Results 1 to 17 of 17
Thread: rebuilding a gsr with nitrous in mind
    dahlonega
    Default rebuilding a gsr with nitrous in mind
    i have a b18c that spun a rod bearing and i am about to rebuild it. the original plan was just to rebuild it back to stock but if i was planing to put it on a bottle is there anything i should do different in the rebuild process ? if it does go on the bottle it wouldn't be a huge shot, nothing larger then 50-75 max. i know zero about nitrous so any advice would be appreciated
    I've actually never gone out with a girl
    Quote Originally Posted by Stretch®
    Why does a dog lick his own nuts? Because he can. Later, QD.
    Quote Originally Posted by AllStock
    nice ride.. what doesss FTW! mean??
    slick fricks sikfricks's Avatar
    ROME,GA
    build it like your gonna turbo it low compression
    <img src=http://www.importatlanta.com/forums/image.php?type=sigpic&userid=19661&dateline=1274467236 border=0 alt= />
    Quote Originally Posted by sikfricks
    Why would you do that? You'll just end up having to spray more just to get it to run. The more compression, the less you're going to have to spray.
    Quote Originally Posted by efman
    Expand the ring gap accordingly. And if you plan on spraying a lot, don't use a moly coated top ring.
    Out the game again!!
    southside of the border
    lol nitrous loves high compression
    Soon!!
    dahlonega
    i'd i do spray it will only be like a 75 shot max so r there anythings that could use upgrades while i have everything apart
    If that is all you are truely going to spray, you really don't have to do anything out of the ordinary.
    dahlonega
    well i'm just now looking into it thought i'd ask just to be safe !
    the county
    have fun running a 17 sec 1/4mile.
    personally, i'd up the compression just a little bit, maybe a metal head gasket.
    is it a wet or dry shot?
    Stang Mod slostang's Avatar
    Southside
    75 wet shot on a stock gsr will be fine as long as you dont get trigger happy.
    Quote Originally Posted by srt4bangin
    correct
    Athens/Memphis
    I would at least get it tuned for spray.
    UGA: Everybody is laughing at us this year.
    Miss my Civic.
    Hit triple digits or shut up! 100 wet shot or bust!.....Kidding its your car.
    Higher compression, If you plan on going higher you want to get a nice set of rings! Head gasket and TUNE TUNE TUNE!!!!
    Oh yeah, also get a nice TUNE!!!!
    Don't forget to tune your car on Nitrous as well....
    Miss my Civic.
    Also. If Kevint707 comes in here and start telling you what you should get.....
    DON'T LISTEN!!!
    Im kidding Kevin.
    Anything above a 50 shot, a tune would be recommended. I believe the timing should be retarded by 1-1.5 every 50 shot of nitrous too. I'm not sure 100% about the internal work with pistons, rings etc but I do know that I'm running 10.5:1 compression CP pistons and I believe my ring gap is set to have a little extra space too; which explains why my motor burns about a 1 QT of oil every 1K miles.
    Quote Originally Posted by Sentra
    DON'T LISTEN!!!
    Im kidding Kevin.
    LOL ..
    Quote Originally Posted by KevinT707
    LOL ..
    The timing calculation isn't really accurate, but for that little amount of nitrous, that calculation should be up to par.
