Results 1 to 10 of 10
Thread: Which D-series block is best for boost?
    95 teggy for parts DaRussian's Avatar
    Default Which D-series block is best for boost?
    i have some parts laying around at home and just wanted to put it together to boost it. never done it before... which d-series block is best for boost?
    VQ Power ------- SHIFT_W.O.T <br>
    03 Maxima 6spd VLSD -- 1/4 mile -- 14.12 @ 96.3
    92 eg Hatch b20vtec -- 1/4 mile -- 13.6
    Originally Posted by MMBmomoney
    i changed the vtec solenoid and nothing changed. in another post i saw "vtec fluid" where is that located and how do i check it?
    go with the d15 but most ppl would say d16
    which ever one you decide to sleeve
    Southside Ridin HATCH
    Id go with the JDM D16
    West palm beach
    Quote Originally Posted by Black4DrEK
    why, most jdm engines have higher compression. other then the pistons, d16 blocks are pretty much the same. the y7 has the dip stick on the side witch is out of the way of the turbo , and the y8 has known oil pump issues , any of these would be fine- d16a6, d16z6,16y7 or either one of the sohc zc's
    NO ADVERTISING
    -IA MANAGEMENT
    140 on one wheel
    columbus, ga
    d16a6 or z6...im running the y8 with no problems though and im at around 360whp
    Where Am I
    Really any of them theirs really not a big difference between the D16's, But for my vote I'd say the Y8, Newer=less miles, better tranys, Cheap, Vtec, Good intake manifolds, over 200hp easily......
    ok thanks for the help guys. i guess im just going to go with y7. but if i find anyother one for cheap ill jut get it lol. im not trying to go for crazy power just want to turbo a motor and just push it all it got lol.
    it's true! QD my fav tmracing83's Avatar
    Rockdale, GA
    id say d16z6
    thats what ive been runnin and i havent had one prob.
    OBAMA..... *IS*
    One. Big. Ass. Mistake. America.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    ahhh you will think im nuts but a d15z1 E vtec is a good choice as far as the block. when the head is off look down in the coolant walls and its like this, the bottom of the inside of the water jackets are only half way from the top of cylinder compared to the others being at the very bottom and it slants to the back on the intake side so it more reinforced on the thrust side od the block and has pretty thick sleeves and a fully main cap girdle! also the d15z1 pistons r low compression when used with other vtec heads cause they have a huge dish in them. the d16 cranks and rods with these pistons should all interchange as well because the blocks are tough,im telling you but the heads for the d15z1 are the weakpoint with little economy flow ports hince E-VTEC!
