Results 1 to 25 of 25
Thread: Where's the best to get a 302 (5.0)?
    I'm Glad I'm Human CHRISNITTOLO's Avatar
    Oct 2009
    Stockbridge? Ellenwood?
    Default Where's the best to get a 302 (5.0)?
    I want to drop one in my Ranger. Any advice? I will make a build thread too if it happens.
    Block:
    Heads: Explorer GT40P
    Transmission (manual):
    Cam: E303
    Pistons:
    Rods:
    Crank:
    Mounts:
    Harness:
    Headers:
    Exhaust:
    Intake:
    Drive shaft:
    Rear end:
    What am I missing? I will fill this out as I go through. Kind of like a list of WTB. I would greatly appreciate it if I could get the estimated price too.
    Thank you in advance.
    Quote Originally Posted by tdurr View Post
    sigged.
    Projects
    Make sure its a HO Motor
    Oct 2009
    Quote Originally Posted by JDMJAY View Post
    What?
    sigged.
    Projects
    Quote Originally Posted by CHRISNITTOLO View Post
    What?
    High Output motor is built better and more durable then just any 302
    I was told once by a 5.0 GSP Officer that the LX mustang had the best Motor idk.
    Hiawassee, GA
    1987-1992 Mustang was a good choice. Prior to 87 you where about 25hp shy, and in 93 the power rating was dropped around 20hp and 15 ft lbs. The 1987 to 1992 where rated at 225/300. Bolt on a set of Explorer GT40P heads, a small cam such as an E303, and a good upper/lower intake and you will have a pretty decent budget setup.
    -Zach-
    1987 Toyota Pickup - Toy
    Oct 2009
    Quote Originally Posted by 03RCode View Post
    So can I get the mounts off of an exploror? What year? Tramsmission? What's the price outcome look like?
    sigged.
    Oct 2009
    C'mon people. Bump for help.
    sigged.
    Hiawassee, GA
    There are tons of SBF to Ranger motor mount kits out there. Personally for a transmission I'd try to find an AODE out of the same Mustang if you want an automatic, if not you can attempt a T-5 but be prepared to replace them often if you decide to make any power. Price depends on how extreme you choose to go.
    -Zach-
    Oct 2009
    Check OP. An I love 5 speeds/manual.
    sigged.
    turbos
    the boss 302 is a.............
    6 bolt main................
    just saying
    but if bolton is ur thing than the previous posts are ur answer
    TOO BIG
    Oct 2009
    Quote Originally Posted by seanrg1116 View Post
    just saying
    I'm thinking about getting it bored.
    But what are you saying about thiis boss 302?
    sigged.
    Johns Creek
    First off - to the OP:
    How much power are you wanting to make? Do you plan to carb or use EFI?
    Is this to be a DD, or just a weekend toy?
    How much budget over x-amount of time, have you planned?
    Who is doing the work - a shop or yourself?
    If yourself, how much experience do you have with swaps and fabrication?
    Oct 2009
    Quote Originally Posted by David88vert View Post
    Power: As much as I can for a DD.
    EFI most likely.
    DD
    However long it takes for the motor in the Ranger now to go out. A vast amount of time.
    If I come up to something I can't do, than a shop. But I will ask for some help from anybody who wants to. But I will be doing a lot of reading and asking questions.
    sigged.
    Foxbodies?? Anyone?? ranger250x's Avatar
    LIL-burn
    best bet for now is to use a stock HO motor. Getting the engine, trans, and exhaust in place should be your top priority. worry about building the engine after you already have the ranger successfully swapped to 5.0L.
    1999 Mazda Miata- For Sale $4,500 FRIM!
    Oct 2009
    Alright, what would be the first step? Motor mounts I mean.
    sigged.
    Oct 2009
    Bump.
    sigged.
    Johns Creek
    EFI most likely.
    DD
    If you go with a stock 302 block, you are limited to about 450rwhp on a daily driver. If you go with a 351w, you can safely do around 750rwhp. If 450 rwhp is enough, then go with the 302, as it will end up cheaper.
    Best bang for the buck and easiest to install route without nitrous would be to buy a good used 302 and T-5, and a small Vortech blower. Stock motor, with a S trim, 30-42# injectors w/MAF, and a chip for the ECU, Walbro 255 intank, should get you to about 325rwhp, and daily driveable. Later, you could add some heads, cam, intake, and go up to 450rwhp safely.
    Oct 2009
    I like the sounds of that. How hard do you think labor would be? Price?
    sigged.
    Johns Creek
    If you have the time, as you indicated earlier, you should be able to do the swap, and install a SC with little out of pocket for labor. Most of the parts come in the Vortech kits - which you can find for sale used on Craiglist for under $2500. It's pretty straightforward. For help, I suggest you post on the forums like Corral, and learn about the swap, then see if you can have a couple of guys to help you on a Saturday - and you provide the beer. That usually will find you a couple of helpers.
    Oct 2009
    Sounds real good, man, Thank you.
    sigged.
    Loves Twinkies Schroeder's Avatar
    Oct 2009
    In the Garage
    Check this out:
    http://www.jamesduff.com/broncoII/v8conversion.html
    And your best bet would be to pick up a 5.0 out of a Lincoln Mark Vii with matching trans from Pull-a-part in Conley. www.pullapart.com
    Most people overlook the fact that the Mark Vii's have the H.O. motor.
    If you do the T-5 be prepared to get the hydraulic thowout bearing for the T-5. They are Cable operated in the Mustangs and the Rangers are a Hyd operated TO bearing.
    Also You wont be able to "Legally" pass an emissions check here in Ga. You're only allowed to swap an engine that was offered in your year and model. Of course there are ways around this.
    The Shitbox
    Fuck Your AC130 browningboy7's Avatar
    Dec 2008
    Unless he lives somewhere where emissions isn't needed....Like where I live. lol
    bump wish had the cash for a tranny
    Epic Foxbody Thread Crew Member #01
    Oct 2009
    In the Garage
    Quote Originally Posted by browningboy7 View Post
    I just looked at whatever he had posted in the rh upper corner which is Ellenwood or Stockbridge. But like I said there are ways around all of that!
    The Shitbox
    @ballengine ballistic08's Avatar
    Grayson, Georgia
    give Ball Engine a call, they do tons of them and can custom build one to your needs.
    facebook.com/ballengine
    i has stock car :D
    Oct 2009
    If you are still looking for where to purchase all of this..
    mpsautosalvage.com
    I completed a 3.8 to 5.0HO swap in my 95 mustang earlier this year.
    The motor i got only had 32K miles on it and I picked it up for just under 1K. Then all the other miscellaneous parts needed to complete the swap like CCRM and the Harnesses and the minor stuff ran me up another 500.
    So I spent 1500 and 4 weekends worth of time doing this.
