Results 1 to 40 of 54
Thread: How to be SLAMMED without RUBBING: An informative guide to fender mods on most Hondas
    Grocery Getter GetFRESH!'s Avatar
    Columbus
    Default How to be SLAMMED without RUBBING: An informative guide to fender mods on most Hondas
    Ok, so after getting many PM's inquiring on how I rode so slammed and claimed to do so without any rubbing... I've decided to do a write-up on what I did to modify my front fenderwells in order to achieve lock-to-lock turns with no rubbing at absolute dumped status . Anyway, here's a rough step by step guide on how to rid your ride from the dreaded rub. I know for sure these tips work on Civics and Integras from 1992-2000. Much older or much newer vehicles may have slight variations, but I would guess not by much.
    Also, if a mod could please make this a sticky, I'd greatly appreciate it.
    I'll try to make this as understandable as possible. lol. And maybe sometime I'll get around to taking some pictures to help further explain these steps.
    Tools needed:
    Dremel tool (very helpful, but not 100% necessary)
    Sheetmetal shears (common type w/ yellow handle)
    Big fucking hammer (metal head type. You won't get far with a rubber mallet)
    Flat head Screwdriver
    Razorblade
    First thing's first. Do you have fender liners? If so, do you want to keep them? If you don't, doesn't matter. Just a lil less shit you gotta do. If you do, once you jack up the front end and remove your wheel, you should see some of the fender liner that's already been rubbed through (one spot closer too the front, one spot closer to the rear). Using the dremel (or sheetmetal shears), cut out ONLY the upper middle section of liner where it's been rubbed. You may need to pry off some of the clips that attach that section of liner to the inside of the fender well with the flathead screwdriver in order to remove section. When finished, the front and rear sections of liner should still be intact and attached and look completely stock and unmodified when car is dropped back down to normal height. Be careful not to get any of the plastic shrapnel discarded from the dremel on your skin cause that shit will burn the FUCK out of you and make you want to go inside and watch TV instead of working on your car. lol
    Next, you'll then see the exposed culprit of what's causing your rubbing when you hit bumps and such... that damn pinch welded sheetmetal body seam that sticks down about 1/2". Using the sheetmetal shears (or dremel if you have a GOOD cutting disc), cut slits in the thin areas along the length of the seam (you'll know what I mean when you see it) every 2-3 inches or so.
    Then using the big ass hammer, hammer the lip flat up against the frame. Make sure you hammer it BACK TOWARDS the fender and not towards the strut assembly or your upper control arm will get sutck and it's just a big f-ing mess that you will NOT want to deal with at this point.
    Once flat, inspect the curcumference of the actual fender arch in and along the inside and you should see where it's been rubbing against the lip where the liner attaches. Holding the flathead screwdriver HANDLE in both hands (tip pointing down towards the ground), with your thumbs pressed against the outside painted part of your fender, fold the lip inwards so it sits flat and flush against the inside of the fender. This is a BIG pain in the ass and requires a bit of elbow grease, but it's the best way to not crimp and wrinlke the fender, as using a pair of channel locks or a hammer will do. Do this slowly and you shouldn't have any problems with the paint chipping. If you see some paint start to buckle, run the razorblade along the circumference of the fender arch, so if paint should chip, it will stop at the cut before it reaches any visible point on the outside of the car. Your tire really only rubs on two points of the fender (which you should see due to those two spots being rubbed down to bare metal) one closer to the front, one closer to the back, so try and get those points really flat... and try pulling outwards on the fender arch (gently, but with enough force to actually do something) to squeeze a few more millimeters of clearance away from the tire. Every little bit helps. As stated above, refrain from using channel locks or vice grips to pinch the lip down, or a hammer to knock it flat, 'cause you'll just end up distorting the shape and body line of the fender.
    Lastly, check around for any other spots on the inner fenderwell that's been rubbed to bare metal. If you don't have a super wire-tucked or shaved bay, you can get away with tapping on the rubbed sections with the hammer, "pushing" those sections inward towards the bay. I did this on my brown coupe and it was nearly unnoticeable from the enginebay... and nobody can see behind your wheel anyway. It'll cut down a lot on scrubbing with high offset wheels, due to a higher offset placing the barrel of the wheel closer to the inside of the fender.
    DONE!
    Remember, wheel/tire combination has A TON to do with how much you scrub... not just height... plus of course camber and offset come into play when you get this low. Here are some examples of cars I've done these mods to and how LOW they can be with NO rubbing whatsoever:
    **bonus tip for preparing fenders for extra gangster wide/low offset wheels**
    If you're planning on running any sort of wheel wider than 7" with an offset of any lower than +30, you'll probably be needing to do some more drastic modifications when being slammed. To do so, start by having a buddy nearby cause this is a two man job. Have one of you get into the car, in gear and ready to drive forward. The other needs to have that big ass hammer ready. lol. Hold the head of the hammer in both hands and place the handle between the tire and fender arch where they meet (near the back section... just imagine if it were a clock it would be around 8 position). Have the friend drive forward SLOWLY as the hammer forces itself to be sandwiched between the tire and fender. Gently "see-saw" the handle towards you and away from you forcing the inner lip on the fender to flatten out towards the inside and slightly "pull" the arch outwards. Reverse the process slowly once hammer is run all the way through. Please take notice of paint and if any chipping occurs, run the razorblade along the arch of the well to take care of that. I hear a heat gun works just as well (or better), I've just never used one so I can't say. Also be VERY CAREFUL to not over do it and start buckling, crimping, or distorting the natural curvatures and bodylines. It is meant to be a subtle, slow process that within time stretches the metal outward and away from the tire.
