Results 1 to 40 of 44
Thread: my build thats almost done
    IA Member 2.0lef_itbs's Avatar
    mission bc
    Default my build thats almost done
    well i might aswell post some pics lol
    Jun III
    excedy 8.5lb flywheel mmm
    springs and retainers
    block
    pistons mmmm compression
    its together and i cant wait for some warmer weather to start tuning it
    valve covers a bit weird but i thought it would be funny
    Krazy Tiny Tunerz
    Nov 2009
    Rome
    nice bro lovin the valve cover
    Certified Gearhead Jello!'s Avatar
    Jun 2009
    marietta 30067
    thats the most awesome valve cover ive ever seen
    mission bc
    thanks lol i've seen some really good airbrush stuff that puts this to shame though i think its fuckin sweet though glad you guys like it
    that vc is sick, that engine is like a wolf in a sheeps clothing, soft cover harnd internals
    Cobb County
    Nice stuff! What compression are those pistons?
    mission bc
    There mahle 11.5.1 CPR pistons I've got about .025 off the head and block together I should he at about 12.0.1
    Senior Member DustnU's Avatar
    I'm on a boat!!
    Damn nice build and VC is SICK!!! Very should I say pepto rific!! LOL
    Work in progressneed slicks!
    Cobb County
    Quote Originally Posted by 2.0lef_itbs View Post
    Good times! Keep us updated!
    your moms house
    nice build man
    you should pick up a set of pro 1's or pro2's and make another 15 to 20whp those are great cams but there is always better.
    my momma's house
    Quote Originally Posted by all-mota View Post
    nice build man
    Pro1's are that much better than JUN III's? I thought Jun's were supposed to incredibly nasty as far as lift is concerned.
    Trend settin'
    mission bc
    The skunk 2 have 12.6 mm of lift with 264 duration on the intake and the exhaust has 11.9mm of lift at 264 duration.
    The juns are 12mm of lift and 11.5 mm on exhaust both with 304 duration.I don't think there's going to be a.15-20 hp difference between the 2 cams.there 2 different cams aswell skunk 2 are more mid range power where jun is more top end
    vanilla sky.
    no itbs?
    mission bc
    No itbs was thing about it. to much work have to make them and then tune for hours to get them to work right.then home made ones usually get out flowed by most after market intakes so I got a 70mm bbk throttle body. I am hoping for low 12,s with this motor
    vanilla sky.
    let me guess for eg?
    mission bc
    89 hatch
    you can only go really fast int the ef chassi lol
    vanilla sky.
    ef,you must be a jdm lover haha.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    My research shows, that the best overall cams on the market are S2 Pro series cams. If you want peak numbers then Rocket Motorsport cams are what you want. Jun cams are good, but they are old. So there are better profiles now. With that being said, Jun cams are still good cams, just not the best out now.
    mission bc
    Lol yea rocket motorsports looked good.I still wanted to go though aircare around here not huge primaries but decent sized.I might look at rocket motorsports when I put the gsr head on it in the next couple of years
    SMR 4 LIfe smrlsvtec's Avatar
    my bro actually made more power with the jun3s than pro1s....go figure...
    your moms house
    sure thing whatever you say man i've only seen it happen plenty of times i never said they will make 15 to 20 peak whp but they make more power everywhere over the jun 3's when setup properly. pro 1's and 2's make more power down low and up high compared the the jun 3's and make more torque along with having a better torque curve.
    but if you don't believe me you can gladly try it yourself. or i'll give you the phone number to the guy that has done numerous cams test with rocket motorsports skunk2 crower jun endyne and every other cam on the market thats worth a crap.
    Quote Originally Posted by smrlsvtec View Post
    that can have alot to do with his setup or the person tuning the car the pro series cams need a nice intake manifold throttlebody and header to perform really well.
    mission bc
    well at one point adding bigger cams wont help.
    the head can only flow soo much air unless i get a port and polish but that wont come for awhile but i am still i couldn't see add no more than 5-10 hp with the difference between the cams these days. i wouldn't mind seeing charts if you dont mind or contact info so i can see charts
    mission bc
    nice build man
    he was running an endyne head, with skunk2 intake and hytech headers...it was tuned in NC...by some shop name RLZ or something like that....my point is that the Jun3 are still good and will make some good power....every motor is different..bigger is not always better..
    your moms house
    i completely agree but there are alot of different aspects that could cause stuff like this and in every setup i have seen the pro series cams have made more power everywhere when degreed in and setup as they should be.
    mission bc
    I just want to go fast!
    your moms house
    don't we all lol
    mission bc
    Waiting for my vibrint tensioner and six puck act clutch
    Apr 2009
    Villa Rica
    bazooka bumbble gum comic spark plug cover?
    mission bc
    Dubble bubble.spark plug cover
    Miss my Civic.
    Reliability, daily drivable, and great power (for usually a cheaper price). The pro 1s and 2s would be my choice. but then again, i have never driven a car with JUNs, so I guess I cant talk.
    mission bc
    The guy I bought my head off of put pro 1 in his type r and said he would have rather had toda B.might be to much cam for a type r .
    Rome, GA
    Quote Originally Posted by silverDA View Post
    lol. Nice build man! Lovin' the valve cover!
    Southside Ridin HATCH
    Damn sick as hell!!
    mission bc
    I can't wait to fire it up
    YEA!
    I know that feeling..AWESOME
    known as Charles
    This has alot to do with it.
    In my opinion, if you are running a stock head or very mildly ported head then the S2 pros are a better cam to run. The larger lift allows more air in but the shorter duration allows for more quench time. I have been happy with the power of the S2 and they make good low end power. We have made over 200whp with 1.8L, stock port head, and ebay header.
    No matter what cam you run you need to degree them in for your motor. I have not had a chance to test this yet on the dyno (I always degree the cams in out of the car) but I would like to see what the difference in power is from just set to 0,0 and when degreed in. Good luck with your setup.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    For the Jun3 specs you posted, that duration is the adv. duration. Actual duration at .05 is closer to the 265 mark. I like to refer back to this chart http://hondaswap.com/reference-mater...m-specs-28669/
    The pro2's have .493" lift on the intake versus the .472" but the Jun has 265 duration versus 258. The exaust cams are very similar, Jun .452" lift, Skunk .458" and both are 265 degree duration. Based off those number I'd say the Jun might make a little more power, but the fast ramp design on the Skunk Pro's is not factered in by these numbers. This is why the Skunk Pro series makes more than every other camhttp://www.skunk2.com/images/diag_ys2cams_lrg.jpg. Yes at .05 the duration is the same but the duration is so much more everywhere else. Jun3's should make more power than the Pro1's though, no matter what. Thats just not a fair comparison imo.
    Your Jun3's should still make very nice power and since you have them there's not much point in getting something else. Just trying to pass along some info for you. Ive been researching cams for my H22 and tried to talk myself into some BC's cuz they are so cheap but the Skunk Pro's will destroy them. I really like the VC as everyone else has stated, gets my creative juices going for mine. Im thinking bright orange with some garfield clippings.
    As I said thats the advertised duration. Ive never understood why cam companies even list that information at all.
    A good read that I found last night with just about every B series cam spec(except the Skunk Pro's):http://www.ek9.org/forum/resource-ar...s-engines.html
