Results 1 to 35 of 35
Thread: b18b all motor
    Certified Gearhead 93delsol15's Avatar
    tennessee
    Default b18b all motor
    i have been searching around and still havent gotten any clear results but here is my question:
    i have an Ls that is going in my sol and i want to stay all motor but i dont want to put new pistons in so what can i do to get some good numbers out of it?
    i was thinking about doing:
    2 layer head gasket
    edelbrock intake mani
    injen cai
    larger TB
    2.5 exhaust
    decent port polish
    crower cams
    crower valve train
    and a decent header
    will this make some decent numbers
    ps i am new to b series soo go easy on me
    d15b7 fs 300obo has to go soon
    All that will cost over $1K easily and you still won't make over 170 WHP.
    You could start off the an aftermarket intake manifold, Ebay intake, 2.5" exhaust, and a header and get a few WHP .. and that's about it. Larger TB is a waste of money for you right now.
    tennessee
    thanks for the input man i may go with a small turbo setup but i really just want about 170-175 so that sounds good
    buy a header from me , the Tri-y ($280)
    Buy a Skunk2 Intake manifold
    Buy Crower 403s (stock valvetrain is ok)
    Buy an ECU from me an tune.
    should make 150whp, thats about the best you can expect from a stock bottom LS engine
    listen to kidd he knows his S l-l it the tri-y is awesome too
    i had 155whp in my b18a1 with a 7lb flywheel full skunk 2 exhaust and a ebay intake.
    Quote Originally Posted by fightrice
    HAHA i agree that number aint worth crap unless you got a paper provin it
    Southside of The Jungle
    why do ppl say stock valvetrain you cant use on those cams?They say get dual valve springs.
    you can use stock valvetrain on crower 403 cams. you cant use stock valvetrain on crower 404 cams
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Quote Originally Posted by jadakid88
    and u dont have to worry about valve float with them
    Warner robins ,Ga
    hes the man.
    no need for the edelbrock manifold and the injen cai...id just do a cheap intake with blox velocity stack and filter.
    post the dyno. That would be the STRONGEST B18B in history
    02 WRX patrick4588's Avatar
    warner robins
    x2. i would just go with a small turbo setup
    GCO Member
    NRA Member
    well for a complete all motor non vtec b series here you go
    http://www.jspecautosports.com/files...chcenter3m.htm
    How many miles does the motor have on it also.Just throwing stuff together on a old worn out motor wont help either.I say stock rebuild then add jubaloop
    the motor was new with low miles. When i first dynoed it with just a intake and header it had 132whp. Ill dig the sheet up from that. Was at mainstream i talked to dave and rob up their and with the setup im running i should be around 155whp. Dave said hes never seen a stock b18 put down numbers like this. you also have to consider weather and everything when its dynoing.
    so SHOULD you make 155whp or DID you make 155whp with just an intake an exhaust?
    if you did make it, then holy **** thats a record.
    Out in the Boonies
    if you want to go all motor vtak is the way to go
    B20 wat u want to do JDMB20's Avatar
    Macon
    hey i think mr.kidd knows wat he is talking about when it comes to cams.....
    ONE DAY
    Yep....I got nothin Pickleteg's Avatar
    Clarksville, TN
    I hate to tell ya but to get the most outta those 403s you need higher compression. I am a LS guy but my opinion is to put a small turbo on it or do the LS/VTEC. Strictly my opinion, do what you want. People hated on my JRSC LS.
    95 Teg SE Synapse A/C ramhorn kit, 276whp, 210wtq
    09 Si Sedan...some bolts ons....
    NW, GA
    My LS with msd cap and coil, intake, header, cat back made 135.2 whp and 119.7 ftlbs
    Certified Gearhead PUNISHER's Avatar
    macon
    the key to N/A LS is compression i had a LS integra GSR tranny with PR3 piston p&p head crower cams, springs, stock manifold ported with a 68mm TB it went best of 14.7@95 i figure that should be around 160hp with no tune and in integra with A/C
    Quote Originally Posted by PUNISHER
    Thats good I guess since it was in a teg.
    macon
    yea i would think so i think with tune on it maybe some low 14's on street tire or maybe high 13's on a slick........ you should have picked that stuff up of mine i hope the new ower will make something out of it in his hatch
    or drag radials
    tennessee
    well i just want like 150 at the wheels for now so any ideas to get close
    you dont need to know
    buy a b20 iahd 1 that made 139WHp and 129tr in a hatch and ran 14.2 on street tires.
    tennessee
    ok this thread was about a b18 please be helpful
    Quote Originally Posted by 93delsol15
    just my 2 cents , good luck on getting those numbers.
    my car blew before i got another chance to dyno it. But i had no a/c no power steering. I just had hte manditor tings to make the car work. might not add much idk. Also depeds on type of dyno
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    Small Turbo x2, 170whp is very easily obtainable W/a small turbo. My bone stock LS made a 127whp W/all acc. To be honest I can't see a LS being too successful N/A, Never the less Good Luck.
    Quote Originally Posted by twinj
    LS motors can be very successful N/A if you have the money and the right set up actually
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Search honda-tech all motor section. I'm pretty sure you can get the info you want from there.
    tennessee
    thanks for the responses guys
    macon
    N/A power is totally different from boost power but IMO its not hard to get good numbers out of a LS motor but will take time and some R&D
