Results 1 to 22 of 22
Thread: Brake Lights aren't working, Need Help ASAP
    Default Brake Lights aren't working, Need Help ASAP
    So suddenly out of the blue about 2 days ago, while driving I press the brake and every single time the open door + seat belt lights and sounds will go off until I take my foot off the brakes; on top of that my brake lights don't come on at all. It's super annoying! I have looked & checked out the wires that leads from the button which the brake pedal presses on to turn break lights off and nothing seems out of place.
    Any ideas or suggestions?
    If anyone in the Cobb/Marietta area would like to take a look then I am willing to pay too so contact me (via PM and/or post)
    Thank You
    ^^this guy loves you jdm-civic's Avatar
    the sky
    sounds like a wiring shortage.....did you put a volt meter to the brakelight switch? check for a open in the swich
    Emancipate yourself from mental slavery, non but ourselves can free our minds- Bob Marley
    facebook me: http://www.facebook.com/profile.php?id=779918877
    Killing it Since1982 bloodline's Avatar
    new york city
    Did you re-wire anything recently? I'm having shortage issues myself..
    riding low is like a religion
    The crack
    Does your cluster still light up?
    Quote Originally Posted by jdm-civic View Post
    I don't have a volt meter at the moment but everything looks fine visually.
    Quote Originally Posted by bloodline View Post
    Have not re-wired anything recently, just happened out of the blue.
    Quote Originally Posted by Okie_doke. View Post
    Yeah my cluster still lights up as normal.
    Stang Mod slostang's Avatar
    Southside
    try replacing the brake light switch.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Look for a blown bulb some where. That might be causing the weird problem.
    An open will not cause that. Don't replace parts or listen to half of IA take it to a pro.
    So no its not a switch or a bulb, that's retarded
    :noitacoL
    Quote Originally Posted by bigdare23 View Post
    What he said ^
    mine was doing the same thing and i called dare, he said check the bulbs, and sure enough a bulb was blown, lol. does your horn work? Check your fuses too.
    McDonough
    any water leaks anywhere inside the car or around the taillights or under the dash?
    Bitches love bacon.
    Oct 2008
    this is the only correct answer
    Quote Originally Posted by 81911SC View Post
    unknown
    fuse or the brake button
    Quote Originally Posted by SVTsanctuary View Post
    None inside the car/dash and nothing in the tail lights from what I can tell.
    Quote Originally Posted by uproot View Post
    The EXACT same thing as mine? By pressing the brake pedal it makes all these other random things go off so I wouldn't think a dead bulb would do that but I guess I'll check. Confirm with me though.
    Sounds peculiar but oook..
    Quote Originally Posted by Eg4LiFe View Post
    Which fuse exactly cause under the dash there isn't a brake light and as for the button, lets say it is bad but why does the chime + seatbelt + open door lights go off too?
    Jan 2010
    did you check your bulbs?
    sounds like wiring. We are in Smyrna if you want to come by.
    Please god take it to a shop and not listen to the idiots in here who know NOTHING about opens
    unknown
    the fuse under the hood it should say STOP ad some other things
    You sir are RIGHT, I give you E-Hugs now that my problem is fixed.
    I had 2 blown fuses (fuse box under hood), replaced 1 & nothing, replaced other and MAGICally everything works! Weird Hondas ..
    Thanks to everyone for the advice, good or bad. Reps if I can to whoever I can get to ..
    :noitacoL
    Quote Originally Posted by KevinT707 View Post
    No it wasn't doing all the crazy stuff, i missed that part but it was very similar and was a bulb problem.
    :noitacoL
    unknown
    no problem.. glad i can help
