Results 1 to 11 of 11
Thread: 2000 Honda EM1 P1607 code
    IA Member KrispyWhiteH's Avatar
    Dec 2010
    Crackton
    Default 2000 Honda EM1 P1607 code
    Just seeing if anyone has had this problem occur on their si. My engine light has been a phantom bastard and clearing itself until today i finally caught it on and hurried to a tester to see what the code was. Says its ECM/PCM problem which i have found replacing the ECU wil fix. I was just wondering if my VAFC Neo was F&cking with my wiring.
    If anyone has had a reltaed problem i would like to hear and suggestions before i got grab a new ECU.
    If someone needs a mod list for my motor i will provide.
    I put diamonds in my cereal. For two reasons.
    One- Cuz its ballin as shit.
    Two- So when i poop my doo doo twinkles.
    Dec 2010
    Crackton
    maybe?
    yea replace the ecu. And yes sometime the vafc messed up the ecu. I worked on some cars that did the same thing, just take the vafc off and replace the ecu.
    Dec 2010
    Crackton
    i ran across something about the leaks in the passenger floor board causing the ecu to throw this code due to the connection problem caused by the water. I will be pulling my ecu today and seeing if it is wet. fixing the leak in the a pillar and putting ecu back in to see if it works.
    IA Member donek9's Avatar
    cochran, GA
    if you end up needing a ecu i got one
    Dec 2010
    Crackton
    Thanks man how much you want for it if so?
    Dec 2010
    Crackton
    pulled ecu out. and..... water came out of it... currently drying it. haha.
    Newnan
    no need for a VAFC.
    learn to english
    Dec 2010
    Crackton
    mildew in my ecu.....haha
    and im keeping vtec controller undoubtedly.
    Dec 2010
    Crackton
    thorough cleaning. runs like new.
    Newnan
    good job..
    learn to english
