Results 1 to 37 of 37
Thread: Polished up hazy headlights using Mothers Mag & Aluminum Polish
    Default Polished up hazy headlights using Mothers Mag & Aluminum Polish
    I don't know if this stuff will last or if it will eat up the headlights. But these are spare headlights I had laying around. I made a mess the first time. I recommend wiping the polish on with a pad and then using some powered polishing. Don't recommend applying polish to the power tool, apply to headlight instead. DOh!!
    Quote Originally Posted by SweatyBalls View Post
    http://i682.photobucket.com/albums/v...d/DSC_0746.jpg
    http://i682.photobucket.com/albums/v...d/DSC_0747.jpg
    http://i682.photobucket.com/albums/v...d/DSC_0749.jpg
    http://i682.photobucket.com/albums/v...d/DSC_0748.jpg
    DIY thread of the year. Thorough step by step directions lol! :facepalm:
    Seriously, metal polish is the best for plastic polishing. I've been doing it for years. Blue Coral makes a metal polish that has a silicone sealant in it too and have found it works the best.
    I think the Mother's M&A Polish was like under $10 for the 10oz and under $5 for the smaller size. I'll have to try the Blue Coral. Even though the Mothers did a decent job it wasn't perfect. Maybe I'll go back and do it again and longer polishing time. It's plastic so I didn't want to over do it.
    georgia
    will it remove that scaley type crust from the head light?
    yes i am....
    Vtec Member SiR EG2's Avatar
    Gwinnett Co
    you didnt wet sand it?
    Quote Originally Posted by THEONE View Post
    You'll want to wet sand it then polish it.
    B-Town Crunk Force
    Statesboro, GA
    Fantastic write up.
    On a serious note, Im convinced that this is the best pre-assembled kit offered. Never seen ANYTHING work as well. It looks as though the OP used the fitting for the drill which is included in this very kit, or one identical to it.
    'Round These Parts
    Well done on that accord headlight, looks great but the yellowing will be back for more. I can tell that you didn't wet-sand it by looking at the corner of the light.
    Quote Originally Posted by jdm>usdm View Post
    Fantastic write up.
    User error or lack of enough product is very common with those.
    Leisa and S. 4 Life NM?
    Jdm S15 Psw Jdm's Avatar
    Sep 2008
    Atl
    Bump fir you
    Slidin Sidewayz...
    B-Town Crunk Force
    Statesboro, GA
    Quote Originally Posted by Kevykev View Post
    I was able to get both headlights on my integra looking like glass with just one of those kits. I did my own thing though rather than follow the instructions step by step. Maybe thats why my results were different than those of others
    Southern Speed
    Macon
    I always wet sand them first, seems to turn out better and last longer.
    F.A.N.A.T.I.C. primespark22's Avatar
    i used mothers polished and its been goimg strong for a year now,but i use sand paper first
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    'Round These Parts
    Word, The principle is to sand past the top layer of the BS clearcoat manufacturers apply.
    Good Stuff. Bunch of ways to get good results.
    (ノಠ益ಠ)ノ smoknlegend's Avatar
    Around
    Ahh the factory UV coating. Ya, if there are chips in that, you want to remove that whole coat through wetsanding.
    Now i dont know the validity to this, but ive had a few people tell me to avoid metal polish on plastic since some of the chemicals in the metal polish will actually increase the likeliness of them to yellow.
    When I do headlights, i normally use 3000 grit wet sanding, followed by hitting it with meguiars 105 polish on a 4" lake country pad, topped off with a plastic polish by hand, then a wax.
    Quote Originally Posted by smoknlegend View Post
    It will always yellow no matter what is used if it's not properly polished and waxed AND maintained.
    Around
    Quote Originally Posted by speedminded View Post
    of course it will, but what i was told was that because there was kerosene in mothers mag and aluminum polish, it would actually deteriorate the plastic quicker, causing it to yellow sooner.
    georgia
    what grit paper do you all reccomend and is it ok to polish by hand since i dont have drill,i do have a variable speed buffer will that work?
    yes i am....
    If you properly polish and wax it afterward then there is no longer any residue of petroleum based products. That's why it works so good, it basically eats off a layer...like a liquid sandpaper. I've using metal polish on plastic lenses for at least 7 years.
