Results 1 to 30 of 30
Thread: Built Head, blown block?
    The Dark Lude dakilla4ever's Avatar
    In the Darkness
    Default Built Head, blown block?
    I've heard that if you have a fully built head it will cause you to throw a rod or maybe other serious damages to the block. If anyone has any insight on this let me know. I'm considering buying the Crower stage 2 camshafts and the spring and retainer kit for my H23 with new stainless steel valves. Info will be greatly appreciated.
    Fast+Cheap= Not Reliable
    Cheap+Reliable=Not Fast
    Fast+Reliable=Not Cheap
    THE DARK LUDE SPEAKS
    Ive NEVER heard that before, i had a completely built CROWER head on my LS, nothing happened. Who ever told you that is an idiot i think, but i could be wrong
    Lexus GS300
    DC5-R
    Gwinett
    Quote Originally Posted by SL33P3R
    In the Darkness
    Cool I thought he ,ight have been blowin steam but i didn't know if it had a chance of being true.Will the crower head setup interfer with the type-s pistons im putting in. Cause i still dont understand the whole "clearance" thing.
    Senior Member 99SI's Avatar
    Jackson
    The problem you can encounter with a "built" head and a stock bottom end is when you get into high RPM's. Most aftermarket camshafts need to rev higher than the stock rev limit to really take advantage of the increased lift/duration. Depending on how aggressive of a cam you run or how much higher you are turning the motor above the stock rev limit you can run into problems. A "built" head on a stock block alone will not cause any damage at all as long as you do not have any piston to valve contact due to the increased lift and duration of the aftermarket cams. That's why on both of my motors I added ARP rod bolts. Rod bolts are generally the weak link on the Honda motors. I do not have any personal experience or input to give on the H23 specifically as I'm not familiar with it. Good luck I'm sure there are people out there who have run type s pistons in the H23 with aftermarket cams if you look you should be able to find something.
    In the Darkness
    Thanks for the info.
    In the Darkness
    How do i go about measuring all this before i buy these parts and end up having to sale something i don't need.
    Jackson
    claying the motor is the best way to tell if you will have valve clearance issues. It's a bit time consuming and since I am sure what you are doing has been done before I am sure you would be able to find some info on whether there are any clearance issues. I would imagine that with a small cam such as the Stage 2 crower you wouldn't have any problem but I do not know what type of dome is on the type S piston. Also has your head been decked or milled down?
    Macon
    With type-s pistons you are gonna be around 12:1 compression ratio. So id say a good tune along with your willingness to run 93octane all the time will be the deciding factor on how long the motor lives. Assuming there are no clearance problems of course.
    98 Ex - B16
    92 accord - H23
    95 teg - shell
    88 std - shell
    98 Lude - broken :/
    06 Sierra 4x4
    who builds an H23 LOL.
    those motors dont like to rev, so i hope you keep the RPM down
    In the Darkness
    I do. Now back to the subject. How do i measure the piston height and the length of my valves, in relation to my cam duration.
    with tools that you prob dont own.
    Dome height, comp height, valve face, duration , valve to valve, valve to piston clearance. those are all numbers you should have.
    In the Darkness
    See that was all i needed not all that other shit. Preciate it.
    ^The Bad Guy toonz's Avatar
    Lithia Springs LOL!!!!!!
    LOL ^ I saw you on the southside one day with that dark blue Prelude more like midnight blue or something like that right
    Still here!
    In the Darkness
    Yeah. Where were you?
    Im the kid that pops up sometimes LOL I got the sleeping white crx with the loud ass muffler LOL you know my boy Drew with the Black spray painted crx sometimes I come up there with him in the white one I met you before but that was a while back
    Still here!
    In the Darkness
    Quote Originally Posted by toonz
    Yeah i gotcha. Have you been out lately?
    If you were keeping the stock pistons, you probably wouldn't be increasing lift and duration enough to run into interference issues, but with the new pistons it's a lot more critical to know your clearences. Even more so if you throw adjustable cam gears into the mix. If you're putting in pistons why not go the rest of the way? You need to know what head gasket your going to run so you can use it's thickness to calculate your clearences, or make very small adjustments in static comp ratio. So........using clay is probably your best bet, it's ghetto but people have been using it for years.
    Quote Originally Posted by dakilla4ever
    Nah I'll be out soon tho it was cool meetin you I'll be out there sometime I don't know it just sometimes it's dead so I just chill wit tha wifey
    Still here!
    In the Darkness
    Very understandable. Well if you decide to roll out there just catch up with me.
    In the Darkness
    Quote Originally Posted by Big J
    I'm going with TYPE-S pistons and crower stage 2 cams. And numerous other things but that the main reason for this thread. I was just trying to figure out how to measure all of that without buying all the parts then ending up having to sell my cams because they have too long a duration.
    Cool
    Still here!
    In the Darkness
    Cool
    Yeah thats what i think as well but everybody i talk to can't tell me how, or what i need to do to calculate this before i buy this stuff.
    Jackson
    Use your math skillz yo!
    In the Darkness
    O....K...... AND DO WHAT WITH THEM. What numbers am I using. Thats what im trying to find out.
    Jackson
    add them, subtract them, multiply them, divide them, as for the numbers I would start with real numbers, then move on to prime numbers, then get into fractions. lol, I'm just fucking with you. Can't help it. I can't tell you the actual process that you need to do. I only know what you need to do. I would seriously doubt you will have problems with any piston to valve contact, however, it is always best to know for sure. I would try to contact a shop to see what their input would be. You may have to pay a little bit to get it figured out but in the long run it would be worth it IMO. Good luck.
    In the Darkness
    Preciate that. I didn't event think about that. Cool.
    In the Darkness
    So what do I need to have my block capable of spinning at higher revs?
    Jackson
    higher is relative. You really should not spin too high with the H23 regardless of what you do b/c of the rod/stroke ratio. A set of ARP rod bolts and a full balancing of the bottom end will give you a little more insurance to go up a little higher. Again, my limited knowledge of H series specifics keeps me from putting out a specific RPM you could go to.
    In the Darkness
    Cool preciate the info. What all do I need to balance, besides the crank?
