're running some significant exhaust and intake changes I'd recommend one, but nothing else is required with them.
    -Zach-
    1987 Toyota Pickup - Toy
    McDonough
    Okay, that makes sense. Right now, it has a Yoshi slip on but it's going to get swapped out for a Two Bros twin pipe system. Still gotta figure out why my FI light is on. I don't want to mess anything up so I am going to run it over to the shop tomorrow morning and see what's up. I was considering a PC3 just so that everything runs smooth as mods are thrown on it.
    Bitches love bacon.
    Hiawassee, GA
    Did you do the method I linked you to to pull the code? Could be a simple fix that would save you a chunk to do yourself.
    -Zach-
    McDonough
    I never got around to that method before driving past the shop so I stopped in and let them do it. It has something to do with a plug and changing the exhaust to aftermarket. They said it's a $400 fix if the plug is damaged.
    Worse than that, the shop broke my rear brake pedal but since that particular foot peg was already broke, they gave me an excuse about "well.....since it was laid down on that side.....it probably bent the pedal......blah blah blah"
    I can't prove they broke it other than it was working when I pulled into the shop and now it doesn't. Now, either I buy a stock replacement or find a cheap aftermarket rear set.
    Bitches love bacon.
    Hiawassee, GA
    I have no idea what type of plug they are quoting you for $400, seems full of shit to me. I'd pull the code myself and do some research. You can buy a decent folding brake pedal pretty cheap at most good shops.
    -Zach-
    McDonough
    Only problem is where the pedal broke requires me to change the entire rear set on that side; can't just change the pedal itself. It's lame.
    I will see about pulling the code myself and find out. I am going to register on ZXforums and get more information anyways.
    Bitches love bacon.
    Hiawassee, GA
    If you have to replace one side rearset might as well do both, Woodcraft makes a quality cheaper set. Don't go with ebay brand rearsets they have been known to break.
    Pulling the code is easy. These new bikes are easy to work on don't be afraid to try it.
    -Zach-
    McDonough
    I haven't found any woodcraft rear sets for my bike. Found vortex on ebay for 354 shipped though.
    Bitches love bacon.
    Johns Creek
    Ok, when you change the exhaust from stock to a full aftermarket, you eliminate the servo. On a lot of bikes, they measure resistance internally, and will throw an FI code if they do not see the servo. There is an aftermarket adapter for this elimination of the servo, and it usually runs around $100-$150, depending on who you buy it from. Additionally, they probably are planning to make you pay for replacing the rear set that they broke, plus shop labor. All of that would probably be about $400.
    My suggestion - buy aftermarket rearsets - look for Vortex or Woodcraft - preferably a used set on Ebay. Those should run you $150-200 for a pair in like new shape. Buy the servo eliminator, do a search on Google for which is the best for your bike. Get the full Two Brothers twin exhaust, and a PC3. Put all of that on yourself (it's easy), and then take it to get it tuned immediately.
    McDonough
    Two questions: who can tune and does it sound right to only go 105.8 miles on a tank?
    Bitches love bacon.
    Hiawassee, GA
    I don't know anyone down around the ATL area, but I know our shop can do it, as well as 2 or three others up here if you don't mind bringing it up here to get tuned.
    -Zach-
    McDonough
    I can take it anywhere. Im just not familiar with who tunes bikes.
    Bitches love bacon.
    Hiawassee, GA
    I'm sure there are several people down that way that do it. We've got a dyno and have been tuning them for 7+ years now, my boss is an artist with a PC, but there are SEVERAL places up here that do it. I can name atleast 2 or 3 other shops who will treat you right.
    -Zach-
    McDonough
    It doesn't matter to me who does it really as long as it's done. Currently it has a Yoshi RS5 slip-on which will do for the tune. Just need to change some fluids and plugs, get that servo motor eliminator, a new K&N filter, a PC3 and have it tuned. The Two Bros pipes can wait. Will I need a retune when I get the new pipes?
    Bitches love bacon.
    Hiawassee, GA
    As long as you stay slip on you should be fine. It may be slightly off, but no where near as bad as not having a PC.
    -Zach-
    McDonough
    Good deal. The rear sets will take priority. I'll post a pic tomorrow to show what broke. You'll be able to see why I am pissed about it.
    Bitches love bacon.
    Johns Creek
    In Atlanta, there are a couple of shops that tune well.
    For some tunes I go to Rob at MSP Cycle, and for other bikes, I go to Huey at Marietta Motorsports.
    A lot of friends of mine like to go to HFD1 Motorsports, and those tunes have always seemed to be correct.
    There are plenty of other shops that I have not had any experience with, and others that I would not want to try.
    Choose a tuner with care. Get references from people that you trust, and don't be afraid to ask your tuner how long they have been tuning, and what types of bikes that they tune the most.
    Hiawassee, GA
    My R1 was originally tuned at Marietta Motorsports and he had done an excellent job. The tune was near perfect. We put some new plugs in, checked the valves, then just did some VERY minor tweaking to compensate for the fuel I'm running.
