Results 1 to 24 of 24
Thread: HELP!! I have no reverse.
    South Side Georgia
    Default HELP!! I have no reverse.
    My B16 Tranny is acting up, it wont go into reverse. It doesn't grind in any gear it just wont go into reverse. When i was doing my swap i put two quarts of synthetic 10w40 and bout little over half of lucas tranny fix. Whats wrong?
    resize pic
    Your tranny is blown
    Norcross
    sometimes my car wont go into reverse either, and i have to mess around with the shifter and the clutch a little bit and it goes in
    turbos
    Quote Originally Posted by j0nbunklah0m
    mine does the same thing.............damn hondas
    TOO BIG
    Streetracer101 Ajdgotskillz's Avatar
    Marietta,Ga
    my accord used to do the same thing i took it in and it needed a whole bunch of new shit for the tranny so i traded it and bought a new car.
    Super Ghetto Rally Team EP3sAreFun's Avatar
    Barrows
    Quote Originally Posted by gerardojdm
    you put 10W40 oil into your transmission?
    Quote Originally Posted by EP3sAreFun
    yeah that's what I'm thinking, I use 80W-90 in my tranny and diff.
    VTECKLR amped4life33's Avatar
    Rome Ga
    Revers is over rated anyway...
    **Original photo by CF Photography**
    Barrows
    Quote Originally Posted by 87 Turbo II
    lol yeah...
    Original Poster put ENGINE OIL in theTRANSMISSION.
    that is why your transmission is fucked. you are going to need to rebuild/replace the whole thing.
    Senior Member jfman's Avatar
    Can you shut the car off, put it in reverse and the start the motor and have reverse?
    lmk
    IA Member blumagic04's Avatar
    somewhere
    lol yeah...
    you might not have to take it as far as replacing or rebuilding.... just drop the tranny and get some degresser and wash the tranny down reall good, put it back in and use the right stuff.....
    going from first to reverse (not in motion obviously)
    - IA Mgmt
    Senior Member 9ussy's Avatar
    use honda transmission oil next time..
    89 240 rmeyer114's Avatar
    Oct 2008
    snellville
    damn thats dumb who puts engine oil in a tranny
    95 mk3 jetta celebration edition
    -Rob-
    Wheres the money?
    McDonough
    10w30 is in mine and it ran fine
    to many projects not enough money
    Barrows
    Quote Originally Posted by tank500999
    you are running the wrong viscosity oil. go fix it now.
    North Augusta, SC
    I use 80w-90 in my engine...
    But hopefully it won't cost you too much to rebuild/fix the problem...
    Back to being stock and slow
    dteng Homer Simpson's Avatar
    Evergreen Terrace
    get some GM synchromesh and call it a day.
    thats what i put in my car and it does miracles.
    Long Live GM! :^o
    Alpharetta
    Run some water through the tranny to flush it out...
    Just kidding...seriously, though, drain the 80/90 out...refill with Syncromesh ($9 bucks a quart), row through the gears for about 15 mins or and do it one more time.
    Lucas is not meant for manual trannys btw...80w90 is meant for rear ends/transfer cases. I've never seen a manual use 80/90.
    And yes, you are supposed to use motor oil (5w20 if I'm not mistaken for Hondas) if you do not have the correct manufacturer specified -MANUAL- transmission fluid. It stated in the manual...Honda, do not use any additive in their gear lube, specifying regular motor oil until recently, and now their own brand of gear lube which seems to be an enhanced version of motor oil.
    Do this...with the car off obviously, see if it will go into reverse. With the clutch down, start, see if the shifter forces itself out of reverse. I don't think Hondas have a reverse switch so it should start in reverse with the clutch down. If the shifter doesn't budge, simply see if will pull itself (or push) without any additional throttle. If the shifter forces itself out...you need a new tranny.
    I know the thread date is old...but I want to clarify that motor oil is the correct fluid for a Honda transmission and my other manual trannys out there.
    Macon
    Quote Originally Posted by rmeyer114
    You're an idiot. Honda manual transmission's can use anything from 5w20 to 10w40. Do not put gear oil or higher weight transmission fluid in a B series tranny.
    Damn thats dumb, Who replies to a thread and doesn't know what the fuck they are talking about?
    As for going into reverse, try putting the shift lever into 4th gear first (do not release the clutch), then go into reverse. My GSR, civic, prelude, and CL type S 6 speed all did the same thing from time to time. I haven't had a honda that didn't do that.
    Land Rover LR3 HSE
    all of you thats dogging dude fr using engine oil are the idiots. like last dude said, honda manual trannies take engine oil. my factory shop manual says use 10w30.
    know ur cars before trying to bash somebody thats asking for help.
    If u put the car in 1st gear, move it forward a couple inches then try reverse does it work?
    Hmm....ShakaLock??
    NorthSide Red Rider
    HOLY SHIT THIS IS SOME SERIOUS BIZNESS!!
    Quote Originally Posted by KIZDAWAY View Post
    Sounds like a date, wear some make-up cuz dis will be in HD. I'll bring da K-game, so you better be on race fuel cuz you'll need it. :boobies:
    Quote Originally Posted by Glides View Post
    This whole, "It's just the internet" is just dumb. If that's the truth then the person busting you in the face for running your mouth can say, "It's just 5 cross yo lip dude, don't take it too seriously"
    General Tech Hater
    Quote Originally Posted by allmotoronly
    you also beat your cars into the fucking ground, thats why they did it..
    and yes 10w30 is specified in the honda owners manal to use temp. if you can not use honda MTF.
    Barrows
    lol alright i'll admit. Since i've never been into Hondas i was not aware. but thats weird. any reason why you have to run such a thick oil? what makes the honda transmissions so special?
