Results 1 to 23 of 23
Thread: eBay header
    keep D series alive SLPR's Avatar
    with ya gurl
    Default eBay header
    my stock exhaust manifold is in bad shape. rusted from hell n back, and it also has a crack. i want a header to put on, but i cant afford to buy a name-brand header. eBay has some for 50-ish bux plus shipping. just curious if anyone has one and the results.
    EE OG Revmaynard's Avatar
    Eh, as long as you scout around and don't treat your car like **** I think you'll be fine.
    Bozzio for president.
    Atlanta, Ga
    If you're just using it to replace your messed up OE header it should work fine. Just don't try to use it as part of a power build.
    i know a dude with a H22 in a eg and ebay headers it runs good just make sure after u install then u wipe them down before cranking the car
    幸運をもたらす Lucky.'s Avatar
    G'nett
    Id say get it...makes your bay look a little cleaner too
    NOTHING WRONG WITH EBAY HEADERS
    I have used them many times, never an issue.
    I don't pull out... E=MCイ's Avatar
    Where we like our sisters...
    Default header
    i got my headers for my civic and my teg from the same guy on ebay his user name is boombop. his shiping was super fast and both fit perfect with no problems at all. cheap too.
    SOUTHSIDE
    ebay headers work good just make sure you get a one piece header because the two piece cames with some weak bolts and the gaskets not all that great they some times leak air out and makes your car sound nasty...thats just my opinion.
    they work fine,go ahead and get the black coated ones, the nice chrome ones will turn purple/browin in 2secs aftet car turns on. also like ^^ said where my 4-2 runs together that gasket blew out,so i have an exaust leak right there.but its lasted good no cracks.gaskets can be replaced.
    Atlanta, Ga
    Quote Originally Posted by wrekonize
    x14899823749324
    i had a 2 piece replica header on my car when i got it and it was crap.
    the o2 bung was in the wrong spot and the bolts stripped easily and the gasket broke.
    just go for a one piece and you'll be alright.
    and as you may know... an exhaust leak will make your exhaust sound like ass and if its bad enough it will make your car run like crap
    I ride DUBS hondachik's Avatar
    Columbus
    Quote Originally Posted by SLPR
    don't do it. if u have a d-series then the 2nd oxygen sensor will not be able to plug up. i have that problem because i just got one 2 weeks ago. it messes up the fuel/air ratio for my car now. don't do it unless u dont mind not having the 2nd oxygen sensor.
    28 . female . I has VTEC . hondachik .
    S.I.C. Chic (Split Image Customs II)
    Columbus
    Quote Originally Posted by 95_gs_R
    x2
    San antonio 210
    dont get a 2pc, 1pc FTW
    used name brand headers for d series are $50 bux.....
    BOOB koukis14's Avatar
    Pennsyltucky
    I put an OBX ebay header on my S14. It held up good while I had it. Fit perfect too.
    Your moms house
    Quote Originally Posted by hondachik
    You could get a bung welded in for around 15-20 dollars.
    Certified Gearhead brandenj's Avatar
    small town loganville
    i would just get an used name brand header in case you decide to make some hp. you can find some just as cheap as the ebay ones, and better quality. or you can wrap you stock one to hide the rust and it might even lower your underhood temp. i wrapped my dc 4-1 headers to hide the rust and i love the way the black wrap looks on them.
    pluss 4-1 flows a little better than the 4-2-1
    abcdefghijklmnopqrst afwfjustin's Avatar
    you get what you pay for...
    post up a wtb for a used exhaust manifold.
    New car:
    95 S14 with RB25DET (stock boost)
    Old car:
    Turbo S2000 400hp/285tq on 9:1 comp & 11psi
    Snellville/Statesboro
    d series headers are hard to come by... for me anyway.
    so what would u guys recommend on the ebay headers: ceramic or stainless?
    UPROOT Photography FTW
    with ya gurl
    i can find d series 4-2-1 headers all day on eBay...but i cant find 4-1 nowhere.
    what should i type in the search engine on ebay?
    Made in BRASIL junior_tm's Avatar
    Brasil
    right now i have a ebay header in my car looks awesome but like bouncy saide wipe it down before you crank it up i didnt and it wasnt a pretty site when i did it but it looks good and never gave me a problem
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    i ment like, name brand ones... can't find them.
    i'm just typing in 92-95 honda civic header, get about 2 pages worth of sales...
    4NSpeedTech thedream2147's Avatar
    Seattle, WA
    Most everybody is correct, one piece is better than two..some will have issues with O2 bungs lining up and sometimes the gaskets suck.
    One thing nobody has mentioned though is with cheap headers, the metal flex pipes tend to leak and tear up over time. This will cause a nasty hiss or a whistle which gets really really annoying.
    Also, if you can spend the extra 25 or 30 bucks, try and get a stainless steel or cermaic coated one instead of a "chrome polished ones." The chromy ones will rust out after a month and look like crap and tend to break faster.