    -Zach-
    Johns Creek
    Quote Originally Posted by 03RCode View Post
    I need to take the R1 back over there - these carbs run on black magic - without a laptop, I can't do anything...
    McDonough
    I am ordering the rear sets from Vortex today and hopefully get my PC3 within a month.
    EDIT:
    BNIB Vortex rear sets - $210 shipped
    seat cowl from ZX6RR - $60 shipped
    Two Bros twin system - $650 on Amazon
    Power Commander 3 - $250 on eBay.
    Two down and two to go. All I need after these parts and a tune will be fresh paint on the body and the wheels powdered gold. and a few carbon pieces.
    Bitches love bacon.
    Hiawassee, GA
    I watched my boss tune a 99 R1... I'm out on the carb thing LOL. Are you running any motor work or just intake/exhaust mods?
    -Zach-
    Johns Creek
    Just intake and exhaust mods on this bike. Stock block.
    Hiawassee, GA
    I hear ya. I'm sticking with intake/exhaust/tune on mine as well. I don't see a time I'd ever need any more power, and want to try to stay as reliable as possible since I'm already racking up on miles.
    -Zach-
    McDonough
    I have no intentions on "building" my bike. I just want something fun to ride with a few personal touches. I don't do anything over 80mph and it won't see the track.
    Bitches love bacon.
    Johns Creek
    This one already puts out 140rwhp as it sits. Not quite as much as my old R1, but enough for the street.
    There is no need to build any bike motor unless you are racing - it's cheaper just to buy a newer bike, and they come out with more power each year.
    As for personal touches, this one is on overkill on that. Almost every part of the bike has been changes or modified - even the frame/swingarm is not stock. There's a lot more than people notice.
    McDonough
    I'd love to throw Marchesini wheels on mine but the factory Ninja wheels look good in gold. Still on the search for more carbon fiber parts.
    Bitches love bacon.
    Hiawassee, GA
    I hear that. My bike is staying pretty stock, I had the suspension reworked, some bolt on power stuff, some stuff that just fits my own taste aesthetically that most hardcore riders would probably rag on me for... but they don't have to ride it, and just some small touches to make it how I wanted it. I'm not a diehard track guy by any means, but I plan on building an R6 for track day thrashing.
    -Zach-
    Johns Creek
    Just sold the GSXR-750 track bike.
    Have a 929RR to sell next.
    McDonough
    Same way I am. Making my bike my personal vision.
    I did find a company that makes a GP exhaust for my ZX6R though so I may go with that one instead of the Two Bros twin system.
    Bitches love bacon.
    Hiawassee, GA
    I thought about going 750 for a trackbike but haven't sold myself on the idea of it. After riding my buddies 04?? CBR600RR trackbike for the mod list it's going to be hard to beat dollar for dollar. He has a VERY budget build, and it's impressive. I'd like to stick Yamaha though, just because.
    -Zach-
    Hiawassee, GA
    What company makes the exhaust you are looking at? Ohhh I just noticed your sig, I'm in the process of finishing up my EMT Plus certifitcation.
    -Zach-
    McDonough
    Competition Werkes makes it. Get your license and I can get you a job. Not really any such thing as an EMT +, just Intermediate or Paramedic.
    Bitches love bacon.
    Hiawassee, GA
    That's just what they call the degree at the school I'm going into. Basically the way it's laid out as soon as it's finished I'll start straight into my Paramedic classes. It's structured as a way to get everything through like one big major.
    -Zach-
    McDonough
    I've never seen anyone that liked that kind of program. I've been an EMT for three years now and just now starting to get my foot into the door for my Paramedic degree. The Zero to Hero programs run everything into one course and it throws a lot of people off.
    Bitches love bacon.
    Hiawassee, GA
    I can see where it would. We go through so much stuff it's obnoxious, the only reason I'm doing it is I have been offered a very nice (and also day shift) position at our local EMS once I finish it all up. My entire family is involved in emergency services up here (from 911 dispatch to driving non-emergency transit buses) which definitely helped. Not to mention I had finished all my core classes, my A&P, medical term, and other stuff up the first time I went to school before taking a year off so it wont be AS bad.
    I'm looking into that Competition Werkes setup and haven't really found much info on it. I was going to see if it was something I could help you out on through the shop, but we definitely don't carry it.
    -Zach-
    McDonough
    Just let me know. I'm hoping these rear sets hurry up and come in so I can have a rear brake. Using just the front brakes now requires a fresh set of pads.
    Bitches love bacon.
    Hiawassee, GA
    It's rare I touch my back brakes typically. I've always been a front brake guy. I've got a 2010 Street book in my room I'll look through tonight and let you know tomorrow if we have anything of that sort you might like.
    -Zach-
    McDonough
    Sounds good. I'm not trying to throw too much at it really. Here is my unofficial list of stuff I want for it:
    undertail kit
    GP exhaust
    new taillight - don't want integrated turn signals. want them separate.
    rear tire hugger
    power commander
    misc carbon fiber parts
    Bitches love bacon.
