Thread: toyota question?
    LAWRENCEVILLE
    Default toyota question?
    Does any one know if a 93 tercel engine is the same as a 94 paseo? do they interchange?
    Hella stock member!
    LAWRENCEVILLE
    anyone?
    Hella stock member!
    Mountain man green91's Avatar
    Dahlonega, Ga
    Gimme a sec, ill log onto my TIS account and see what the engine codes are.
    Dahlonega, Ga
    Okay,
    the 94 Paseo has the 5e-fe
    the 93 tercel 3e-e
    Im going to guess they aren't direct bolt in interchangable based on them being different engine generations.. is very likely possible with some wiring/ecu change they would work.
    Before you spend money on an engine, also get out the jdm 4e-fte swap.. they are pretty inexpensive and a neat turbo swap for either of those cars IIRC.
    LAWRENCEVILLE
    thanks for the info!
    Hella stock member!
    Dahlonega, Ga
    Not a prob, being a toyota tech has its benefits sometimes (access to repair info system)
