Results 1 to 25 of 25
Thread: Anyway to fix IACV???
    Southside of The Jungle
    Default Anyway to fix IACV???
    My car has had small stuff messin up lately im guessin since the person that had it b4 me really didnt give a shit about the car they didnt replace small stuff like sensors but my friend checked the code that being thrown and he said one code was tps and the other iacv which wont let me car rev over 2500 rpm is there anyway i can fix the iacv
    Low-n-Slow iEvo's Avatar
    Gnett
    yea buy a new 1
    Quote Originally Posted by BlackIX
    yea buy a new 1
    good one i had question for you did the evo in yo avatar is that the one u wrecked i seen them pics and was llike damn i hope that aint it
    Level IIIa? LOL. allmotoronly's Avatar
    Macon
    yea buy a new one. the IACV wont keep you from revving over 2500 rpm though... it will make you idle really high. The TPS is probably the problem with it not revving high, since the ecu probably is getting a signal that says the throttle is closed when it is actually open, and it limits the fuel injectors.
    btw, wtf is that ghetto rigged intake? you probably lost hp on that one. definitely did not smoothe the air flow any.
    Land Rover LR3 HSE
    Macon
    and where is your pcv valve?
    Land Rover LR3 HSE
    Quote Originally Posted by allmotoronly
    I replaced the tps and it still wouldnt rev over 2500rpm so i took of my iacv i think the codes that were being thrown were 7 and 14 i cant remember but the tps was put on yesterday and didnt solve the problem
    2.2 CL
    i am having similar problems i was reading a whole bunch of stuff last night about it and i would try pulling the iac and cleaning it with some MAF cleaner. ist about 6 bucks at any auto store jus my
    Nov 2003
    Like physically where is it?
    Quote Originally Posted by SLo_MKIII
    i took it off but didnt see like no where to clean except under the bottom where the 3 bolts are where else is there to clean somone else told me it could be distributor but i got code 7 and 14 i just replaced the tps tho and it hasnt went off yet and 14 is iacv i dont kno
    Probably the FITV on the bottom of the throttle body.
    Nov 2003
    That won't make it top out at 2,500, just be a high and/or fluctuating idle...sounds like the ECU is in "limp/safemode" for some reason.
    Senior Member JDM onlyy's Avatar
    Jonesboro/Stockbridge
    7 is TPS and 14 is IAC. Did you reset your ecu to see if will come off or if it will come back on? CEL I mean...
    Quote Originally Posted by JDM onlyy
    HOW DO YOU RESET it i took the battery cable off or watever and put it back on and it did nothin i have a check engine light but its been on since i bought the car
    Nov 2003
    The check engine light means it's throwing a code, the only two codes you have is 7 and 14?
    yes that is the only code i think maybe i counted wrong ive got one long blink 4shorts and 7 quick blinks
    Augusta Ga
    well do wut the EX owner didnt do .. Replace them sensors .. and call it a day ... junkyard will be your friend .. or jus buy them new
    93 sol Si
    95 sol S
    95 sol Si
    yea i been getting around to gettin em all now but sensors arepretty expensive
    Mountain man green91's Avatar
    Dahlonega, Ga
    seeing how youve got a LS in an EF and both the TPS and IACV require wiring modifcations id start by checking the wiring.
    Quote Originally Posted by green91
    seeing that was alreadi done and i alreadi did it so wat else can u think of smart ass
    Macon
    you have to leave the positive cable unhooked for a while, maybe 5 minutes???
    Land Rover LR3 HSE
    Augusta Ga
    yea 5 minutes should be plenty ...
    93 sol Si
    95 sol S
    95 sol Si
    Dahlonega, Ga
    i wasnt being a smart ass, the sensors dont typically go bad and especially not at the same time asshole. so checking the wiring would be a good place to start. but good luck fixing it dickhead. youre obviously pretty smart
    I been checked the wires so that isnt the problem
    Newbie Photodude RBS's Avatar
    All Over U S A
    just a thought, but try switching the TPS and IACV plugs see if it does anything
    Quote Originally Posted by SoSillyyyy
    can't...tps is 3 wire and iacv is 2 wire plugs. good try though.
    HONDATA DEALER/TUNER
    NISSAN REALTIME-NISTUNE
