View Poll Results: Which engine
Voters
70. You may not vote on this poll
  • B20Z
    13 18.57%
  • B16A2
    9 12.86%
  • B18C1
    48 68.57%
Results 1 to 40 of 49
Thread: Vote for my swap
    Norfolk, VA
    Default Vote for my swap
    I am looking to swap one of the following engines into my '91 Sedan.... Just let me know what you guys think.
    B20Z
    • NON-VTEC
    • Found in: 1999-2001 Honda CR-V
    • Displacement: 1973
    • Power: 146 hp @ 5500 rpm
    • Torque: 133@ 4500 rpm
    • Compression: 9.6:1
    • Bore: 84 mm
    • Stroke: 89 mm
    • Redline: 6700 rpm
    B16A2
    • VTEC
      • 1999-2000 Honda Civic Si (EM1)
        • Displacement: 1595 cm³
        • Compression: 10.2:1
        • Power: 160 hp (118 kW) @ 7600 rpm & 111 ft·lbf (151 N·m) @ 7000 rpm
        • Transmission: Y21 S4C
    B18C1
    • VTEC
    • Found in:
    • Displacement: 1797 cm³
    • Compression: 10.0:1
    • Bore: 81 mm (3.189")
    • Stroke: 87.2 mm (3.433")
    • Rod Length: 137.9 mm (5.429")
    • Rod/Stroke Ratio: 1.58
    • Power:
      • 170hp @ 7600 rpm
      • 128 ft·lbf @ 6200 rpm
    • Transmission: S80
    All engine information found on Wikipedia.org
    <---Click it.
    Snellville/Statesboro
    I say the GSR.
    But my vote would be for a ZC and then turbo. You can get a complete swap for $750-$1000 then you got left over money for turbo.
    Norfolk, VA
    well the reason i have the b20 up there is b/c it is a great engine to turbo... and it is a cheap swap
    <---Click it.
    gsr
    Navy Recruit AgentEasy's Avatar
    Cobb
    i'm doin an ls non-vtec in mah rex.. it's gon be smokin.. tires..
    there i did it.. what'd you think?
    No
    I say GS-R.
    how much will the B20 swap cost ya? motor mounts, tranny, ecu everything...
    gsr is pretty much the best all around Bseries engine, you can go N/A or boost easily, and it's fun as hell straight out of the box.
    the b20z would be fun too, and you wouldnt have to worry about compression issues that much, maybe the cylinder walls.
    IMO B18c1>B20z
    Norfolk, VA
    thanks guys and ZC i am getting a quote from mainstream in a day or so
    <---Click it.
    superduper LLLLLLLLL
    this is not even a question..
    d15 all the way
    ^^LOL
    GSR, then B20 then B16
    Personally whiteboy, if i were you then i'd start trappin and use that money to buy a B18c5. but thats just me...
    Norfolk, VA
    lmao, anyone want some weed? j/k
    <---Click it.
    San antonio 210
    gsr ...
    B18C5 are ghey, only cool because of wow factor but for HP:$ ratio it sucks!
    Quote Originally Posted by KevinT707
    ditto
    Norfolk, VA
    well right now i am looking at a non-vtec b18 swap,
    <---Click it.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by Whiteboy
    dont b20 have weak sleeves and the b20z has a higher C/R then the b20b........................ I say a no go with the stock b20 with turbo
    also why swap in a 3rd gen b16. I hear it's the hardest of the b16's to swap in a EF, plus you got to dummie your engine down and smart'n up your car. (if you dont get that ef obd0 ->obd1, engine obd2->obd1)
    ECEFC.com
    I say a b20 swap, but it takes a min to find all the parts (you will need a ls ecu, intake manifold, obd0/1 dizzy, and a tranny).
    I would do a LS swap first, then save up and get the b20 block and swap everything you need for the b20 off of the b18!
    {Oh yeah vtec is so over-rated, your dont get to use it until like 5000rpms LOL}
    Certified Gearhead spacelion's Avatar
    Metro Atlanta
    They cost a lot compared to the C1, yes. But worth it, definitely. But horsepower isn't the only thing that makes up a motor. All the stuff that the C5 comes with from the factory is worth all the money if you add it up. So what if it doesn't put out monster loads of horsepower. Matched with the suspension setups of the Type-R family, they're great factory road/backroad cruisers.
    What it really comes down to is what the OP wants to do. If you're going boost, B18C1 all the way. If NA, you could do C1 as well, but if you got money, get the C5. [/$0.02]
    ][STREETLOVE][
    Just get an H22, start trappin over in Grayson and turbo that bitch. No one could touch you lol.
    ECEFC.com
    Banned caseyT's Avatar
    Winder
    B20, gsr head youll have torque out the ass then turbo that beast
    Augusta Ga
    id put a zc in it and turbo the zc on like 20 psi and call it a day . ... but if u had the moeny .. b18c5 all the way ....
    93 sol Si
    95 sol S
    95 sol Si
    dahlonega
    gsr
    I've actually never gone out with a girl
    Quote Originally Posted by Stretch®
    Why does a dog lick his own nuts? Because he can. Later, QD.
    Quote Originally Posted by AllStock
    nice ride.. what doesss FTW! mean??
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    H2b or K
    your moms house
    Quote Originally Posted by spacelion
    why would you spend that much more money to get a little different crack and 35-40 HP?? i see your point on the suspension and shit but youre talking apples to oranges.
    FUCK B&D COMMUNICATIONS!
    your moms house
    I love how ignorant some of these threads get with bad info and lack of knowledge
    middle ga
    d15z1....hands down
    Belview Insane Asylum
    I say the GSR.
    This man knows whats up.
    And at thinking ANY B series swap is going to be "cheap"
    Earth
    The Powertec RPA 2.6-litre V8 prototype number one or 'Christine' as Ted Hurrell now refers to it, (after the car from Stephen King's book of the same name!) has produced 363bhp at 10,300rpm on her second visit to the dyno. Maximum torque is 196ft lbs. at 7,000 rpm, but amazingly it is still 165ft lbs. at 4,000rpm and 180ft lbs. at 10,300rpm.
    From a V8 that weighs 200 lbs. It's two Hayabusa motors put together. B18C5 FTMFL
    if you need a swap done... "Vuong's Garage" does B series swaps for $600
    check out the sponsor section
    H22 = best bang for buck
    Stan The Man TallGuy's Avatar
    Dacula Ga.
    ^^^^^H22 is a great motor...but out of your 3 id go with the GSR
    Quote Originally Posted by AnclyT
    They will put a B series swap in an EF for $600? That's kinda hard to believe.....
    $600 for labor ONLY
    you provide the motor swap/mounts/axles/etc.
    Well that makes it a bit more believable....
    Banned turb0teg's Avatar
    GSR-T FTMFW
    :boobies:
    L'ville
    d16z6 ftw. green91's turbo z6 was pretty nice. and, if i remember correctly, was fairly inexpensive.
    RE30
    i would go for b20/vtec. n gsr would be my second choice
