Results 1 to 40 of 63
Thread: fuel pump on a 92 teg
    Default fuel pump on a 92 teg
    ok im wanting to know how to take an fuel pump off an how to know if its bad on an 92 integra.also is there an fuel pump relay if so were
    Main Relay
    R&R Fuel Pump
    1. Relieve fuel pressure.
    2. Remove the fuel tank.
    3. Remove the fuel pump mounting nuts.
    4. Remove the fuel pump from the fuel tank.
    Senior Member G.C's Avatar
    Forgot
    actually you dont have to remove the fuel tank. i'm pretty sure it has a access panel like it did on my 92 prelude. its either under the back seat, or under the carpets in the trunk. there should be a panel. you can uninstall and install it back in from there.
    :idb:
    Default hey
    there is something under the bak seat but dont know how to take it out but im not sure if thats what it is it wouldnt start at all but when we sprayed gas in the tb itt started an i had to keep sprayin just to keep it running what could that be i know someone here will know i need help asap
    Forgot
    You can remove the panel by just plying it out with a flat head.
    have you changed the fuel filter? if its clogged gas cant get to your engine. check your fuel pressure too.Also try turning your key to ON position. if your fuel pump is alive you should hear a humming noise. check the voltage thats going to the fuel pump too. it should be 12v.
    :idb:
    Default hey
    Quote Originally Posted by G.C
    hey when you turn it over you can hear a noise around the motor but we couldnt hear nothin at the fuel pump i just took the fuel filter off there was a little bit of something but it was just running the other day an today i got a new fuse box an it wouldnt stay started unless we sprayed gas in it i need it fixed asap an would should i do
    Athens/ATL
    did you check on your new fusebox to make sure that all of the fuses are correct? And not blown? Double check EVERYTHING you have touched... it may be something little and simple.
    Don't actually turn the car OVER to her the pump... just turn it to the II position (like you would to turn your radio on). You should hear a low hum/buzz that's the fuel pump priming.
    Have you checked your starter/injectors/spark plugs? If your car just randomly stopped running, there's a plethora of things it could be.
    I would check your injectors to make sure they're clean, especially if it's not staying running without added gas.
    Where exactly are you spraying the gas in?
    Default hey
    well we was sprayin into the TB but everything is right it was only the fuse box under the hood by the shock tower
    Athens/ATL
    Well still double check for disconnected/loose wires... no matter how many times you do something, there's ALWAYS the chance you will accidentally miss something.
    Check your injectors and check to see if you're getting spark by arcing the plug wires.
    Default hey
    im gettin spark that was the first thing we checked ill check the injectors tom how do you know if there bad just by checkin them
    Athens/ATL
    Not sure how to actually test and see if they're bad, but I'm sure no_mo_hondas has a trick for you to test em.
    I usually pull em out just to check and see if there's anything obviously wrong with them (buildup)
    Default hey
    ill do that someone give me a text on some info 423 506 4163
    Athens/ATL
    you can probably just google it.
    Default lol
    lol i really dont know much about the gas situation thats why i posted it
    Athens/ATL
    I was saying google search for a way to test injectors for function.
    Forgot
    check fuel pressure from the fuel line first. i doubt its your injectors since your engine do crank when you spray Gas in the TB. also check your fuel pressure regulator.
    :idb:
    how do you check fuel pressure from the fuel line?an also when tryin to start it you can keep hittin the gas an iit will sound like its stayin started but aint
    i just pull the plug and see if it wet and smells like gas.
    Default hey
    after i do that an there wet ont that mean there gettin gas i just dont see how the fuel pump would just go out without no signs its gotta be something else
    if it smells like gas and wet u got fuel
    give me a recap of what all u have and dont have
    Default hey
    ok im confused about the recap part but i got everything hooked its just not wantin to stay started unless you spray gas in the motor if you could text me some info that would be great cause im gettin off for tonight 423 506 4163 thanks everyone for the help hope i can fix the problem tom
    Default hey
    up
    Default hey
    ok i just got back in from checkin my spark plugs there dry no gas on them at all the fuel pump is good so what would make it not get gas to the plugs
    SwiperNoSwiping!!
    fuel filter could be blocked, or anywhere else in the fuel system could have a blockage
    EDIT: or, the injector(s) could be bad/stuck closed
    u remind me of a wigger !
    Default hey
    Quote Originally Posted by GM_TUNER
    tthanks were should i start at i need this fixed asap i got ppl to meet
    Default hey
    Quote Originally Posted by tenn69
    another thing when i undo the two bolts on the fuel filter gas sprays out of both couldnt be that right
    SwiperNoSwiping!!
    If you think you can do it, then start by taking the fuel rail AND injectors off as one large unit and point the injectors into the atmosphere and/or put down a towel or something to absorb the gas, and just turn the key to see if the fuel pump will pump. If it does, and you see or smell gas squirt from the injectors, then the injectors are GOOD and you've got no blockage.
    Default hey
    alright will do but what could stop the sparks from gettin gas
    SwiperNoSwiping!!
    And then if you have gas spraying/squirting the way its supposed to, and the car still wont crank, then what you do is check the timing.
    SwiperNoSwiping!!
    Bad ignition coil i'd say is probably the biggest thing. Back when MY teggy was cuttin out on me, i changed out the igntion coil and it werked good again.
    Basically, just open up the dizzy and inspect everything to make sure it looks good, and make sure all connections are clean, make sure everything's tight, and make sure that all the contact points/electrical terminals are touching like they're supposed to.
    Athens/ATL
    There's not supposed to be gas on the plugs. There's supposed to be electric current going to them which is why I told you to check the wires by arcing them against your valve cover.
    SwiperNoSwiping!!
    Yeah, cuz if you get gas ON the plugs to the point where you can feel them wet, then the plugs are probably already ruined.
    SwiperNoSwiping!!
    So, what does it sound like y'all?
    It starts and revs when you spray gas through the TB, but as soon as you stop doing THAT, it cuts off.
    Athens/ATL
    he still hasn't told us if his injectors are functioning.
    Or if he hears the fuel pump coming on.
    Or if he has spark from the dizzy.
    Or if he went back and double checked all of his connections from his fusebox.
    Why do I even bother helping people on here? Go to the honda dealership next time if you want help.
    SwiperNoSwiping!!
    No injector function at all.
    Im talkin to him on the phone.
    SwiperNoSwiping!!
    I think what he said he was gonna do is replace the 440cc injectors that are *bad* with some 550cc ones.
    Athens/ATL
    No reason to upgrade injectors unless you need it. Just stay stock and replace your injectors. Done.
    Tell him he's welcome for the help.
    i have spark checked everything in the fuse box i un did the fuel rail an turned the key over an one of the injectors popped out lol i wish i knew what it was
    Athens/ATL
    replace your injectors with stock ones. Done.
    i got an gsr turbo
