Results 1 to 27 of 27
Thread: da:cv axle advance auto quest.
    Chickens Eat Eggs
    south side hoe
    Default da:cv axle advance auto quest.
    this is for a 90 acura integra ls no abs 5spd :so i needed a passenger axle and i went to advance and the axle i had didnt match with the one they had, the grooves on the spine going towards the tranny on the old axle has a full spine and the advance auto only had half of a spine but everything else seems too look ok, so i matched it up with a driver side axle, and the looked identical ,so i bought the driveer side, the problem is when i was done putting it in and took it for a drive it dont want to make a full turn ...also i replaced my cable ls tranny with a 92-93 integra ys1 cable tranny(gsr,b16), im not sure if they have identical axles, and i know the driver side axle and passenger axle has to be differnet. and i jacked my car up and let the wheels spin freely to see if it was my tranny but it passed.. so my question is was the advance passenger axle the right one ?(jus a newer spine look) or is the a difference ls vs. gsr/b16 axles?, or did i go wrong somewhere when putting in the ys1 tranny? thanks ia i know its kinda confusing
    LS Resurrection
    Fulton County, Union City
    sup kev, uh well did you get a axle for abs? theres a big difference, and also i believe the axles for a gsr and ls are the same, if i'm wrong. you probaly got one for abs
    Chickens Eat Eggs
    south side hoe
    no i made sure it wasnt abs
    Cobb/Cherokee County
    if i understand right you bought 90-91 axles and tried to use em on your 92-93 ys1 transmission?
    90-91 axles are different than 92-93 im pretty sure
    you need to go get 92-93 ls axles
    Chickens Eat Eggs
    south side hoe
    hmm i thought 90-93 gs,rs, ls ,manual no abs are the same
    LS Resurrection
    Quote Originally Posted by laokid
    i thought so to
    alright i was wrong only difference is abs and non and since you dont have abs it shouldnt matter...but did read on g2ic.com that advance sells da axles that are a inch shorter
    Chickens Eat Eggs
    south side hoe
    send me a link
    just go to g2ic.com/forums and search axle problems
    Chickens Eat Eggs
    south side hoe
    ok so heres a picture of both of the axles i found
    Chickens Eat Eggs
    south side hoe
    when i pulled mines off they both look the same and the ones i have on now and before look like the first one, so did i have the wrong axles on the passenger side? because it rode perfect before when i jus had the cable ls tranny
    hmmm idk then
    Sandy Springs
    I dont really understand wheat youre saying about it not turning. Im not sure about the "half spline" thing either. Never heard that. But I can shed light on the axles.
    All 90-01 passenger axles are the same.
    All 90-93 drivers axles are the same. Only difference is the abs ring. Those can be easily removed.
    Chickens Eat Eggs
    south side hoe
    if u have abs and u use a non abs one then tthats a problem,but if dont ahve abs and u use a abs axle it doesnt matter
    correct
    Chickens Eat Eggs
    south side hoe
    so the axle on the top is the driver side and the other one is the passenger side..correct me if im right or wrong, cuz i dont want to take it off for nothing,
    LS Resurrection
    hmm, knocked it in all the way? if the axle is off even by a little bit, then there can be a problem.
    Chickens Eat Eggs
    south side hoe
    it goes in all the way but it has alot of play in it sliding back and fourth,thats why i was wondering if the inner shaft is suppose to be 1/2 or the full length, looks like the full length is the axle of the passenger side
    ccw replicas
    kennesaw
    god i should know this by now, ive done the same thing, i think the one on the top is the pass side(full spline) and the half spline is the driver.
    HF
    Chickens Eat Eggs
    south side hoe
    yeah i asked advance and they cant awnser the right quwstion
    Jonesboro/Stockbridge
    They can never answer the right question. They don't hire people with real knowledge of cars....just idiots.
    LS Resurrection
    Quote Originally Posted by JDM onlyy
    yup no knowledge at all. yeah you might have put the wrong side axle in lol
    Sandy Springs
    Are you saying that after you tighten the outer nut you can move the axle back and forth within the hub?? Like slide it in and out??
    Chickens Eat Eggs
    south side hoe
    Quote Originally Posted by Bus Driver J
    yes
    Sandy Springs
    If youre able to move the axle within the hub, that means the splines are too long. The nut should bottom out on the wheel bearing before it hits the axle its self. The nut is what keeps your wheel bearing from coming apart. Which ultimately means, they gave you the wrong axle.
    And in the pic above, Im gonna say the top one is the drivers side and the lower is the passenger. If you look at the half shaft, it as well has the half spline. The smooth part is where the seal rides. So half spline for the half shaft (right) and half spline for the pass (left).
    Chickens Eat Eggs
    south side hoe
    thanks for the info, but anybody knows for sure?
    General Tech Hater
    what he said..
    and to the genius who says abs and non abs are waayy different axles theyre not that different.. the difference is a small ring on the outer part of the axle that the abs wheel speed sensor reads of of, a non abs axle will work in an abs car, it will just throw an abs light..
    i personally buy all my axles from bumper to bumper.. and i always ask for NEW axles, not reman..
