Results 1 to 25 of 25
Thread: Interested in stroking a b18c:
    Senior Member SE-Rious©'s Avatar
    Default Interested in stroking a b18c:
    Well i have thought about it and i am interested in stroking the b18c to a 2.0L.
    looking for the pros and cons,and whatever else useful.i have been doing tons of searching on many sites Honda-tech being the main one.just wanted to see if anyone has done something like this on here who can give me any useful info,point me in the right direction and steer me far away from mistakes.
    any info is appreciated,thanks.
    DONT STROKE IT OUT!!! Bore the motor out wen you build
    If you really really want a 2.0L just get a B20 block and sleeve it. Stroking/Boring a GSR to 2.0 is going to cost a whole lot more and provide just about the same power gains.
    You also have to remember longer stroke will reduce your max RPMs thus cutting into the time you have to play in VTEC.
    Leave the motor stock stroke, bore it over a little, and use the money you would use on stroking the motor for head work, balancing the bottom end, and forged internals.
    Put the oversize ITR, P30 or CTR pistons in to increase the compression.
    Quote Originally Posted by IDriveToast
    which crank would i use,the b20b crank ? can it handle higher rpm's like the b18c ? also if i build the motor and it had some good cams it would make mroe power up to higher rpm's so i could take it higher.im just looking for torque w/out building a ls/vtec or b20vtec.
    thanks for the help.
    Duluth, G-nett
    Quote Originally Posted by xbn83
    Y? just get forged internals
    Quote Originally Posted by Vuongy_Dong
    Just an OEM route suggestion.
    i noticed alot of JUN,SPOON and other japanese racecars have been stroked to 2.0/2.1L's from the b18c's .. it still is a big intrest i have,we'll see what happens i guess.thanks for the help everyone
    Augusta Ga
    mrvdata eh > lol ... mrvdata's THE SHIT LMAO .bump for a friend
    93 sol Si
    95 sol S
    95 sol Si
    02 WRX patrick4588's Avatar
    warner robins
    if you bore it out to 84mm and sleeve it, you will be able to make torque a lot easier. im assuming you are going turbo? the larger displacement will also help you to spool earlier
    If you want torque...you don't want a B Series. Go K20 or K24 if you want torque.
    Building the motor and doing head work will enable you to raise the RPMs. You don't need to stroke out a B18C to make power if you're going to build it properly.
    Yeah, JUN, Spoon, and others use a stroked motor. But they also put hours and hours and hours into triple checking everything, tuning, maintaining and building. They also spend tons of money. Most people don't want to spend $15,000+ on an all motor engine.
    stroking and possibly boring is the route i will be going.thanks for the help everyone.
    lawrenceville
    if u want torque...dont drive a honda lol
    Proud Mr2 Turbo Owner
    Subherbs
    Hahahahaha
    Quote Originally Posted by 3kgtdrvr
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    Macon
    stroking a B18C is a waste of time and money. The spoon and jun stroker kits are for the B16B, which up displacement to 1.8L. The B18C is usually just bored over. I have not seen spoon or jun use stroked B18C's.
    Land Rover LR3 HSE
    BOOST Gets U LAID
    Cedartown
    I had a GSR stroked and my honest opinion on it is this....Yes it made good torque but it didnt hold together worth shit. If ur doing to to rev out then be careful. It didnt like the revs at all and mine was turbod. At 11psi mine made 317whp and 276trq. SO yes it makes hellacious torque but what good is it if it didnt last but 2000 miles. I wouldnt do it for a DD at all. It is cool to tell people you have it but functionality is extremely important to me in a car.
    thanks for the help.but it all will be done right and wont be in a daily driven car.
    Macon
    Quote Originally Posted by JHJams
    man you are hell bent on stroking it. Dont you think that anybody who spends the money on stroking the engine is going to have it done right? That doesnt matter. It could be built by the best engine builder in the country and only last 1500 miles. A stroked B18C just isn't a good idea. It is not worth the money. The rod/stroke ratio or the B18C is superior to the R/S ratio of a stroked B18C. When you stroke the engine, the piston speed will go up, which means the engine will wear faster. Just have your engine bored out a little (1mm over will give you about 20cc's extra in the engine.) You could have it sleeved and go with 84mm or 84.5mm pistons, which would put you around 2.0L. Since the stroke remains the same, you will be able to rev to 8k+ rpm just as with a stock bore B18C1. Remember, if you up the displacement, you will need bigger cams and need to get the head worked to flow more.
    Land Rover LR3 HSE
    "big $hit poppin"
    in the slums where killas get hung
    man, i had the same idea. do it & let me know how it goes.
    DO NOT STROKE IT
    learn about rod stroke ratios.
    if you want displacement, SLEEVE IT
    Northwest Georgia
    Dont stroke it, the b20/b18a/b cranks are more than enough stroke for a b series and can handle ANYTHING you can throw at them. sleeve the block for 800$ and spend 100$ boring and honing the fucker and put some forged pistons and rods in, and then spend your saved non wasted cold hard cash from not buying a worthless stroker kit on HEAD STUFF!!
    "big $hit poppin"
    are b series cranks interchangeable?
    Northwest Georgia
    yes
    This statement isnt true. The larger stroke CAN play in revability. But the amount of time in vtec statement is false. You engage the 2nd cam lobe when the motor is capable of using the larger amount you are giving it. I larger motor is going to suck more air at a lower rpm than a smaller one, so vtec could be in the 4k range rather than 5500 or higher. Head work also has a lot to do with that as well. A worked head will flow more air than stock one thus allowing you to give it more sooner. BUT, you all motor guys are all about some big cams and the primary lobes on them are so large that your vtec usually stays pretty high.
    I am sure someone can find you a picture of a "stroker" crankshaft.
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    lawrenceville
    ^lol nice pics! +1 for some good stuff
