Results 1 to 17 of 17
Thread: i think i need a new tranny
    Gainesville
    Question i think i need a new tranny
    lol almost 300k miles and it has been abused.. i don't know if it is just the clutch or the whole tranny.. but it makes a funny whitsling grinding screeching sound when the clutch is engaged... i know the cutch is going out but i don't know if this is just the clutch as well.. but yeah any suggestions?
    'Round These Parts
    bearing most likely.
    I have an Accord with 344k on the Tranny and around 41k on the engine. Tranny has a new clutch - it shifts perfectly
    Leisa and S. 4 Life NM?
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    It's just a d tranny. Go buy another one for $25 LOL j/k homie!
    Gainesville
    lol yeah i know i was thinking about just getting a good cutch and maybe getting a tranny as well cause no **** i found one for 50 bucks with lik 50k miles on it lol
    Macon
    sounds like it might be the input shaft bearing. Does it get louder when you accelerate, then let off the gas (probably loudest in 1st gear)?
    Land Rover LR3 HSE
    Gainesville
    yeah thats about right i mean harder accerleration it is louder... think i would be better off gettin a newer tranny? and a good clutch? also ihe car is a 96 civic with a d16y7 i forgot the tranny numbers, but what tranny do you think would e better and still not exspensive i mean after all we are talking d series here lol
    'Round These Parts
    I have a transmission for cheap 100 gets it!
    It's is good condition.
    Macon
    just get a new tranny, and a good clutch. I'm pretty sure just about any hydro D series tranny up to 2000 will fit. I would also go with an Exedy stage 1 clutch. I have had a few and they seem to last the longest.
    you may be able to find a jdm D15B VTEC transmission. I think it was avaliable with LSD.
    Land Rover LR3 HSE
    Gainesville
    kool kool preciate the info guys it'l be a little bit before i get one but yeah i am about to order a exedy stage one in a week
    You said "engage".....to you, does that mean clutch pedal pressed, or not? If it only happens when you disengage the clutch, it would most likely be the throughout bearing (or release bearing). Continue with the clutch replacement, which includes a throughout bearing.
    Quote Originally Posted by §treet_§peed
    A stage 1 is basically a stock clutch, so don't spend a bunch of money on it.
    Macon
    Quote Originally Posted by Init2winit
    an Exedy stage 1 is NOT a stock style clutch. They make a Performance replacement oem style model, but the Stage 1 is made to handle more power and torque. The only similarities it has to a stock clutch is that it is a full face sprung hub clutch, which makes for smoother engagement and disengagement than a pucked design. It has a good deal more clamping power than stock. Go with the Exedy stage 1 unless you are planning on making more than 200whp.
    Land Rover LR3 HSE
    Gainesville
    100 bucks isn't bad is it? lol well when i let off the clutch pedal whether its in the gear or not.. i still call it engaged when i let off the pedal whether it is in gear or not
    Gainesville
    anways i think i still need a new tranny cause third gear grinds almost every time i put it in even at low rpms.. MOLESTED TRANNY FTL lol
    Gainesville
    yup yup so what tranny would yous gys recomend?
    JDM TYTE AnthonyF's Avatar
    either way the trans has to come down, so check out how bad the clutch is and determine whether or not the trans is bad.
    The Carbon Fibered R6
    Gainesville
    eh i figure go ahead and get a tranny that has under 100k miles and not close to 300k and has not been molested like mine lol
