Results 1 to 14 of 14
Thread: stock d16 turbo
    mr.slow
    lawrenceville
    Question stock d16 turbo
    hey guys
    im new to this so i have a question
    with a stock d16y8 and a not so expensive turbo but not so cheap...how many horses would it pull with the stock engine?
    nd how many psi would be good to keep the engine not to blow
    warner robins
    JJSPEC.COM
    Top Secret Build TopNotchEG9's Avatar
    45 min from the A
    if you looking for something not too expensive but still make power...i probably think you should run an eclipse turbo (TDO5) with a HF manifold with an adapter plate and the basic parts of the turbo kit (intercooler, pipings, bov, etc.) and tuned around 8-10psi to be safe...power range 160-180hp...real good for the streets...
    Senior Member WalkS's Avatar
    Middle Ga
    I put a real cheap home made turbo kit together for about 700 dollars. 14b turbo, hf manifold, hm dp, JRC IC abs plastic ic piping, dsm injectors, turboedit. It was on my 214,000 mile stock d16a6 crx, my boost was around 8psi, sometimes it wanted to creap up to 12psi. It was fun!
    I wouldn't worry too much about blowing it up, as long as you have the correct fuel and timing from a tune, your good to go!
    JJSPEC Racing
    mr.slow
    lawrenceville
    about how much money am i going to be spending? with thw turbo kit and tunning?
    FLOSSIN' MR.EM1's Avatar
    millions
    Riversider
    Quote Originally Posted by MR.EM1
    millions
    dont listen to this guy
    But remember, what you pay is what you get. So if you gona go cheap, it wont last you long before you have problems. Good parts=good power good parts=last longer :idb:
    Middle Ga
    Quote Originally Posted by EF-9
    Just depends on what you want to buy. If you want to go the budget route, get the hf manifold, adapter plate and a t25 turbo or a 14b. You can go the ihi route, but eh there to small for my taste, and plus harder to find. Check ebay im sure you will find everything you need. And plus a less risk of getting scammed out of your money. I got scammed a couple times on HMT.com, just be careful.
    You don't have to get it tuned, if you want to stay cheap you can get a base map and just drive it like that. But I don't recommend it.
    JJSPEC Racing
    mr.slow
    lawrenceville
    Quote Originally Posted by WalkS
    yea i think ima go for the tunning
    i was planning on gettin the pipeping from ebay and dan just get a good turbo...would that work?
    Middle Ga
    That works! Hell remember I got my IC piping from home depot. The abs plastic has a higher melting rate than the pvc pipes, so I went with the abs plastic..LOL!
    JJSPEC Racing
    warner robins
    that brings back memories
    JJSPEC.COM
    Middle Ga
    Quote Originally Posted by d16_turbo
    Hell yea man! I want to do another one...but I rather build another little go fast setup again. I'm going to start on the civic again this summer
    JJSPEC Racing
    mr.slow
    lawrenceville
    wat are ur plans for the civic?
    oh and is a decent turbo i can go for?
    im trying to atleast go for 200hp for rite now...dan ima save money and build it so i can reach 300hp
    mr.slow
    lawrenceville
    was ur engine stock or built?
    how much hp did it have?
