Results 1 to 19 of 19
Thread: acura integra gsr vs. type r...
    Roswell
    Default acura integra gsr vs. type r...
    can anyone tell me the differences in these cars? any help is appreciated.
    Jan 2005
    Columbus, Ga
    hp
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    Gainesville
    lol at B...dog you wildn out... naw man see a GSR stock is perfect for a small amount of boost as to wer the compression rates of a TyTe-R are to high...plus IMO GSR are best for a Boosted buile either with a Turbo or Supercharger, as to were a Type-R would be better for a N/A build..that's just my opinion though...
    h series
    norcross
    Quote Originally Posted by §treet_§peed
    so so true
    down the yellow brick road
    ehh i belive the jdm itr motor revs to around 9k....i dunno about the usdm itr motor though....
    Gainesville
    i believe you are correct sir...but i also think that the USDM version revs to 9K also.....but
    yeah i dont know about the usdm version. I've only ridden in a teg with a jdm ITR swap. Could very well rev to 9k too
    da ringmasta teggy 2nr's Avatar
    G county
    usdm revs to 9k too, and the best teg for boost will be the LS because of the super low compression of the b18b. the type-r comes with a great amount of hp, but its actually really hard to modify, if you dont know what you doing, the mods you put on there will LOWER hp rather than increase....type-r has longer gear ratios, i believe, and the tranny also comes equipped with LSD...aside from mechanical differences, the inside of a type-r looks super duper cool with the black leather and red stitching reminds me of a pair of reebok solja's i use to own.....
    Gainesville
    GSR's do it better!!!!!!!
    noob?call it transfer
    Bama
    i think the gsr is best 4 boostcuz it comes comes with beefier internals than a ls. jus change the pistons for a high boost 2 lower compression correct me if im wrong
    Some people are like slinkies!good for nuthin but u cant help but smile if you see one tumble down the stairs
    Factory Intgegra Type R LSD $300 PM Me.
    BanBait
    Atl
    Quote Originally Posted by kidstyle12
    If you're gonna go that far in and replace pistons, who really cares about the rest of the internals that are stock?
    "better" completely depends on what you want to do, where you want your power, what you can afford etc. This is like asking "what should I eat for breakfast?"
    I live my life one VTEC engagement at a time
    USDM B18C5 (Type-R) is 8,700 with 190-195hp and think the B18C[R] redlines around 8,900 w/ 205-210hp. There's also differant generations of the ITR engine with the latest version ('00-01) having the slighter better intake cam from the Civic Type-R (3° higher intake duration). Compression ratio is 10.8:1.
    B18C & B18C1 (SI-R/GS-R) redlines at 8,200 with 170-178hp and has a 10.6:1 compression ratio.
    Gear ratio's are differant and the ITR has a LSD.
    As for the car itself, ITR's have slightly beefier suspension and sits about an inch lower stock. 22mm USDM and 23mm JDM rear sway bar while the GS-R has a 14mm. Five lug suspension on all but the '96 ITR (4x114.3) and GS-R's all have 4x100. Obviously the ITR has a taller wing and interior pieces and seats are differant. There is a little bit extra bracing in the unibody itself on the ITR but some weight removed from other areas.
    This should keep you entertained for a lil bit
    :) LiL PaKi's Avatar
    in my own lil world
    like shaved sides...
    Quote Originally Posted by LiL PaKi
    oh yeah, no molding on the doors....you'd think i would have remembered that considered what i paid to shave mine and paint everything
    in my own lil world
    haha... i love having my bro as my personal mechanic... well one side of my teggy is filled (metal welded in) the other side still has the holes from the molding.. man i'm still rockin primer
    mechanic and good body work are two differant things....can't weld on thin sheet metal very easily because it will expand and contract making a wavy door.
    in my own lil world
    true.. well he does a lil bit of body work too...
    Bama
    GOOD INFO BRO WISH SOMEONE WOULD PUT THAT MUCH IN MY THREADS
    Boosted LS FTW
    -Taylor
    Lexus GS300
