Results 41 to 57 of 57
Thread: help, integra build not turning over
  1. #41
    i like hubcaps madwick's Avatar
    Dallas
    you cant even fit anything between them!
    if i was to load the teggy onto my trailer and bring it by you guys when, how long and how much would a valve adjustment be? i'd like to be there just for knowledge
  2. #42
    Jul 2003
    Atlanta Centennial Park
    we usually charge $65 for a valve adjustment, we can look at it on Tues afternoon, or Wed
    -www.usedbarcode.net
  3. #43
    Super Dave Z U L8R's Avatar
    Roswell
    THE FUEL LINES ARE ON BACKWARDS HAHAHAHA
  4. #44
    D'oh! lol
    91 CRX SOHC-550WHP 420TQ (Sold)
    02 WRX-224.4WHP 223.2TQ (Traded)
    01 S2000 (stock)-201WHP 130TQ (Traded)
    98 GSR (stock block) - 415WHP 340TQ...Hydro locked. Sigh
    91 240SX POS - 0 WHP 0 TQ (Junked)
    10 370Z (Sold)
    97 Civic DX (turd awaiting polish)
    98 GSR (built) - 606WHP 366TQ @ 20 psi on 93 octane
  5. #45
    Dallas
    i'll be able to borrow that tool to tighten the locking nuts so i'll do it myself this weekend!
  6. #46
    Northwest Georgia
    paypal me 100$, i will bring tools and if it CAN crank, it WILL crank.
  7. #47
    Engine Builder hondasniper's Avatar
    SC
    Also, if you change out your valves, you need to do a valve adjustment. Valve tips can differ between companies which will change your clearance and can also change your install height. Shit, anytime you mess with the valvetrain you should do a valve adjustment. Your valves were staying open the whole time. It's good that it wasn't set too far down where it could've hit the valve reliefs. Its good that you have ur car running again. I'd be pissed too if I were to turn a car over and it wouldn't start. Remember to gap your plugs too, unless they are pre-gapped. I'd suggest .040 gap (~1mm). It's pretty neat how much help you can get on one of these sites. Good stuff guys!!! Also, I saw this with someone who came into the shop, some camshafts have too much lift with can result in the retainer hitting the top of the guide/valve stem seals. Check your clearances and check the manufacturer's recommendations to see if the guides have to be machined down a bit. Just for future reference.
  8. #48
    Dallas
    awesome thanx dudes ill be working on them today!
  9. #49
    blank
    nowhere
    get that shit fixed son.
  10. #50
    Dallas
    okay so i am getting great progress but i can't get the timing right! i think the adjustable cams are tweeked!
  11. #51
    Jul 2003
    put them at 0,0
    it should be fine, sometimes, you have to slide the belt on once cam gear (intake side) then get the belt almost on the exhaust cam gear and move it SLIGHTLY with a 14mm to get it to line up
  12. #52
    Dallas
    well i did that but i think that the adjustable part on the cam gears are wrong!
  13. #53
    Jul 2003
    what cam gears are they
  14. #54
    Dallas
    crower's adjustable... i have the duration and othe specs to the cams but i need to know where to line the cam gears up.
    also, how much time/$ is it to tune a car with hondata s200?
  15. #55
    Nov 2003
    so you have no compression but it's not turning over freely?
  16. #56
    Dallas
    no its turning with compression now and no contact! the adjustable cams are screwing up my timing! they are at tdc and the sprocket is at the arrow so why wouldn't it turn over?
  17. #57
    Nov 2003
    Quote Originally Posted by madwick
    take a pic of the cam gears! [while they're on the car]
