Results 1 to 40 of 42
Thread: A common NOT so common problem?:
    Senior Member rbf's Avatar
    Sep 2008
    Augusta
    Default A common NOT so common problem?:
    Well after 9 years dealing with the 88-91 civic/crx chassis I have only twice come across this problem and or have heard of it.It is the rear cross member where the rear motor mount bolts down.It seems some how they become weak and start to rip apart where the bolts thread down?.
    The first time I came across this problem is @ the beginning of 2008 when a friend purchased a cr-x off of here for a project.The rear cross member had been destroyed and the owner before him tried to weld it back up?.But it was useless none the less,The other time I seen this problem was on Honda-tech where they claim it to be a common problem for the ef?.Has anyone came across this personally or have heard of this problem @ all w/our chassis?.Maybe w/some rust damage I can understand it causing this but not to sure what else really can cause this unless your running busted up oem mounts since 1988 or whatever and they all pretty much have lost all the rubber?....Anyone consider this a common problem? or maybe just common if you do not have decent mounts?.
    Here is a photo of what I am trying to explain.[not mine]
    In the photo the bolts seem fine but somehow still damaged from maybe the mount was wedged up agaisnt it?.
    Hamilton, GA
    Yup mine looks like that lol
    Don't know why though
    Sep 2008
    Augusta
    Quote Originally Posted by T2KU
    it is just crazy..
    DUH-KYOO-LUHHH
    thats not good. lol
    i havent heard of it but then again i havent messed with EFs much.
    Sep 2008
    Augusta
    Quote Originally Posted by Thighs
    thats not good. lol
    So no one else has had this problem?.
    EE OG Revmaynard's Avatar
    Never looked into it on my car.
    Bozzio for president.
    Southside of The Jungle
    Wow
    Senior Member sakasaku's Avatar
    Marietta, GA
    i have one of those sitting here at the house if you want it has no rack in pinion though, the bolt on one of the lower control arm i believe its seize or just really stuck cant remember
    Lurking
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Its a common problem on high powered drag cars with swaps. I believe its due to using 3 mounts rather than the original 4 mounting locations. A more common problem is stretching the forks where the lca connects to the cross member. That's due to hitting curves and pot holes.
    Hamilton, GA
    Mine was like it when I bought it. I'll have to be careful when I boost it again I guess. Not planning on doing many digs though.
    Ohio asshole.
    Yep lol. That 4th mount makes a fairly big difference in support. When I pulled the boosted motor out of the CRX I noticed it was like that. I made sure to check the one in my new car before putting the motor back in. I think the person I got the Hatch from, must've had the same problem, and just bought a brand new one.
    I'm on my way to the garage now to fab up a forward motor mount for my car.
    Your mom's bed
    it's from all that mad crazy B16 TQ
    Sep 2008
    Augusta
    It has to be because of alot more than not using all mounting locations w/a drag car?.Seems to happen on alot of Dseries ef's ahhahaa and we all know that is no powerhouse!.But anyone who does not buy good mounts when doing a swap w/more than stock hp isn't too bright.We used Innovative 95a on the cr-x swap that was sold on here.The car came w/a nice torn up set of Yonaka's ahhahaa.But I guess you get what you pay for?.You buy quality parts and do everything correct it last and performs great.But if you buy cheap stuff and or install things rigged up you eventually will know what failure is.
    Still this problem too me can not be so [common] a real common ef problem would be maybe the relay or something that happens alot! not twice.
    Sep 2008
    Augusta
    Quote Originally Posted by 00CelicaGT
    you better believe it.
    what time is lunch?
    woodstock
    I've heard about that with b series engines. not d series.
    I'm running three mounts in my civic with a b and 4 mounts in my rex with a d.
    Sep 2008
    Augusta
    Quote Originally Posted by rbwdriven
    I say when running [higher] hp/trq engine swaps might as well buy a nice tractionbar that allows you to use a front mount as well.Add this w/a nice stiff set of mounts and there is no way this could happen.
    I know ESP has a nice kit for ef's:
    San Diego, CA
    89 CRx Si, 173K mi, purchased as shell, had d-series in it before I got it.
    91 Civic hatch 212K mi at time of sale, had d-series until it hit probably 173K mi, then went b18a1
    90 Civic hatch, 128K mi at time of sale, had d-series, currently owned by Saka
    None of the three have seen that problem. It's gotta be due to the extra pull on the mounts that a turbo leaves. My LS motor was stock, but it's known to be a more torque-y motor.
    JDMadness ==> EvasiveEF9
    Hamilton, GA
    Might have to invest in a new piece next year
    Sep 2008
    Augusta
    Quote Originally Posted by EvasiveEF9
    Yea I have owned many many ef's and none had this problem.B16's/B18's/Dseries and still nothing.Maybe the problem is the owner strips out the rear mount threads or maybe cross threads it and eventually causes it to fail? I have no clue how but can agree more powerful swap could be the cause but what is the excuse for a Dseries or a rather stock B16?.It really is all too crazy.ahhahaa
    San Diego, CA
    Quote Originally Posted by iHATCHBACK™
    Well, no, cuz it's not the teeth slipping out of the mount. It's literally the mount coming apart. The ONLY thing I could think of being user-mechanical error is if the bolt is not fully seated in there, and the female end of the mount is literally ripping in half from not all the teeth being seated. But it would only make sense if it happened once, maybe twice. But if several people are having this problem, this leads me to believe 1) there's alot of dumb people in this world (which I truly do believe) or 2) the car just wasn't designed to have a b-series without a b-series rear xmember like in japan.
