Results 1 to 23 of 23
Thread: y1 tranny fifth gear question
    Default y1 tranny fifth gear question
    i'm looking still online but i figured i would ask while i look, i drove my friends ef with a b16 today and it seems like it hits vtec around 4600 with the j1 trans in it. So i'm wondering is it going to be the same with my y1??? because i couldnt do over 65 on the interstate with out whailing away at the vtec. is it okay to drive with vtec engaged constantly like that or do i just have to go 65 everywhere. anyone ?
    straight ninja mode EuroTra$h's Avatar
    canton
    my buddy has a eg hatch and hes in vtec all the time i dont think it will hurt anything but im not super sure
    Hamilton, GA
    your trans has nothing to do when VTEC engages
    it will hurt your gas mileage though if you are in it all the time kind of like a turbo
    I'm at 4700-5k at 80mph,and stock VTEC engages at 5k but I bumped it up to 5500
    All Motor EK N/A EK's Avatar
    On IA.com
    MIne is a 5k at 80mph.
    Quote Originally Posted by T2KU
    How did you bump it to 5500 that's where I hope mine is
    Southside of The Jungle
    Quote Originally Posted by jriley60
    chip the ecu ! and yes with b16 trannys you really cant go that fast with out being in vtec.My friend has his vtec at 5500 but with stock p28 at like 75 -80 hes in vtec
    so is it bad for the car to be riding for an extended period of time in vtec?
    EF Enthusiast jfrolang's Avatar
    far far away
    bad for the engine, no. It's just an oil pressure activated pin and larger camshaft lobes.
    A chipped OBD-1 ECU is the way to go.
    Hamilton, GA
    I have a phearable chipped p28 and converted to obd-1
    you tell them whatever you want and mods you have and they send you an ecu
    far far away
    A basemap is no substitute for tuning.
    ls/vtak slut! SlamminCRX's Avatar
    Hinesville/Savannah, GA, Orlando, Florida
    X2..
    Hamilton, GA
    Quote Originally Posted by jfrolang
    true but I'm not tuning my low compression b16
    When I told phearable my mods they were like "huh?"
    well i really can't think about converting to obd1 right now although it's a maybe for the future. i've got a long way to go till then though. on a good note motor should be finished real soooooon like tomorrow i hope
    Hamilton, GA
    Cool g/l
    hey anyone got a link to a good write up on how to convert the b16a to obd1?
    Hamilton, GA
    just go to phearable.net
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    buy
    p30 or chipped p28
    obd1 o2 sensor
    obd0->1 conversion harness
    dizzy jumper
    the instruction will come with the harness
    mixed life dustinkelley's Avatar
    monroe
    i want a ecu conversion too someone pm me so i know where to go!!! (to buy)
    JDM ASS FUCK:boobies:
    buy
    p30 or chipped p28
    obd1 o2 sensor
    dizzy jumper
    I'm not running any O2 sensors so I guess you don't necessarily have to run it.
    Quote Originally Posted by dustinkelley
    This is the one I have: BoomSlang
    Hamilton, GA
    I have the phearable.net conversion harness, dizzy jumpers, ECU, obd-1 dizzy and 4 wire O2
    far far away
    Kevin - If you have a chipped ECU, you can disable closed loop and you won't need an O2 sensor at all, except for a visual emissions inspection. If you're using an unmodified OBD-1 ECU, you'll need a 4-wire O2 sensor.
    monroe
    This is the one I have: BoomSlang[/QUOTE]
    is it worth it and easy to install
    Sep 2008
    thank you for your sharing~
