Results 1 to 31 of 31
Thread: ls crank in b18c1
    Warner robins ,Ga
    Default ls crank in b18c1
    ok i have done some research but want some ia input.
    i have a b18c1 block and i know the ls assem will fit in (ls carnk ls rods and pistons) but i already ordered gsr rod and crank bearings and pistons rings can i still use those? with the ls assem?
    Certified Gearhead 94ej2's Avatar
    Mobile, AL
    Yes if you want it to blow up. LS stroke is longer that GSR.
    middle ga
    ask patrick4588 about an ls crank in a gsr block..i think as long as you use the right rods you are safe...patty had i think gsr rods and pistons met head and resulted in broken skirts!
    Warner robins ,Ga
    yes patt is my friend he lives down the road. he used ls crank gsr rods. thats why his blew up im using ls assem meaning LS RODS ls PISTONS ls CRANK lol i know that works with no head contact my ? is can i use my gsr crank bearing on my ls crank assem and gsr rod bearings and piston rings?
    Jul 2009
    2 people missinformed
    ls crank and rods will go in just fine..... oil squirters will hit rods so they will need to be deleted or bent.
    gsr rods will not go on ls crank
    i have forged gsr internals in my turbo ls
    ls crank and rod bump up compression
    Warner robins ,Ga
    yeah but can i use my gsr bearings that i ordered on the ls assem ?
    Quote Originally Posted by xdavidscenex View Post
    no the RODs are different so the Rod BEARINGS will not work.
    Mains i dont think work either.
    GSR/ITR mains the same
    B16/LS mains are the same
    Jul 2009
    you can use the mains as they are the same as ls.... but the crank is different on the rod journals they are different..... you cant use gsr rods on a ls crank...... you will need to get ls rod bearings and use either gsr or ls mains... no biggie... acls are like 30bux at your door
    Mobile, AL
    Quote Originally Posted by dallasb84 View Post
    yeah right when it hit the valves.
    Jul 2009
    once again i have gsr crank eagle hbeam gsr rods and standard je forged gsr pistons in my ls
    Jul 2009
    Quote Originally Posted by 94ej2 View Post
    thats strike two
    so your telling me you cant put a gsr head on a ls.....
    are you stupid
    GSR and LS Mains are NOT THE SAME im almost positive
    EDIT: im right
    ACL Race Engine Bearing Set (Main/Rod/Thrust) B16A2, B16A3,B17A1,B18A1,B18B1,B20B,B20Z1
    B16/LS =Same Mains
    GSR/ITR= Same Mains
    Mobile, AL
    thats strike two
    are you stupid
    now did i say that?
    are you dumb?
    GSR BLOCK+LS CRANK=EPIC FAIL.
    Jul 2009
    C/R (Compression Ratio) for the LS/VTEC
    (B16a head on B18a/b block w/stock b18b rods) motor:
    9.6:1 - P74 LS Pistons
    10.0:1 - P72 GSR Pistons
    10.8:1 - P73 US ITR Pistons
    11.0:1 - P73 JDM ITR Pistons
    11.5:1 - PR3 Pistons (1st Gen B16a)
    11.7:1 - P30 Pistons (2nd Gen B16a)
    12.4:1 - CTR Pistons
    This is with the LS block with LS rods and a GSR (B18C1) head:
    9.8:1 - P74 LS Pistons
    10.2:1 - P72 GSR Pistons
    11.0:1 - P73 US ITR Pistons
    11.2:1 - P73 JDM ITR Pistons
    11.7:1 - PR3 Pistons (1st Gen B16a)
    11.9:1 - P30 Pistons (2nd Gen B16a)
    12.6:1 - CTR Pistons
    11.5:1 C/R is the "Safe" or target on 92+ oct street
    pump gas.
    Jul 2009
    EDIT: im right
    B16/LS =Same Mains
    GSR/ITR= Same Mains
    a bearing set is different than mains.... the reason they are grouping is because of the rod journal difference,,,,
    the mains are the same
    now did i say that?
    are you dumb?
    Wrong GSR block with LS crank and rods =
    Mobile, AL
    wow you are dumb. HE HAS A GSR BLOCK.
    Jul 2009
    now did i say that?
    are you dumb?
    dude thats strike 3.....
    there is no difference between bore and deck height on a gsr and ls buddy....
    shut the fuck up
    Mobile, AL
    Quote Originally Posted by ASE*Tech View Post
    opps thanks for correction. i forgot to add that in.
    Are you sure? I could have sworn ive seen LS/B16 mains listed differently even individually
    Jul 2009
    aka "ls vtec"
    this kid is having a brain fart and doesnt know what hes talking about.... no big deal just funny
    Jul 2009
    that was the problem i ran into when i built my motor.
    the bearing sets were different but the part numbers for the gsr mains and ls mains are the same....
    i had to get my bearings separately and it cost a bit more since i ordered just rod bearings and main bearings.... the thrust washers are the same too
    Warner robins ,Ga
    yeah 94ej2 get it right or get out! this is pro talk im using B18c1 block yeah thats right with a B18b1 crank AND RODS AND uh oh PISTONS = sleeper ls v :] and thanks you guys i matched up the gsr rod bearing on the ls rods and yea they are smaller bc the ls rods are thicker and better but the mains are the same they did line up the same so i just gotta get rod bearings.
    should i spend the 30 bux on ls rod bearings or stick with the gsr crank and rods and just put the ls pistons on that? witch would cost 40 to get the pressed
    i mean i have both setups..
    gotcha, my mistake! Thanks for the clarification
    Jul 2009
    + 1 rep for ej..... we all witnessed the ..... "DOH!!! i knew that..."
    lolololol
    Jul 2009
    no biggie dude.... when doing alot of my build i read alot of what you put in the fact section and built by it so i take it as a compliment to talk motors with ya...
    im still a noob tho.
    Mobile, AL
    shit i thought you said gsr block,ls crank,gsr rods.
    why would you want to use LS Pistons?
    If you are going boost run GSR Pistons strong ringlands and good compression
    if you want to stay NA run B16 pistons for mid 11s compression
    Warner robins ,Ga
    ia is great
    thanks for the help!! i hate second guessing myself and yawl confirm lol
    ++ reps
    Jul 2009
    see this is where i exit the conversation
    HOLLAR!