    Indeed there are more (and probably better) ways to go about doing these steps as I've stated I'm sure... and if any other people have any recommendations, tips, or shortcuts, please by all means DISCUSS and POST THEM!
    Disclaimer:
    Also please notice this is intended to be only a guide on what I have personally done to my own cars. Use your own descretion when following these steps and again, DON'T OVER DO IT! This is only meant to be a means of a quick and inexpensive way to cut down on some of those annoying rubs and scrubs everytime you hit a bump or make a turn. The "right" way to roll fenders, as always, is to rent a fender rolling machine, or to get it professionally done. I can not take responsibility for mistakes, mishaps, or misjudgements on your part which cause any damage to your vehicle. Just be smart about this people.
    Good Luck!
    my momma's house
    GOTDAMMIT BOY, PREECH!!!! We must be related.
    I've been in a funk cause of my recent "steelie whoes"", and tryna ride KKKlean... you've just woke up my inner dumster.
    Dump.Hard.Or.Go.Home...
    The End.
    Trend settin'
    the duckster
    Rome
    this should be stickied
    Race Ready Developments Member #5
    Rome Crew
    Jonesboro/Stockbridge
    nice, my friend taught me this. but i can't ride that low. lol but its great for people who want to!
    Senior Member Nang's Avatar
    if you aint smashin up oil pans, you aint LOW!
    2 down!
    J.R
    Down South
    very interesting man, looking foward to seeing da pics
    LS Resurrection
    Fulton County, Union City
    yeah i took my fender liners off and its not scratching any more
    revolution big mac's Avatar
    you should do a write up with pics man
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    Nice writeup!
    reps
    It looks like you just use really small wheels so they aren't wide enough to scrap the fenders. I see wheel gap.
    blank
    nowhere
    u guys should try being slammed on 17s with +25 offset and 215 tires no camber kits. do work!!!!!
    한 국
    DUH-KYOO-LUHHH
    why in the hell would you want a car THAT low?
    ESPECIALLY a honda with high offset wheels?
    West Staines
    Good shit Andrew!
    now you just gotta let out your secret on how you get that low period!
    BTW! LOVE the new name!
    Hwy 315
    lol, even if you're "slammed" on 17s your car is a mile off the ground.
    -jonathan
    [/URL]
    Jesus Christ is my Savior
    Texas
    ^^^^ gotem.... and i still have my inner linner...
    San antonio 210
    Quote Originally Posted by Thighs
    Looks I guess ! !
    Hwy 315
    A couple tips from se7en: (since andrew asked for input as well)
    *Trick #1
    the infamous "fork trick" that can be used; a picture says a thousand words:
    in essence, you are pushing the damper further down into the fork, you want to be careful when doing this as to not place it too FAR down as it may come into contact with your axle - no bueno.
    *Trick #2
    EF front forks (and dampers) on a 92-95 civic - they're shorter... by about an inch - and will bolt right up. This will decrease the overall length of your LCA - Strut Tower length and will instantly lower your car about 1".
    *Trick #3
    skinny tires, smaller rims - get the 40 size sidewall instead of the 45 or 50, get the 15" wheel instead of the 16" if it's that important to you.
    *Trick #4
    trim a hole in the strut tower - I'm not recommending doing this, as it can definitely take away from the structural integrity of the car. But at least your A-arm wouldn't smash anymore.... right?
    *Trick #5
    get some stiff springs... and I mean stiff. What? Your Omnis have 10k front and 8k rear? try again - those rates come out to 560lb front and 448lb rear, which means that your suspension will move too much for typical daily stuff if you're wanting to ride low. My current setup uses 18k front and 12k rear - 1012lb front 674lb rear... yes, the car rides somewhat stiff, but to those who have ridden in it since i installed the new stuff, all sing the rides praise. I never bottom out, and the car handles well. And dang there were a lot of commas in that last run-on sentence.
    *Trick #6
    negative camber can be your friend - to those of you who want to ride slammed and be able to turn... prepare your wallet for lots of new tires.
    a couple of pictures for my "resume of accomplishments'" for cars i have owned and considered to be "slammed." Sorry if they're a tad to large, I'm not feeling like resizing these.
    the current configuration - with now different wheels/tires:
    and there you go
    -jonathan
    [/URL]
    ALL CAPS JITB's Avatar
    im gonna buy all b/d series oil pans and sel them for crazy jdm prices.....
