Page 1 of 7 12345 ... LastLast
Results 1 to 40 of 274
Thread: Turbo Build !!!
    Jun 2009
    Phenix City, Alabama
    Default Turbo Build !!!
    So as most of yall know I am boosting my ride. This is my first turbo'd car so Im very excited. Well Ive decided to make a build thread to keep yall updated and show yall where Im at. I hope yall enjoy !
    So far Ive got the manifold and boost controller l
    v
    ive got some more stuff coming in this week. i should have some stuff in tomorrow.
    Aug 2009
    DOUGLASVILLE
    how much did that turbo manifoild cost?
    Jun 2009
    Quote Originally Posted by 14thecount View Post
    $ 95 on ebay
    Jun 2009
    just got my Walbro 255 fuel pump in the mail
    Aug 2009
    great start so far keep it up
    Jun 2009
    Quote Originally Posted by getherdone View Post
    thanks man
    AccuracyPerformanceAutomotive
    Let us know if you need help. You have a ways to go, but are gettin to a good start.
    500whp of spinnin fury!!!
    same manifold design i've got. I've heard negative stuff about it since the WG is only coming off one side, instead of the middle. Of couse, I've never noticed it though since Its the only manifold i've had. I'm looking at Spoolin Performance's sbFab manifold though, I'll let you know if theres a big difference.
    @thens!!!!! fools
    I had spoolin performance's log mani on a d16 and it was the fucking bomb.
    Jun 2009
    Quote Originally Posted by QWK D16 View Post
    thanks. i already have everything ordered just waiting on it to get here
    Jun 2009
    so what is the negative effects of this manifold, since the WG flange is on one exhaust port. does it cause any problems ?
    I forget what the main arguement is. Something about it not being equal on all ports, so when the WG opens, its not as efficient of exiting exhaust as other manifolds. But dont quote me.
    And btw, I looked, the manifold im looking at is the SPFab, not SB.
    Jun 2009
    ok well thanks for the info. i think im gonna stick with this manifold cause im out of money. LOL
    02 WRX patrick4588's Avatar
    warner robins
    basically only one runner on the manifold is utilized with that wastegate placement. you want the wastegate to be centered. might cause some boost creep. if you are running low boost, you might not notice it though. gl
    GCO Member
    NRA Member
    ballin on a budget hondalover00's Avatar
    ga
    yes on honda-tech they have a thread about that style mani causing boost creep....ill try to find it
    Jun 2009
    Quote Originally Posted by hondalover00 View Post
    ok thanks
    Senior Member cm7k24's Avatar
    kennesaw
    when i was deciding on which manifold to get that was the one they said stay away from if you run external wg. just because its only getting from 1 port instead of mutilple,
    but keep this thread coming i wanna see the out come
    Jun 2009
    Quote Originally Posted by cm7k24 View Post
    i think i will be find with the manifold. my cousin was running 20 pounds on a Y8 with the same manifold and wastegate i ordered and he had no problems. but i will keep yall updated !
    warner robins
    what wastegate did you get? you arent getting a bunch of ebay parts are you? if so, this build will bring more headaches than you want.
    GCO Member
    NRA Member
    Jul 2009
    you will have no problems with the manifold..... one of the best cast manifolds made for the b series was a "drag" brand that your manifold is knocked off of. if that makes any sense. lol
    good luck\
    i got a tip for you
    get some siemens deka high impedence injectors.... they are CHEAP and dont need resistor boxes..... plus.....THEY ARE CHEAP.
    i got them for 40 bux a pop for 60lb 660s
    Jun 2009
    Quote Originally Posted by patrick4588 View Post
    yes i am ordering off of ebay. LOL i know ive heard of things from ebay but ive also heard good things. so idk we'll see
    Jun 2009
    Quote Originally Posted by dallasb84 View Post
    good luck\
    i got a tip for you
    man i wish u would of told me this earlier. i already ordered the black top DSM 450cc injectors
    Jun 2009
    so as promised i have more pictures. when i got home from school today i had this at my door
    dog wanted in the pic.
    roberta
    GL man hope it all gets together
    West palm beach
    bump for another sohc turbo build and fellow dog lover...reps
    NO ADVERTISING
    -IA MANAGEMENT
    I wouldnt get a wastegate off ebay. You may have luck with anything else, but I have had 2 go bad. They burn out the push rod and the tube warps. Then it sticks open.
    West palm beach
    x2, either run an internally gated turbo, or buy a quality gate...
    NO ADVERTISING
    -IA MANAGEMENT
    roberta
    x2409852 tial could be your friend
    Agreed. Im running a Ebay BOV but I've got a Turbonetics Evolution Wastegate.
    Jun 2009
    i oredered a Godspeed wastegate. any good luck with them ?
    Jun 2009
    also what do i do about welding the piping and the bov flange since there both aluminum. if yall have any good ideas let me know. cause i know its hard to weld aluminum.
    SUPERMAN
    Oct 2008
    Summerville, GA
    What turbo are you going with?
    (SRT EQUIPPED) It's Just A Neon...
    1/4mile= 11.21 @ 127mph 2.0 60ft
    The Boost Is Strong With This One.
    If You Can't Say Anything Nice,
    "Then Go F**k Yourself"!!!
    Jul 2009
    take the flange and the piping to a welding shop..... should be cheap.
    look for a sheetmetal welding place as welding thin aluminum is a whole different science than welding thick materials.... im a certified tig welder and ive seen many people that weld heavy aluminum burn up sheetmetal jobs......
    IA's Pedo-cord tdurr's Avatar
    Fayco
    good info. Welding thin aluminum is a skill that takes a min to get use too. im okay at it..
    but get a brand name WG, and u can get a ebay bov. I got a HKS ssqv knockoff and it works great.
    Save ur engines!
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    how much power are you planning on making initially?
    Jun 2009
    Quote Originally Posted by tdurr View Post
    my cousin found a welder that canweld aluminum,soim going to take it to him
    Jun 2009
    Quote Originally Posted by RandomGuy View Post
    around 200 or a little more
    Jun 2009
    well guys i got some new things in today.
    .50 A/R
    the injectors came in also. the guy said they are 450cc but in says 530 on the side
    now im just waiting on the slim fan and the wastegate and ill be set
    somewhere, GA
    I hope it works out. Like JJspec says...cheap, fast, reliable...you can only have 2.
    '82 TE72 SR5 Sport Coupe
    3tc
    Warner robins ,Ga
    looks good for a first turbo build you will learn alot
