Results 1 to 32 of 32
Thread: Integra Help
    Douchebag Ed's Avatar
    Smyrna, GA
    Default Integra Help
    So here's the deal. Gf's 94 integra has a problem.
    Last night, drove it home just fine, this morning it wouldn't start up. I know for a fact we didn't leave anything on (IE misc lights, stereo, or headlights).
    Got jumper cables, jumped it. Worked just fine, drove it to work, lunch time comes, it wouldn't start again. So I jumped it again, after lunch same problem.
    So my conclusion was, it must be the alternator. After work, I went to Autozone and tested the battery, alternator and starter. Everything came out 100%, according to their test.
    Checked everything, checked the alternator and there was some grease underneath it, which i am guessing is from the cv axle because the boot is ripped. I already knew that was a problem, but that wouldn't cause any problems starting the car right?
    It couldn't be any electrical wires loose, because I haven't done anything electrical on this car.
    Also, a little bit more info, after I jump start it, and turn it off and try to crank it back up, it tries to start but does not, then after that the battery is basically dead. It seems like that last try just drained the rest of it.
    The battery is brand new, i just replaced it about 1.5 month ago.
    I think this is all the info I can give.
    Any ideas?
    either something is staying on grounding out.
    or
    have your battery tested again someplace else or try a different 1.
    Smyrna, GA
    Quote Originally Posted by no mo hondas
    or
    yeah i thought that it could be the grounding issue too... but like i said i havent touched anything electrical lately, so i cant see how it would just randomnly be something like that.
    either way saturday im retesting and gonna try to figure it out. i am just trying to get some pointers right now
    Scottish Scotsman's Avatar
    on the road to recovery
    Quote Originally Posted by Ed
    look at your manual
    Smyrna, GA
    look at your manual
    i will ban you!!!!!!
    wait,
    nvm.
    wait,
    nvm.
    try it biotch
    Hamilton, GA
    Check your alternator wire
    jump car and allow batt to fully charge. shut off car and disconnect batt and let sit overnight (it's possible the batt is taking a dump on you and the cold has just pushed it over the edge). take batt in for test to see if it's dying on it's own-volt and load test(bad cell, etc). if everything checks out then you have an issue w/ the car/wiring/grounding. when it gets cold like this i have seen issues w/ rats getting up in/underneath the batt and dash and chewing on wires. is your car left outside or inside at night?
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
    Smyrna, GA
    wouldn't that show on the test they ran at autozone?
    Smyrna, GA
    Quote Originally Posted by scttydb411
    how long do you think it would take to charge?
    it's left outside.
    thanks for the tips btw.
    North Augusta, SC
    I've heard at least 15 minutes if trying to recharge a dead battery by letting the car run...
    Back to being stock and slow
    Senior Member Schugg's Avatar
    Wichita Falls, TX (Conyers, GA)
    i know alot of times i had problems with winter coming around my car would stop starting. most of the time because a sensor on the throttle was too cold or the starter was to cold, cant remember which one. but everytime it happen i would just warm it up and it would start fine.
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    you can find out if your alternator is holding capacity as well.. jump start it however you started it up and disconnect the battery! it should stay on ONLY if the alternator is holding power, if it dies after you disconnect the battery then .. it's a badd alternator! and the alternator is draining your brand new battery to it's last breath 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    Bring it to me, I will fix it
    Smyrna, GA
    Quote Originally Posted by Motivation
    i drove it home after it was on. does it have to be on idle?
    Quote Originally Posted by Schugg
    i will try that
    Quote Originally Posted by YouKnowIt
    someone told me this earlier. i am gonna try it. thanks a lot.
    Smyrna, GA
    how much?
    North Augusta, SC
    No, it doesn't have to be at idle... Guess that rules out that option to try. ha
    not neccessarily. when u drive he car it charges the battery. by the time u go in and get one of those sorry bastards at autozone to test it, its prolly still charged so it shows good. that tester is dumb in some areas but smart in others.
    i had a car charging at 15.5 volts and the tester said it was good. now the one camary i tested with it that was charging at 46 volts it realized that was too high. And yes, i did say 46 volts. i ducked next to the car telling them to turn it off bc i didnt know that was possible. lol!!!
    North Augusta, SC
    46 volts? WTF? That battery was a trooper and an over-achiever! lol
    Hamilton, GA
    Easy ass way to test your alternator. I did it and thought that my alternator was bad but it turned out it was just the alternator wire going to my fuse box got burned up.
    Smyrna, GA
    Quote Originally Posted by BTEC
    when i got to autozone, i turned off the car and tried to crank it back up so i didnt look like a dumbass if they asked me to crank it up.
    the tester showed 13.8V
    that means ur alternator was working at that time. do u know what the CCA rating on the battery is versus what it put out? What kinda accessories are on the car. you may have not touched anything lately, but if u have some ghetto wiring somewhere u could have a wire that finally rubbed the insulation off and is grounding out. <-just throwing some things out there for u to check saturday. oh and a dead cell in a battery would read 10.6 when u turn the car off. it wont be able to hold 12.5 volts any more. hmmm, what else.....you could let somebody who know wtf they are doing fix it for yuh. LMAO!!!!!!
    Smyrna, GA
    yeah i asked emmino how much. awaiting for his response.
    if not, my friend whos helping me saturday knows wtf hes doing lol
    lol at one of those autozone assholes ... btec... lol..
    Btw I had an integra that would charge battery sometimes and then not other times, and the batt light would come on when the lights came on but if you turned the high beams on it would go away lol... ended up being in the back of the fuse box under dash, loose wire...
    shut up Joe!!!
    Hope i helped atleast a wee bit Ed.
    Smyrna, GA
    yeah jesse. thanks a lot man. i'll take it over to mainstream sat and emmino will look at it.
    Hamilton, GA
    Hope ya get it fixed. I know that shit is annoying.
    North Augusta, SC
    My dog could tow it for you if you can't get it started.
    *runs*
    volt meter guys, cant guess at parts, if its not charging an your battery,alternator is good, could be electrical also could be a Bad ECU, it sends a signal to an from the alternator to tell it when to charge, if its not getting that signal the computer will not tell it to charge, there for No charging...
    No where near a common issue unless some dumbie has messed with the wiring before, factory wires just dont come loose like that on a daily basis, but glad you found that problem, just verrrry rare thats the case
    make sure the wires to the battery are clean and tight. they may have loosened up... check it out and post if that works
    check all ground
