Results 1 to 20 of 20
Thread: e break bypass
    jack daniels addict integra938's Avatar
    marietta
    Default e break bypass
    anyone happen to know what the bypasscode for a dualbrad indash is what place i can find it ? i tryed google no luck
    Acworth
    Blacc Panther member
    look to ya left
    just ground the pink wire lol... thats all
    marietta
    cool thanks
    I GOT IT!
    Jan 2003
    Lithonia, GA
    ive installed a dual where the code didnt work so i had to use a toggle switch and do the E brake by-pass sequence with the toggle switch for it to work also.
    Hybridaccord
    Quote Originally Posted by Dracc
    What he said, lolol...or whatever color the e-BRAKE wire is. If you can't figure that one out then errr...i can't imagine what the wiring for the amps, crossovers, speakers, etc. look.
    i too am struggling with the bypass switch on a Pioneer in dash.
    h series
    norcross
    x2, at least someone knows what theyre doing
    BUNG
    Jan 2003
    Newnan,Ga, USA
    Which model pioneer are you having trouble with? their bypasses arent typically as simple, although just grounding the light green wire sometimes does the trick.
    Single... but looking.
    look to ya left
    the pioneer you will need a toggle switch and run the actual e brake with to the brake pedal and then to the toggle switch... press brake in park then flip the switch then let go of the brake then your good
    Why not just ground the wire and close the loop 100% of the time?
    BUNG
    Jan 2003
    Newnan,Ga, USA
    Pioneer's are model specific. Meaning what works for the avic-n3 does not necessarily work for the avic-z1, although there are exceptions. Some of their bypasses require dropping soder under that little silver piece of tape that says "VOID" if you peel it up. Others a flash of the parking lights while in its loading screen bypasses the e-brake.
    look to ya left
    sometimes grounding it like that on high end screens sends current back to the screen and then POOFFFF
    I'm saying if it has to sense the e-brake switch is open/closed then just wire it up as if it's not there.
    Post a wire diagram of the headunit and I can "red line" it showing exactly what would need to be done.
    i just grounded mine out and it worked but some models you will have to run a toggle switch.
    Quote Originally Posted by 98cvcex
    If it requires a switch then that means there is 2 wires coming from the head unit specifically for the e-brake right?
    look to ya left
    no.. one wire.. spliced into the switch... its just to trick the e brake wire that the car is in park
    nope just one wire. when hooking up switch you may have to flip on and off depending on what ya want to do with head unit (i.e. listen to radio or watch dvds)
    Senior Member | IA Veteran Mad Mike's Avatar
    Gainesville
    on the duel indash touchscreen models you can't just ground the E-brake wire. Theres a built in safety that has a 10-13 sec bypass. I had to hook up a switch to it and if it doesn't show a pic i flip the switch off for 10 sec and then back on then it shows the video.
    BUNG
    Jan 2003
    Newnan,Ga, USA
    the bypass for the Dual brand screens is clearly printed in the manual that comes with them new. The toggle is like 5 seconds on, 5 off, then back on, or some random amount of seconds for each one, and then it works. Same goes for Jensen's, Audiovox's, and etc, as they are all the same product...
