Results 1 to 26 of 26
Thread: A quick paint job I can do myself
    Haters love to hate! nismo1987's Avatar
    Augusta
    Exclamation A quick paint job I can do myself
    Oh ok IA Just got a accord and paint job is not so hot rite now...... Its primer a light gray and dark gray and black on front end.... I wanna redo it myself... and I wanna go wit deep dark blue..... I had plan on doing it wit spray cans.... (I know it sound cheap but am a student ballin on a budget)... I been told since am going wit a dark blue I would need to go wit black primer... and I was thinkin since the car is two tone I would need to just over the whole car wit a black primer before I paint it.... But should I resand it than primer it again or could I just go on head primer it as it sits... Somebody let me know whats the best way plz out there its needing alot work asap.... Thanks IA
    Mane what a year it has been already.....
    GOOGLE is your friend
    Augusta
    Oh ok thanks for your help I am just lookin to see if anybody has done samething am tryin do on here but thanks again
    BMW 750iL
    Augusta
    Thanks
    chill six7teen's Avatar
    Columbus
    just wet sand the primer with some 400 grit before you put your paint on!
    Middle, Ga
    Quote Originally Posted by nismo1987
    Not sure if you know this, but you're not going to be "ballin" with a rattle can paint job on your car. Sorry, had too quote you on that.
    Hope everything turns out good for you though.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    You do know for under $100 you can get a gallon of real auto paint right?
    BMW 750iL
    freezrburn frostbyte's Avatar
    douglasville
    yes resand the car. wet sand it id ur broke, n out of a rattlecan ur not gonna really get a cheap ballin paint job (except the lil ball that makes it rattle). ur not gonna get the shine u think u will have. honestly, if its ur first attempt the primer will prob look better than the paint. if ur wantin it to be present able save for automotive paint, or try sanding it to the point ur happy n let maaco do it for $2oo bux is ur best bet.
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    Augusta
    Has anybody every try this rolling it on.... And how did it come out.......
    West Ga
    can buy a cheap spray gun at walmart for $20...
    Rolling works fine if you prep the car properly, apply the paint evenly and then wet sand it back smooth.
    i painted my car for about $150.turned out very well IMO and others for a hour or 2 of work.
    Just head to Finishmasters**AutoColor** in lawrenceville or chamblee tucker off 85.
    have them Mix up the paint for ya for prolly $70ish per quart and then get a gallon of clear with harnder for $60ish depending on company *my SMART clear was 66 and some change$
    if the car is primerd,you need to either sand it with 320g and go back over it with 600g..or like somebody said wetsand it with probably 600g also.
    then just go to town..I have a DIY on here from when i did mine.
    edit: found it
    DIY:Paint car for cheap-show car results
    Roll it on for $30, I did.
    Augusta
    So how long did it take you to do it?????
    Augusta
    Hey mane you car looks good.... What color blue you went wit there... And also how long did that take you???
    Quote Originally Posted by 1NonlyAccord
    edit: found it
    Cost me $120 for all the stuff needed to spray this truck but the compressor.
    BMW 750iL
    its called lamans blue met *sp?*..its a BMW color code.
    it took me only an hour and a half to spray it..but took me some time to buff it.wetsanded it by hand. if you use a DA itl only take another hr also.
    EE OG Revmaynard's Avatar
    Quote Originally Posted by X-Runner
    I think you got a little over-spray on the tire. lol
    Bozzio for president.
    You're not a very good example to use. Later, QD.
    JDM TYTE AnthonyF's Avatar
    You serious? DAYUM. Looks fuking hawt.
    -Ant.
    The Carbon Fibered R6
    The wind blew my cover off the tire. Painting outside FTL!
    BMW 750iL
    Just lightly dust them with satin/semi-flat black paint from a rattle can!
    Augusta
    Oh ok then.... Hey thanks 1Nonlyaccord for the DIY it was alot of help and your car turn out great mane....... I'll most likely go off of what you did.... But the rolling on I really don't know what much bout that..... I would really have to do that on a project car to see how it turns it out first..... But all you guys were a big help and thanks again.....
    Haha its been long enough its worn off now.
    BMW 750iL
