Thread: 1992 acura integra steering issue
    Oct 2009
    White,Ga
    Default 1992 acura integra steering issue
    Hey guy i got a big issue with my new car when i turn the steering nothing happens to the wheels it just keeps spinning.If its the rack does anybody know how to swap it or a site i can look at.
    LAWRENCEVILLE
    I would look at the sterring linkage first
    Hella stock member!
    Dahlonega
    Quote Originally Posted by silversol View Post
    x2.
    Oct 2009
    White,Ga
    ok guys up date dropped rack and looks brand new
    barrow county
    sorry best picture i can find on google.
    its on your left on right tire, on the right on left tire. its the steering control arm
    this thing come off while dring, you'll be praying for your life. ITS WHAT TURNS YOUR TIRES
    Feb 2010
    Zebulon
    proper explanation of your problem will help when diagnosing.
    if your steering wheel turns, but the rack/tie rods (pictured above with a yellow bushing) fail to move, first check your linkage between the steering wheel and the rack and pinion. there is a u joint held on by 2 10mm bolts.
    since you have the rack down, can you turn the input for the rack and pinion to make the tie rods move? if not, consider a new rack.
    Oct 2009
    White,Ga
    thanks bro that was it. the splines were stripped
