Having problems getting that 2.5in Header to bolt up to your stock or stock size exhaust?
Want to buy a 2.5in Header and have it bolt up to name brand exhausts like Skunk2, Greddy, HKS, etc?
What about 2.5in DOwnpipes?
Or if you are in the market for just replacing that power robbing catalytic convertor, ive got you covered.
-Basic info on test pipes-
* Made Out Of Aircraft Quality 304 Stainless Steel
* Adjustable Length & Clocking w/ Removable Center Section
* 5-10 Horsepower Increase Depending On Engine Modifications
* Will Work w/ Your Stock Header Or A 2 1/2" JDM Header
JDM=2.5" collector.
* Bolts Up To 60mm Exhaust Systems
* Hand Tig Welded For Your Viewing Pleasure
* This Product Is For Off Road Use Only
* o2 bung for use of an o2 sensor or without
KiddRacing ADJUSTABLE TEST PIPES
VERSION 1
VERSION 2
Tri-Y Header TestPipe
This is a modified version that has 1 extra adjustment so that the hytech replica header will directly bolt on to your cat back exhaust with no extra welding, Straight bolt on solution !
An average of 5-10 horsepower can be gained depending on engine modifications and if properly tuned. Can be used with your stock exhaust manifold or a 2 1/2" JDM size collector header.
$85 SHIPPED !
