Results 1 to 18 of 18
Thread: Parting out B16A2
    Southside
    Default Parting out B16A2
    I'm parting out my previous swap. This is not a working head, in its current state. #2 Dropped 1 Intake and 1 Exhaust, causing damage underneath, this was due to way too Aggressive Cams and High-Compression CTR pistons. The block is also up for sale, the sad thing about the block is that it's cracked completely through in cylinder 1 and have cylinder 2 has 2 smaller cracks in it, but can be re-sleeved. Before I bought the swap from the previous owner he had a turbo on it and cut a little chunk out of it. The .25 over-sized CTR pistons are of no real use, when piston #2 took the impact, shards scattered doing little damage to 1 or 2 other pistons.
    Specs of Head:
    Port & Polish on Intake and Exhaust
    JG Engine Dynamics Valve Springs and Titanium Retainers
    Buddy Club Spec III Pro Cams
    Stock Rocker Arms
    Stock VTEC Lifters
    Ferrea 6000 Valves
    Ferrea Valve Seals
    Ferrea Valve Stems
    Ferrea Keepers
    Specs of Block:
    Bored .25 so bore is 81.25
    Stock Rods
    Stock Crank-shaft
    The whole head with the exception of the Buddy Club cams: SOLD
    Buddy Club Spec III Pro: $300
    The Valve Springs and Retainers: SOLD
    Block: $75
    Crank-Shaft: $75
    Oil Strainer w/ Baffle Plate: $40
    Water Pump: $40
    Thermostat Housing with tube that connects to Water Pump: $ 50
    Stock P2T ECU: $100 firm.
    Rywire OBD2b to OBD1 conversion harness w/ secondary O2 sensor wire [never used]: $100
    There are more parts for the block, so if you have any questions just ask
    Senior Member Nang's Avatar
    got a tran?
    Southside
    using it on my current motor
    b16? trade you a gsr one for it =)
    southside ATL
    bump for a cool guy....and them killer cams
    damn i wished i had 4bills
    BABIES "R" US crew
    Banned lsxtreme's Avatar
    $75 for JG Engine Dynamics Valve Springs and Titanium Retainers?? if so i'll take'm
    Southside
    Quote Originally Posted by lsxtreme
    That's cool. I'll just have to get the spring compressor to get them off for ya......
    Southside
    Southside
    Price drop for Buddy Club Spec III Pros, I need these cams sold by or if not before the end of this week. 300 and the cams are yours.
    GoonSquadsNinja JDMjoe's Avatar
    i85north
    Free bump for you man...
    Southside
    Sale Pending on Head for 80
    Southside
    ttt
    Certified Gearhead lsi-crvtec's Avatar
    Ill take the head for $75...today
    Certified Gearhead kar906's Avatar
    Southside
    Quote Originally Posted by lsi-crvtec
    just sold it today
    Southside
    Southside
    Sale Pending on B16 Crank, Rods, and Flywheel
    Southside