    Southside
    Fawk'n Nice
    West Staines
    i fuckin love you Jonathan.
    im like your BIGGEST groupie!!!
    Columbus
    I see wheel gap.
    wow.
    funniest thing I've heard all day.
    Why the hell does anybody do anything to their car?
    Let me put it to you this way:
    Now, the world don't move to the beat of just one drum,
    What might be right for you, may not be right for some.
    A man is born, he's a man of means.
    Then along come two, they got nothing but their jeans.
    But they got, Diff'rent Strokes.
    It takes, Diff'rent Strokes.
    It takes, Diff'rent Strokes to move the world.
    Everybody's got a special kind of story
    Everybody finds a way to shine,
    It don't matter that you got not alot
    So what,
    They'll have theirs, and you'll have yours, and I'll have mine.
    And together we'll be fine....
    Because it takes, Diff'rent Strokes to move the world.
    Yes it does.
    for diff'rent folks man.
    Good shit Andrew!
    The secret is... learn to deal with your car riding like complete shit!
    Nah but for real, none of those cars ever really rode "great" by any means... but at the time I wasn't really worried about ride quality, just wanted to be low low. Now I'm spoiled riding on these Buddy Clubs so no more dumped status for me. Actually I've been getting more into the look of slightly higher stances (yesh, I know... BLASPHEMY!!! lol) but man you just keep doin yo thang and keep it pimpin close to da earth! Cause that's the D.O. way!
    Oh and thanks Jon for your input
    I knew of all people you would have a book's worth of knowledge on this topic. lol.
    Honda Saved My Life Jiggity96's Avatar
    Dec 2008
    Henry County
    ^^^^^repps if only everyone else on this site could understand
    JIGGITY96
    Middle, Ga
    I'm not going to lie, I love the way Honda's look slammed on some nice rims... But for a DD, this is a bit extreme. I kinda like the low but not to low aggressive look after a 3ish inch drop and a mean set of rims. But awesome write-up and tips from Seven.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Quote Originally Posted by GetFRESH!
    wow.
    ...Explain....the wheels on some of those cars look sucked in. What's the point?
    Columbus
    vs.
    I though you meant height, not distance from wheel to fender.
    But I too hate the "sunken ship" look. I just had the silver coupe and red integra each for like 2 months each so all I did was dump them on whatever wheel it was on. High offsets on OEM wheels ftl.
    Texas
    ya whats the point of being slammed anyways. Thats stupid I think that is the biggest waste a money you could throw at a car. I like my car high thats why I ride like I do, Lemme show you what I roll in. nice and smooth
    Hwy 315
    yeah, definitely not your car... Lol
    -Jonathan
    [/URL]
    Good write up man. I do ask you what you think "absolute" status is.
    I've ridden on true absolute slammed status for over 20 years, with no fender rubbing problems. But that write up should be good for folks that may need it.
    There's more than enough stickies as it is, man. Later, QD.
    Quote Originally Posted by se7en
    *Trick #1
    *Trick #2
    *Trick #3
    *Trick #4
    *Trick #5
    *Trick #6
    and there you go
    -jonathan
    what is your current setup if i might ask????
    Columbus
    It's just a turn of phrase man. Nothing really absolute about it. lol. Just a way to say I was at the point where going lower would have been stupid. It's more relative I guess.
    Gotcha. No biggie.
    'Round These Parts
    Hondaz, there everywhere in this thread!!!
    Don't think i'll ever stop liking 99-00 Civics!
    nice Tucks!
    Leisa and S. 4 Life NM?
    i believe the most common rear shock idea hasnt been brought up
    or it might have, but i didnt read every reply lol
    cutting the spring seat on the rear shocks, so the coilover sleeve can go lower...Johnathon you can make another cool diagram if j00 know what im talking about
    West Staines
    Quote Originally Posted by rhd_civic_ej
    oh shit. i think you right B. its funny because Andrew (the OP) had that done to all of his setups if im not mistaken
    i know for a fact that that was the case on both the EJ's
    pics of this, my rears are not going down anymore
    I like steak Dirka Dirka's Avatar
    westchestertonfieldville
    God i love you man! lol. I was just thinking that but you beat me to it.
    I know im the man, ill be doing this, this weekend if i can find the right cutting disc for my dremel tool. It works great, and major ass slammage in the rear
    Quote Originally Posted by Dirka Dirka
    I know I know, you can pay me this weekend :boobies::idb:
    IA's Pedo-cord tdurr's Avatar
    Fayco
    /subscribed. I vote for sticky!
    Save ur engines!
    Quote Originally Posted by Nang
    and the answer for you is here
    ^ You want to cut that piece in pink. BUT i would leave about half inch to a inch lip, cause you dont want the coil sleeve to slide off the edge if it was cut even.
    and another trick (think) for all the da, and 92-95 guys, you can use 88-91 crx rear shocks, they have a shorter body and give that little bit more slammage. Ek guys can use them to, but i think you have to use spacers.
    so what is shorter in the front between ef an eg/dc? the shocks or the fork? or both
