Thread: 3mm oversize Intake valves?
    Oct 2003
    Exclamation 3mm oversize Intake valves?
    Well found a head for a decent price with following
    B18c1 Head
    3mm oversize intake valves
    0.5mm oversize exhaust valves
    my current setup:
    b16 Block balanced stock bottom end
    B18c1 head
    Skunk2 Stg2 cams
    skun2 ProSeries Intake Manifold
    Dual valve springs/Retainers
    revs to 9k easy as hell
    DynoDay was a big disappoinment .. only made 146hp because i was running REALLY lean, i know it could put down 160 easily
    but found out on the way home why...injector 1 has completely stopped working,
    Ok back to my question
    i think i am gonna have more of a valve to Valve clearance issue more than valve to piston especially if i rev high
    what do yall thinkkkkk? or should i go gsr block or b20?
    Attached Thumbnails Attached Thumbnails -aaaaaaaaaaaaa-jpg
    Alpharetta/Duluth
    have you measured the valves? Are they from a different honda motor? I didn't think you could get 3mm oversize unless maybe it is a custome race-only valve.
    Oct 2003
    custom race only application valves....... head was built for a turbo appl
    complete port & polish work on exhaust and intake
    BAD NEWS, the head is NOT holding you back. you need a better header, an TUNING.
    i made 240whp with STOCK SIZE valves. Oversized valves are not needed an are bad news, ESPECIALLY a valve that much oversized.
    you will have big problems with valve to valve contact with any camshaft if the valves are that big
    HardParkin'
    and something bigger than a 1.6 bottom IMO
    everywhere & nowhere
    Stay away from oversized valves in a B series IMO. I really built SOHC head could use it if you are REALLY tryna get more flow, but that would need to be an insane build.
