Results 1 to 15 of 15
Thread: SUPER SINGLES!!!!
    Default SUPER SINGLES!!!!
    Instead of the 2 wheel per side per axle set up on most semi trucks, I get to ride on SUPER SINGLES!!! One HUGE tire on the end of each axle.
    Tire size? 445/50-22.5. Lolol.
    Later, QD.
    Attached Thumbnails Attached Thumbnails -img_1020-jpg
    Oct 2003
    JDM?
    Scottish Scotsman's Avatar
    on the road to recovery
    sweet!
    what kind of truck?
    The beach.
    I had a truck that had those, they do ad the cool factor, hope one never blows out, most repair trucks don't keep singles on hand. Might be stuck for a bit.
    2008 International TranStar. Later, QD.
    Damn I thought this was gonna be about some new huge Kraft cheese slices...
    - IA Mgmt
    Roswell, GA / Georgia Tech
    Quote Originally Posted by fcman
    hahaha
    Quote Originally Posted by Justin.
    Thats what I was thinking. What are the main advantages of these??
    gone old school C-loS109's Avatar
    somewhere
    i heard that those are actually pretty bad. not everybody has the chain size, shops may not carry them and if one blows there isnt a second tire to take the weight. but on the other hand, im seeing more and more trucks with them so they must be good somehow.
    =EJ-EG SQUAD SUPPORTER=
    2000 HONDA CIVIC - SOLD
    1966 MUSTANG COUPE - TRADED
    1989 FOXBODY MUSTANG - DD
    Saving about 1,000 pounds of weight thus using less gas is one thing. Instead of having two steel wheels per position, you have only one aluminum wheel. There is also reduced friction with less sidewalls also increasing gas mileage. One more thing is that since they weigh less than dual tires, freight amount can be increased in the truck (since we have weight limitations we have to meet in each state).
    Quote Originally Posted by C-loS109
    There are pros and cons to almost everything. These tires haven't really been recommended for LTL as much as for regional or local hauling. Later, QD.
    I ride DUBS hondachik's Avatar
    Columbus
    thats cool. the normal tire size's i deal with for large trucks/motorhomes are 245/70R/22.5 for the duals.
    i will actually have to share this pic/info @ work that they make tires this big.
    28 . female . I has VTEC . hondachik .
    S.I.C. Chic (Split Image Customs II)
    step sticky stephen's Avatar
    there's not really a whole lot wrong with super singles. if one blows, it can be emergency fixed with duals. when i worked for schneider, we had an issue with goodyear super singles though. there was a paper run where they were putting too much paper in the trailers. the singles were starting to crack on the sidewalls due to everyday bouncing while driving and being overloaded.
    Quote Originally Posted by TheScotsman
    You gonna get raped!
    - IA Mgmt
