Results 1 to 31 of 31
Thread: 21 psi on sohc 1.5
    center field
    Default 21 psi on sohc 1.5
    this is what happens on 21psi stock motor i.5 , 3holes and broke rod
    Attached Thumbnails Attached Thumbnails -damon-kmotor-005-2-jpg   -damon-kmotor-007-2-jpg   -damon-kmotor-007-2-jpg
    center field
    pic to big sorry
    typical of a honda...lulz
    duhhh bet it was stock map sensor too...
    Total Insanity helcat17's Avatar
    macon
    honestly i cant hardly tell what the pic is of its to big and distorted
    2009 Honda Civic
    2006 Honda CBR1000rr FS/FT
    http://www.importatlanta.com/forums/...d.php?t=211300
    macon
    is this the same motor that you were talking about that was suposedly "built for nas" in this same sections about 6 posts down?
    2009 Honda Civic
    center field
    no its not the same
    center field
    duh 3 bar
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    lol was fun though?
    R.I.P Booga
    M.A.P
    F.D.L.R
    center field
    YEAH Y IT LASTED
    well at least ya had a shot at making a pull w. the three bar..
    did you intentionally try 21psi or did it overboost?
    center field
    i swap the vacum on the waste gate and it went to 22psi , kinda did it on acident
    turbos
    I love carnage pics
    sux what happend but 1.5s are cheap cheap cheap get another one
    TOO BIG
    Certified Gearhead miro_gt's Avatar
    kinda silly that one spice can cause that ...
    dont you guy know about protections ?!?! I guess not.
    TT kte324's Avatar
    Oct 2008
    Columbus, GA
    I had a friend that did the same
    Sep 2008
    lithonia
    wow
    Slimm
    Texas
    Been there done that its awesome for that good 7 seconds then the car fill sup with smoke and your like shit. What the hell. My carnage was close to the same but mine was 16 pounds on stock 1.5.
    Atlanta, Ga
    Jesus christ.
    Thats some kickass carnage. How long did it last?
    Alpharetta, Ga
    Quote Originally Posted by seanrg1116
    I love carnage pics
    me too
    get another and do it again but get it on video next time.
    The G Spot Hero
    Quote Originally Posted by LiLJames93
    don't forget on stock mapsensor tuned to like 10-11psi. lol
    140 on one wheel
    columbus, ga
    how many of the sleeves did you split? SEVEN on here said no b or d series can run more then 11lbs on stock sleeves quoted from his race shop or the sleeves will split!
    Quote Originally Posted by -S Double C-
    i've had a few b-series stock sleeves 500whp +/- and d-series 300-400whp. with the exception of b20 i would rate b/d series sleeves easy at 400 and i used to say 500, but the longevity at 500 is somewhat questionable.
    maybe he meant stock internals (pistons/rods). depending on the turbo/flow 11psi could be a reliability estimate he was making or talking about the stock mapsensor. certainly if you push more than 11psi through the stock mapsensor that's only been tuned to 11psi could cause a sleeve to go if you push 17psi at fuel and timing of 11psi (way too lean and way to much advance).
    140 on one wheel
    columbus, ga
    I know scotty, i was joking except about the part seven said its was true lol
    You tuned my car on 18lbs and its stock other then vitara's arps head studs and fjt rods.
    Quote Originally Posted by se7en
    www.d-series.org
    professional race engine shop
    http://www.eddiesvalvegrinding.com/honda-sleeving.htm
    Exospeed
    http://www.clubcivic.com/board/showthread.php?t=36356
    notice in both of the links provided they mention tuning as the biggest factor. Who tuned yours?
    -jonathan
    UANEKNO Bridged's Avatar
    Columbus, Ga.
    Se7en doesn't know anything, he just reads everything on the net and thinks his smart. Everyone knows everything on the internet is true!
    Certified Gearhead 4eyedbox's Avatar
    ATHENS
    Nice destruction you have there.
    If ever you want to try for maximum destruction, you should attempt to see how large of a nitrous shot you can run on a 88-91 D15 dual port with only retarding the ignition. Its fun for a while, but you eventually get tired of swapping engines out.
    Its slow... I promise
    Quote Originally Posted by Bridged
    ^ that reminded me of someone here....
    /Oo ___A___ oO\
    |=_/_______\_=|
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    lol i wonder how it felt before it blew... i wouldnt do it just bc i wouldnt want to pay for a tow truck... lol
    buford,ga
    thats awsome. all i can say
    94 si h23a1
    GPC member #2
    I ran 14-16psi on my d15 for a few days trying to blow it up on stock MAP with a turboedit basemap a few years back lol. Damn thing finally just started using so much oil i took it out and threw my new engine in.
    you dont need to know
    it lasted for a good 20 sec and it sounded like a jet taking off.
    f*ck off