    ^^^to theone it depends on your lights and how bad they are,mine where pretty bad i had to use 600,800,1000,i went the extra mile and used 1500,2000 then polished
    georgia
    Quote Originally Posted by primespark22 View Post
    so trat the lights like paint then? should i use any soap in the water?
    yes i am....
    Yes, all plastic and glass should be treated like the paint. You can wet sand, polish, and wax all of it.
    I wouldn't sand glass though, there's no need in it since there is nothing on glass that can't be polished off. I always polish and wax windows though.
    he speaks the troof^^^^^
    georgia
    well thanks, im gonna try this again, will my polisher work for this with a wool pad and terry cover?i tried scratch out it helped but not that much and yeah my light housings are plastic.
    yes i am....
    yeah but ones you sand with a lil work you can even polish with a shirt lol,i have a big buffer at the shop but what i did was get a small one for 20 buxs for the little stuff
    'Round These Parts
    WOW, I can't believe you go that fine.
    I stop at1500, As long as you have the right products all scratches will be removed.
    For Japanese Vehicles 800 or 1000 is actually a good starting point. German Vehicles you must start @ 600 but as low as 500. Starting at 800 or 1000=longer sanding time.
    I can go on and on and on I've got it down to a science and the yellowing never comes back EVER (only on cheap aftermarket applications) I doubt they use polycarbonate lenses.
    Speedminded - Glass is a LOT more labor you can actually sand glass to reduce/minimize pitting which will lead to greater clarity.
    ^^^yeah thats how i look at it,the finer grit the more you will sand,and thats good info you posted
    No I didn't wet sand it, just wanted to spend a minute on it and see how it would clean up without any effort. Lazy.... yes very!
    If they weren't my spare headlights that I don't plan on using, then I may take the time to wet-sand it.
    I don't even know where that foam polishing pad came from, it was just in my toolbox. It may have been from the 3M kit.
    Thanks for all the response.
    Senior Citizen Dylan's Avatar
    Milledgeville
    yeah i tried it about 3 weeks ago on my car and the yellow came off pretty well..and still hasnt returned.its a great 5 mins in effort improvement.
    Northwest Georgia
    i wet sand with 2000 till consistent and then use the dewalt buffer and meguires compounds. Its been a few months now and still shiny. It usually will come back if you dont clean them and wax them from time to time, the factory coating has just burned off from sun and weather and you really should clear coat them or put the 3m clear bra stuff on them to make it more permanent.
    Senior Member mikesEK's Avatar
    over yonder
    ive allways wondered about that as well
    i THINK itd go like this 800-1000...and just clear them (like by a car paint shop) cux
    there'd be no need to polish cuz the paint would need some sorta surface to adhear to
    anyone done this..... I have a cousin that paints n he says "yeah itll work
    but it may flake off at some point, the clear is made to bond onto PAINT
    not plastic" what you guys think....or has anyone on here ever had a set cleared before?
    PawnShopMike
    I miss-spell big words freeqwentlee thanks Dekalb Co skhool systems
    Northwest Georgia
    Quote Originally Posted by mikesEK View Post
    it would work fine, clear is made to bond to anything that is properly prepped for it, like fresh base coat, or a properly sanded sub strait.
    over yonder
    Quote Originally Posted by SPOOLIN View Post
    with that being said......automotive clear would last way longer than a polish
    job....right??!?!?!??!?!?!?, cuz it has uv stabilizers in it
    PawnShopMike
    Certified Gearhead RHD_Joe's Avatar
    Bump for lookin
    IA's Biggest Grouch
    Kennesaw, GA
    I've wondered this myself, and what you guys put on the headlights to protect them from UV?
    'Round These Parts
    Quote Originally Posted by 91LudeSiT View Post
    Just keep them waxed.
    Do not put automotive clear on them, you'll just be recreating the problem.
    The clear will pit since the lights are up front, then it's down hill from there. The clear will also give it a texture.
    When you do it the RIGHT way, Clear is unnecessary.
    Fantastic write up.
    x2 what i heard from a buddy at autozone
    cars
    still searching! Hondatwin23's Avatar
    Atlanta\Lithonia
    that kit has the exact sand paper grit for the headlights to come out good. that trizac at the end is the key
    http://twitter.com/LEGEND_STATUS
    1997 w/1999 civic w/ Built GSR...FS/FT
