thanks alex14!
thanks alex14!
got more parts in... hopefully be putting heR back together soon.
updates?
D16 + Turbo = The Replacement for Displacemnt
I will have some updates next week since i'm off all week.
more updates!!!
since i'm off all week of thanksgiving I figured I would get something done on the caR!!
por15'd more stuff!!
finished
Finally finished the fender wells and underside in por15 with a topcoat (which is lighter grey)
I kinda like the two tone :P
I also wanted to mock up my new fuel and brake lines
old stuff
new lines together
I also sprayed the plastic tray black again
Also had my future father in law and his friend stop by and bring their welder
I had to cut a hole in the toe adjuster area since the bolt was rusted to the toe arm. Got everything taken care of and also was still able to use the slide adjuster nut.
rewelding the hole back up!!!
then por15'd over it
[b]And last but not least I pressed my lower ball joints in[/b
more more more more more more more more!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Shit. I didn't know you took the windshield out already
great work!!! (class is in session boyz listen up!!!)![]()
got many more parts in and will actually start putting stuff back on the caR
Have some updates!!
Got the fuel/brake lines all mounted up
I got the lines bolted up and also got the subframe mocked up
I also had to fix/ rethread some holes due to paint and por15 in the threads
also a departing pic
broken type R spoiler and rusted lines in the trash :P
Got all of the brake/ABS lines in
I also put in the driver side wiring harness
edit...
the caR finally broke skin!
I'm coming by to see this tomorrow.
Started to get gas tank and filler neck ready to put back in the caR
cleaned up and painted
pic of the brake and fuel lines
Gas tank (added foam padding to the top since the old stuff is trash)
bought new covers since the old ones were trash
Last but not least i got the exhaust back up and bought some heat shields as well since they were missing.
waiting on my PCI RTA's and also a new lower control arm back ordered from the dealer![]()
thanks Bacon!
got the rest of my suspension pieces and hopefully by next week get everything put back on
a departing pic for the evening...
more updates!!!
I got all of my rear suspension parts in so I can put it back together
PCI RTA's
Put everything back up
It was bothering me with the springs and surface rust so I took them apart to get sand blasted
Got everything ready to go get sand blasted and powder coated (i'm lazy and didn't want to Por15)
A few days later I picked up everything from the sand blaster and brought to the powdercoater! Here is the finished product!
Got the coilovers back together and torqued the subframe and other suspension parts. Put the front sway bar in and got the rear sway bar bushings in and put them in.
I also am getting the interior ready to be sanded and painted
and how she is sitting right now...
Sex
Sex
Wow. I wish i had the skills you have to do that to my car. You dont happen to have an extra itr wing laying around do you?
looking good buddy
GECKO SQUAD MEMBER
MSS RACING REPRESENTA.....
the saga continues....
such an amazing restoration/upgrade homie.. keep it up..
Over the past week I got more done on the caR!
Got the interior sanded and also ground down the old cage stumps
and I also got some tires in for my track wheels
Nice meats. 225/45 or 205/50? I just ordered up some 205/50 Ecsta XS but was on the fence between the XS and the R1R. Went with the XS so I could rotate the tires side to side.
Picked out some wheels?
