I think I opened a box of worms..
the car has been running fine since I got the relay fixed..
well tonight driving home.. I happened to glance at my speedometer and the needle started flicking back/forth.. then laid on the 0 mph...
the check engine light then came on..
luckily I was right around the corner from the house.. pulled into the driveway, turned off the car, turned back on the car and the check engine light didn't come back on..
I let the car run, check for leaks, anything possible. NOTHING.
I'm assuming my SPEED SENSO took a crap? I remember when I first purchase the car several years ago, I changed out (sensor/or whatever you call it) that was in the cluster because my speed wasn't working correctly, it was off by like 10 miles. I changed that and never had a problem until now.
The only reason why I say that it could be a speed senso is b/c the damn check engine light came on.
Any suggestions?
1993 Honda Civic DX
and the miles for when you reset them or miles on the car are not working in addition to the MPH