    Hamilton, GA
    hmmmmm....JDM rear crossmember...
    I'm gonna price a USDM one tomorrow
    I guess since I have the super duper B16 I can't complain too much
    San Diego, CA
    Easy.
    1) Look for someone who's replaced there's with aftermarket stuff (dare? Jfro?)
    2) Check a salvage yard
    3) Look around for part-outs
    4) Check HT
    EF Enthusiast jfrolang's Avatar
    far far away
    I have seen this problem a handful of times in the last 7 years or so. My hypothesis is that it's caused by large engine movement, so someone with a swap that overpowers their front and/or rear mount could have some trouble. This includes people that have stock engines with totally shot mounts.
    There is no aftermarket rear crossmember that I've ever seen, so stock is the only way to go. JDM would not be compatible unless you were doing a RHD conversion.
    San Diego, CA
    Quote Originally Posted by jfrolang
    I meant the...LHD...JDM one... Yeah...
    See, that's why I ask JFRO and dare when it comes to shit I'm not sure about...LoL
    Sep 2008
    Augusta
    I agree.We use correct mounts and never have this problem.
    Hamilton, GA
    I work at Honda so I will get their price on one
    Sep 2008
    Augusta
    Since you work @ Honda can you confirm something for me?.I was told if your Honda seat belt is faulty they will replace it for free on any chassis?.
    Ohio asshole.
    I'm running Hasport mounts that are 100% tight. Slamming gears in Vtec on a b16 or GSR will do it no problem. The rear member is 1/8" steel, with "nutserts" basically welded on the inside. Not much support there what so ever.
    I greatly doubt in most cases that it's user error. I'm sure in some where people are to lazy to try and get that rear bolt tight they leave it loose and the vibration and the mount slamming down will cause it.
    Most of the time its due to the fact that your driving an Econo-box that you've upgraded to make more hp/tq and its not built to take it. Sure, the car will be fine for a while, but eventually things are going to break.
    Its a fairly simple thing to avoid. Make sure your mounts are tight, and it'll last for quite some time. Add the 4th mount, and it'll last even longer. It's by no means hard to run a 4th mount, even with the stock cross member, if your able enough to fab it up. A lot of people aren't, most of those people tend to have money so, go out and buy a traction bar lol.
    I'm also planning on switching to Innovative mounts, or atleast the innovated rear mount. The Hasport mounts only use 2 bolts to hold it to the cross member, where the Innovative use 3. Using more surface area will help support. I don't know if the aluminum Innovatives use three, but I know the steel set does.
    Ohio asshole.
    Same question lol. I've never heard about it, but if this is true, i'd like to know because my drivers side doesn't reel back in.
    Sep 2008
    Augusta
    Quote Originally Posted by jmmx258
    Innovative mounts are the best!! until you go h/fSeries into ef then ESP.
    Ohio asshole.
    No way, the Hasports are way more shiny!!! lol
    I really like the Hasport mounts, aside from their rear mount. They're very high quality, and CNC machined out of billet. Of which is far better than anything aside from say Ti or Mag. mounts lol
    Sep 2008
    Augusta
    But Innovative has bronze anodized billet mounts!!!!
    hahahahaaa they are sweet.
    San Diego, CA
    If you work at honda, you've got the hookup with discounts, but you can STILL get a better deal (moneywise, maybe not always value) if you get one used.
    San Diego, CA
    Oh, and I had another theory, today...
    This is gonna blow ya'lls mind...
    ...shift more smoothly. Don't slam gears unless you have to. You've gotta pay to play...
    Sep 2008
    Augusta
    There honestly is no reason to actually [SLAM] the gears,a quick shift does exactly the same as if you do a [POWER SHIIUUFFTTTT]
    San Diego, CA
    ...ok jackass...I was exaggerating...
    LoL.
    Best mod you can do to a car is a driver-mod.
    Sep 2008
    Augusta
    LoL.
    No jacka** here just a sense of humor It was simply a joke.
    [from a vid on lolHonda.com] it is hilarious.
    San Diego, CA
    I just realized how new you are to the forums here on IA. I've got a good sense of humor. Usually quite sarcastic. It'll be rare that you should ever take what I say seriously.
    Sep 2008
    Augusta
    Naw I have been on here since 2003,just have a new name.2 other names before this one.
    But it's cool I didn't take the last thing seriously I just didn't want you too and think I was being a [d*ck] w/my remark about powershifting hahahahhaa.
    San Diego, CA
    Nah. The only dick is JDMJAY. We used to be cool, but he doesn't talk to me, anymore.
